#1890 - 08/02/07 11:31 AM LS7 Engine Repairs Or Replacements
Document ID# 2001187
Subject: Chevrolet Corvette LS7 Engine Repairs Or Replacements - keywords 7.0L block cool coolant head knock lek lifter noise oil piston push replace replacement rod spring tick valve Z06 #PIP4132A - (07/31/2007)
Models: 2006-2007 Chevrolet ZO6 Corvette
Equipped with the 7.0L engine RPO code LS7
This PI was updated to put a hold on Bowling Green repairs. Please discard PIP4132.
Condition/Concern:
The new engine replacement process on 2006 to 2007 ZO6 Corvettes has been put on hold.
The process would have been as described below.
General Motors has started a new engine replacement process on any 2006 to 2007 ZO6 Corvettes.
If a dealer has encountered a 2006 to 2007 ZO6 Corvette that needs an engine replacement, please contact the General Motors Technical Assistance Center (GMTAC), or the Powertrain Quality Center (PQC).
If the decision is made to replace the engine, a qualified shipper will be sent to the dealer to pick up the vehicle.
The vehicle will be shipped to the Bowling Green Assembly Plant and the new engine will be installed there. After repairs the vehicle will be shipped back to the dealer.
Recommendation/Instructions:
Due to the workload at the Bowling Green Assembly plant no more vehicles will be scheduled for engine replacements.
Please continue to use SI diagnostics, and complete any LS7 repairs or replacements at the servicing dealer.
This PI will be updated when more engine replacements can be scheduled.
#1895 - 08/04/07 10:32 AM Re: LS7 Engine Repairs Or Replacements [Re: teamzr1]
barkingowl
JR what's up with all of the engine replacements for the Z06s anyways? Weren't they built right?
#1901 - 08/04/07 11:26 AM Re: LS7 Engine Repairs Or Replacements [Re: ]
Issues have been with oiling, bearings and valve springs
Not sure though how many were damaged sue to abuse, lousy mods added or bad tunes installed in them
Keep in mind it was a 346 CI block pushed out to a 427 makes very little safety between cylinders
#1915 - 08/08/07 06:55 PM Re: LS7 Engine Repairs Or Replacements [Re: teamzr1]
Gregory T. Lloyd, DVM
do you have any idea as to the rate of failure? what percent? Was there evidence of abuse or misuse, or just running the car hard and it failed?
