Fastener Tightening Specifications
Application
Specification
Metric
English
Bearing Housing Assembly-to-Coupling Bolts - Automatic Transmission
70 N·m
52 lb ft
Bearing Housing Assembly-to-Coupling Bolts - Manual Transmission
90 N·m
66 lb ft
Clutch Actuator Cylinder Mounting Bolts - Manual Transmission
12 N·m
106 lb in
Coupling-to-Propeller Shaft Bolts - Automatic Transmission
90 N·m
66 lb ft
Coupling-to-Propeller Shaft Bolts - Manual Transmission
90 N·m
66 lb ft
Driveline Tunnel Closeout Panel Bolts
10 N·m
89 lb in
EBTCM LH Mounting Bracket Mounting Bolts
50 N·m
37 lb ft
Flexplate Spindle Nut - Automatic Transmission
90 N·m
66 lb ft
Flexplate-to-Flexplate Spindle Bolts - Automatic Transmission
50 N·m
37 lb ft
Input Shaft Bearing Positioning Bolts
35 N·m
26 lb ft
Input Shaft-to-Coupling Bolts - Automatic Transmission
70 N·m
52 lb ft
Input Shaft-to-Coupling Bolts - Manual Transmission
90 N·m
66 lb ft
Negative Battery Cable Bolt
15 N·m
11 lb ft
Propeller Shaft Balance Specification @ 3,500 RPM
6.0 G-CM
Maximum
Propeller Shaft Hub Clamp Bolt - Automatic Transmission
125 N·m
93 lb ft
Rear Exhaust Hanger Mounting Bolts
50 N·m
37 lb ft
Rear Suspension Crossmember Mounting Nuts
110 N·m
81 lb ft
Shift Control Closeout Boot Retaining Nuts - Manual Transmission
12 N·m
106 lb in
Shift Control Mounting Bolts
30 N·m
22 lb ft
Transaxle Mount Bracket-to-Differential Bolts
50 N·m
37 lb ft
Transaxle Mount-to-Rear Suspension Crossmember Nuts
50 N·m
37 lb ft
Transmission Oil Cooler Rear Pipe Front Fittings-to-Junction Fittings at Engine Flywheel Housing
27 N·m
20 lb ft
Transmission Oil Cooler Rear Pipe Rear Fittings-to-Transmission Fittings
40 N·m
30 lb ft
Transmission Oil Cooler Rear Pipe Retaining Clamp Bolts
12 N·m
106 lb in
Transmission Shift Control Cable Bracket Retaining Nuts
20 N·m
15 lb ft
Transmission Shift Rod Clamp Bolt
30 N·m
22 lb ft
Transmission-to-Driveline Support Assembly Bolts/Studs
50 N·m
37 lb ft
Transmission Wiring Harness-to-LH Transmission Case Retaining Bolt
2.5 N·m
22 lb in
