That is about where I had the start voltage set. Could it be due to the fact that I was not on the road and simply revving the engine to do the final check for leaks? Since the engine was not under load and comes back down to idle fairly quick I guess it would take awhile to use up all of the pressurized fluid from the pump to the nozzle?
I'm waiting on the Goop to dry a little before starting it up this morning. I should be able to get it out on the road today.
Is there a chart that gives a conversion from volts to Hz with the controller?
Thanks for the info on file uploads. I looked around the site trying to see how to upload pics before uploading to my Photobucket account.
