I do not use the rail covers the Corvette has because that traps heat under the cover which in turn adds heat to the fuel rail, injectors and the coils.
Without covers then at least some air movement helps pull some heats off those parts.
That is not good and causes more issues when engine is turned off the heat increases which cooks the fuel in the injectors and helps leave deposits so I'd rather have the noise.
