Document ID# 1999041
Subject: Information on Passenger Presence Sensing System (PPS or PSS) Concerns with Custom Upholstery, Accessory Seat Heaters or Other Comfort Enhancing Devices) #06-08-50-009B - (07/19/2007)
Models: 2008 and Prior GM Cars and Trucks (including Saturn)
with Passenger Presence Sensing System
This bulletin is being revised to include the 2008 model year. Please discard Corporate Bulletin Number 06-08-50-009A (Section 08 - Body and Accessories).
Concerns About Safety and Alterations to the Front Passenger Seat
The front passenger seat in many GM vehicles is equipped with a passenger sensing system that will turn off the right front passenger's frontal airbag under certain conditions, such as when an infant or child seat is present. In some vehicles, the passenger sensing system will also turn off the right front passenger's seat mounted side impact airbag. For the system to function properly, sensors are used in the seat to detect the presence of a properly-seated occupant. The passenger sensing system may not operate properly if the original seat trim is replaced (1) by non-GM covers, upholstery or trim, or (2) by GM covers, upholstery or trim designed for a different vehicle or (3) if any object, such as an aftermarket seat heater or a comfort enhancing pad or device is installed under the seat fabric or between the occupant and the seat fabric.
Aftermarket Seat Heaters, Custom Upholstery, and Comfort Enhancing Pads or Devices
Important: ON A GM VEHICLE EQUIPPED WITH A PASSENGER SENSING SYSTEM, USE ONLY SEAT COVERS AND OTHER SEAT-RELATED EQUIPMENT RELEASED AS GM ACCESSORIES FOR THAT VEHICLE. DO NOT USE ANY OTHER TYPE OF SEAT COVERS OR SEAT-RELATED EQUIPMENT, OR GM ACCESSORIES RELEASED FOR OTHER VEHICLE APPLICATIONS.
Many types of aftermarket accessories are available to customers, upfitting shops, and dealers. Some of these devices sit on top of, or are Velcro® strapped to the seat while others such as seat heaters are installed under the seat fabric. Additionally, seat covers made of leather or other materials may have different padding thickness installed that could prevent the Passenger Sensing System from functioning properly. Never alter the vehicle seats. Never add pads or other devices to the seat cushion, as this may interfere with the operation of the Passenger Sensing System and either prevent proper deployment of the passenger airbag or prevent proper suppression of the passenger air bag.
