Bearing Housing Assembly to Coupling Bolts
70 N·m
52 lb ft
Bearing Housing Assembly to Driveline Support Tube Bolts
65 N·m
48 lb ft
Clutch Actuator Cylinder Mounting Bolts
12 N·m
106 lb in
Coupling to Propeller Shaft Bolts
70 N·m
52 lb ft
Driveline Tunnel Closeout Panel Bolts
10 N·m
89 lb in
Driveline Support Assembly to Engine Flywheel Housing Bolts
50 N·m
37 lb ft
EBTCM LH Mounting Bracket Mounting Bolts
50 N·m
37 lb ft
Flexplate to Flexplate Spindle Bolts
50 N·m
37 lb ft
Hub to Flexplate Spindle Bolt (Automatic Transmission)
50 N·m
37 lb ft
Input Shaft Bearing Positioning Bolts
35 N·m
26 lb ft
Input Shaft to Coupling Bolts
70 N·m
52 lb ft
Negative Battery Cable Bolt
15 N·m
11 lb ft
Output Flange Bolt
50 N·m
37 lb ft
Propeller Shaft Hub Clamp Bolt
130 N·m
96 lb ft
Rear Exhaust Hanger Mounting Bolts
50 N·m
37 lb ft
Rear Shock Absorber Lower Mounting Bolt
220 N·m
162 lb ft
Rear Suspension Crossmember Mounting Nuts
110 N·m
81 lb ft
Shift Control Mounting Bolts
30 N·m
22 lb ft
Shift Control Closeout Boot Retaining Nuts
12 N·m
106 lb in
Transaxle Mount Bracket to Differential Bolts
50 N·m
37 lb ft
Transaxle Mount to Rear Suspension Crossmember Nuts
50 N·m
37 lb ft
Transmission to Driveline Support Assembly Bolts/Studs
50 N·m
37 lb ft
Transmission Oil Cooler Rear Pipe Front Fittings to Junction Fittings at Engine Flywheel Housing
27 N·m
20 lb ft
Transmission Oil Cooler Rear Pipe Rear Fittings to Transmission Fittings
40 N·m
30 lb ft
Transmission Oil Cooler Rear Pipe Front and Rear Retaining Clamp Bolts
12 N·m
106 lb in
Transmission Shift Control Cable Bracket Retaining Nuts
20 N·m
15 lb ft
Transmission Shift Rod Clamp Bolt
30 N·m
22 lb ft
Transmission Wiring Harness to LH Transmission Case Retaining Bolt
2.5 N·m
22 lb in
