Power Mode Description and Operation
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits,
one module is the power mode master (PMM). On this vehicle the PMM is the BCM. The
BCM will monitor the mode switch only with battery voltage above 7 volts to
prevent invalid input readings during low voltages encountered during vehicle cranking.
If the mode switch input or the battery voltage input changes, a ratiometric calculation
of mode switch input value is performed. The BCM discerns four thresholds:
To determine the correct power mode the BCM uses:
• | The mode switch data received from the ignition mode switch
• | The status of the engine run flag (ERF)
The following power mode states are transmitted on the class 2 network:
The following power mode states are transmitted on the GMLAN network:
The power mode message is a periodic with event message type and is transmitted
by the PMM or BPMM at every 2 seconds on class 2 link and at every
250 ms on GMLAN link.
The Accessory power mode times out after 20 minutes and will transition
to Off/Awake or RAP power mode.
Fail-safe OperationThe remote control door lock receiver (RCDLR) is the back up power mode master
(BPMM). The both BCM and RCDLR receive signals from the ignition mode switch, representing
the mode switch data, through 2 different circuits. Therefore if BPMM becomes enabled,
it can determine and transmit all the system power modes per the lists above, except
RAP. There is no degradation in system operation if the BPMM is the RCDLR. Since the
operation of the vehicle systems depends on the power mode, there is a fail-safe plan
in place if the power mode message is not received from the BCM or RCDLR. The fail-safe
plan covers modules with discrete ignition signal inputs as well as those modules
using exclusively serial data control of power mode. The engine control module (ECM)
behaves differently.
Serial Data Messages If no power mode message can be received, the modules remain in the last power
mode received and check for the ERF message. If the ERF serial data is true, indicating
that the engine is running, the modules fail-safe to "Run" power mode. In this state
the modules and their subsystems can support all operator requirements. If the engine
run flag serial data is false, indicating that the engine is not running, the modules
fail-safe to "Off" power mode.
Discrete Ignition SignalsThose modules that have Run/Crank discrete ignition signal input also remain
in the state dictated by the last valid power mode message from the BCM or the RCDLR.
They then check the state of their Run/Crank discrete ignition signal input to determine
the current valid state. If the discrete ignition input is active, the modules will
fail-safe to the "Run" power mode. If the discrete ignition input is inactive, the
modules will fail-safe to "Off" power mode.
PCM and TCM Power Mode Backup StrategyThe PCM and TCM remain in the last known power mode state until it can determine
its backup system power mode based on their discrete Accessory/Wake up and Run/Crank
signal inputs.
Accessory/Wake Up Signal State
| Run/Crank Signal State
| Power Mode Determined
Inactive
| Inactive
| Off
Active
| Inactive
| Accessory
Active
| Active
| Run
Inactive
| Active
| Crank
