C1214
DTC C1214
Circuit Description
The system relay is energized when the ignition is ON. The system relay supplies voltage to the solenoid valves and the pump motor. This voltage is referred to as the system voltage.
The electronic brake control module (EBCM) controls each solenoid valve by grounding the solenoid.
The EBCM controls the pump motor by grounding the control circuit. The pump serves 2 purposes:
  • Transfers brake fluid from the brake calipers to the master cylinder reservoir during pressure decrease events.
  • Transfers brake fluid from the master cylinder reservoir to the brake calipers during pressure increase events.
  • The ignition voltage is greater than 10.5 volts.
  • The system relay is commanded ON.
The system voltage is less than 8 volts for 0.23 seconds.
If equipped, the following actions occur:
The EBCM disables the ABS/TCS/VSES for the duration of the ignition
cycle.
The DRP does not function optimally.
The ABS indicator turns ON.
The Traction Control and Active Handling indicator turns ON.
The DIC displays the following messages:
Service ABS
Service Traction System
Service Active Handling
Conditions for Clearing the DTC
  • The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
  • The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
The system relay is integral to the EBCM. The relay is not serviceable.
Test Description
The number below refers to the step number on the diagnostic table.
  1. Determines whether the DTC is current.
Step
Action
Values
Yes
No
Schematic Reference:
ABS Schematics
Connector End View Reference:
ABS Connector End Views
1
Did you perform the ABS Diagnostic System Check?
Go to
Step 2
Go to
Diagnostic System Check - ABS
2
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. Use the scan tool in order to clear the DTCs.
  4. With the scan tool, perform the Automated Test.
Does the DTC reset as a current DTC?
Go to
Step 3
Go to
Testing for Intermittent and Poor Connections
in Wiring Systems
3
  1. Disconnect the pump motor harness pigtail connector of the BPMV.
  2. Measure the resistance between each pump motor control circuit and the
    housing of the BPMV at the pump motor harness pigtail connector of the BPMV.
Does the DMM display the specified value?
OL
Go to
Step 5
Go to
Step 4
4
Replace the EBCM and the BPMV. Refer to
Electronic Brake Control Module (EBCM) Replacement
and
Brake Pressure Modulator Valve (BPMV) Replacement
Did you complete the repair?
Go to
Step 6
5
Replace the EBCM. Refer to
Go to
Step 6
6
  1. Use the scan tool in order to clear the DTCs.
  2. With the scan tool, perform the Automated Test.
Does the DTC reset?
Go to
Step 2
System OK
