Gm has a PCM flash fix for this
Document ID# 1812070
2006 Chevrolet Corvette
DTC P0443 or P0449
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P0443: Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0449: Evaporative Emission (EVAP) Vent Solenoid Control Circuit
Diagnostic Fault Information
Circuit
Short to Ground
High Resistance
Open
Short to Voltage
Ignition 1 Voltage - Purge Supply
P0443
P0443
P0443
Battery Positive--Vent Supply
P0449
P0449
P0449
EVAP Purge Solenoid Control
P0443
P0443
P0443
P0443
EVAP Vent Solenoid Control
P0449
P0449
P0449
P0449
Circuit/System Description
P0443
An ignition voltage is supplied directly to the normally closed evaporative emission (EVAP) canister purge solenoid valve. The EVAP canister purge solenoid valve is pulse width modulated (PWM). The scan tool displays the amount of ON time as a percentage. The control module monitors the status of the driver. The control module controls the EVAP canister purge solenoid valve ON time by grounding the control circuit via an internal switch called a driver.
P0449
Battery voltage is supplied to the evaporative emission (EVAP) canister vent solenoid valve. The control module grounds the EVAP canister vent solenoid valve control circuit to close the valve by means of an internal switch called a driver. The scan tool displays the commanded state of the EVAP canister vent solenoid valve as ON or OFF. The control module monitors the status of the driver.
The ignition is ON.
The system voltage is between 9-18 volts.
DTCs P0443 and P0449 run continuously when the above conditions are met.
The control module detects that the commanded state of the driver and the actual state of the control circuit do not match for a minimum of 5 seconds.
DTCs P0443 and P0449 are Type B DTCs.
Conditions for Clearing the MIL/DTC
Reference Information
Schematic Reference
Engine Controls Schematics
Connector End View Reference
Engine Control Module Connector End Views
Engine Controls Connector End Views
Description and Operation
Evaporative Emission Control System Description
Electrical Information Reference
Circuit Testing
Troubleshooting with a Test Lamp
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
DTC Type Reference
Scan Tool Reference
Scan Tool Data List
Scan Tool Output Controls
Circuit/System Verification
P0443
With the ignition ON, engine OFF, you should hear a clicking sound when the EVAP canister purge solenoid valve is commanded to 50 percent with a scan tool. The clicking sound should stop when the EVAP canister purge solenoid valve is commanded to 0 percent. The rate at which the valve cycles should increase when the commanded state is increased, and decrease when the commanded state is decreased.
P0449
With the ignition ON and the engine OFF, command the EVAP vent solenoid ON and OFF with a scan tool.
Listen for a click when the valve operates. Verify that both the ON and the OFF states are commanded.
Circuit/System Testing
P0443
Ignition OFF, disconnect the harness connector at the EVAP canister purge solenoid valve.
Ignition ON, verify that a test lamp illuminates between the voltage supply circuit terminal A and ground.
⇒ If the test lamp does not illuminate, test the voltage supply circuit for a short to ground or an open/high resistance. If the circuit tests normal and the voltage supply circuit fuse is open, test or replace the EVAP canister purge solenoid.
Connect a test lamp between the voltage supply circuit terminal A and the control circuit terminal B.
Command the solenoid to 50 percent with a scan tool. The test lamp should flash or illuminate when commanded to 50 percent and turn OFF when commanded to 0 percent.
⇒ If the test lamp is always ON, test the control circuit for a short to ground. If the circuit tests normal, replace the control module.
⇒ If the test lamp is always OFF, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the control module.
If all circuits test normal, replace the EVAP canister purge solenoid valve.
P0449
Ignition OFF, disconnect the harness connector at the EVAP canister vent solenoid valve.
⇒ If the test lamp does not illuminate, test the voltage supply circuit for a short to ground or an open/high resistance. If the circuit tests normal and the voltage supply circuit fuse is open, test or replace the EVAP canister vent solenoid.
Command the solenoid ON and OFF with a scan tool. The test lamp should turn ON and OFF when changing between states.
If all circuits test normal, replace the EVAP canister vent solenoid valve.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Evaporative Emission Canister Vent Solenoid Valve Replacement
