I spent the afternoon installing the Team ZR1 W/I kit. The install went pretty smooth but I have a couple of kinks to work out.
The first problem is a leak at the injector nozzle. I didn't put any sealant on it so that should be easy to fix in the morning. I'll put some Goop on the threads and reinstall the fitting on the nozzle.
The other problem is once I start the car it idles very rough for the first minute or so. I assume that I have the controller set to come on too soon so I adjusted it up but ran out of time to test it.
I also reinstalled the Halltech air cleaner that I had stored in my garage due to the fact that the injector nozzle didn't look like it would work very well in the factory accordion connector.
I'll enclose a few photos I took of the install.
Below is a photo of the WW tank that is used for the system
Since I didn't have any room near the tank to mount the pump I installed it in the front of the car. It is bolted to the rocker rails.
Here is a picture from above showing the placement of the nozzle.
[img][IMG]http://img.photobucket.com/albums/v243/BrettH/Water-Methinjection005.jpg[/img][/img]
and another from the other side
I'll start a new post with the other pics so it will load quicker.
