Coolant
Antifreeze to Coolant Mixture (percent)
50/50
Antifreeze (Pure) Point of Freeze
-20°C
-8°F
Antifreeze (50/50 Mixture) Boiling Point
128°C
262°C
Protection Rating
-37°C
-34°F
Type
GM-Goodwrench DEX-COOL®
Cooling Fans
Blade Diameter
312 mm
12.3 in
Motor Type
2-Speed
Number of Blades
5
Cooling System Coolant Capacity
Automatic Transmission
11.6 liters
12.3 quarts
Manual Transmission
11.9 liters
12.6 quarts
Radiator
Core Material
Aluminum
Fill Cap Pressure Rating
103 kPa
15 psi
Fill Cap Pressure Test Rating (Max)
138 kPa
20 psi
Type
Aluminum/Plastic Slant Back
Thermostat Test (33% Glycol Solution)
Closed (Degrees Below Specification on Valve)
6°C
10°F
Open (Degrees Above Specification on Valve)
11°C
22°F
