Application
| Specification
Metric
| English
Bearing Housing Assembly-to-Coupling Bolts - Automatic Transmission
| 70 N·m
| 52 lb ft
Bearing Housing Assembly-to-Coupling Bolts - Manual Transmission
| 90 N·m
| 66 lb ft
Clutch Actuator Cylinder Mounting Bolts - Manual Transmission
| 12 N·m
| 106 lb in
Coupling-to-Propeller Shaft Bolts - Automatic Transmission
| 90 N·m
| 66 lb ft
Coupling-to-Propeller Shaft Bolts - Manual Transmission
| 90 N·m
| 66 lb ft
Driveline Tunnel Closeout Panel Bolts
| 10 N·m
| 89 lb in
EBTCM LH Mounting Bracket Mounting Bolts
| 50 N·m
| 37 lb ft
Flexplate Spindle Nut - Automatic Transmission
| 90 N·m
| 66 lb ft
Flexplate-to-Flexplate Spindle Bolts - Automatic Transmission
| 50 N·m
| 37 lb ft
Input Shaft Bearing Positioning Bolts
| 35 N·m
| 26 lb ft
Input Shaft-to-Coupling Bolts - Automatic Transmission
| 70 N·m
| 52 lb ft
Input Shaft-to-Coupling Bolts - Manual Transmission
| 90 N·m
| 66 lb ft
Negative Battery Cable Bolt
| 15 N·m
| 11 lb ft
Propeller Shaft Balance Specification @ 3,500 RPM
| 6.0 G-CM
Maximum
Propeller Shaft Hub Clamp Bolt - Automatic Transmission
| 125 N·m
| 93 lb ft
Rear Exhaust Hanger Mounting Bolts
| 50 N·m
| 37 lb ft
Rear Suspension Crossmember Mounting Nuts
| 110 N·m
| 81 lb ft
Shift Control Closeout Boot Retaining Nuts - Manual Transmission
| 12 N·m
| 106 lb in
Shift Control Mounting Bolts
| 30 N·m
| 22 lb ft
Transaxle Mount Bracket-to-Differential Bolts
| 50 N·m
| 37 lb ft
Transaxle Mount-to-Rear Suspension Crossmember Nuts
| 50 N·m
| 37 lb ft
Transmission Oil Cooler Rear Pipe Front Fittings-to-Junction Fittings at Engine Flywheel Housing
| 27 N·m
| 20 lb ft
Transmission Oil Cooler Rear Pipe Rear Fittings-to-Transmission Fittings
| 40 N·m
| 30 lb ft
Transmission Oil Cooler Rear Pipe Retaining Clamp Bolts
| 12 N·m
| 106 lb in
Transmission Shift Control Cable Bracket Retaining Nuts
| 20 N·m
| 15 lb ft
Transmission Shift Rod Clamp Bolt
| 30 N·m
| 22 lb ft
Transmission-to-Driveline Support Assembly Bolts/Studs
| 50 N·m
| 37 lb ft
Transmission Wiring Harness-to-LH Transmission Case Retaining Bolt
| 2.5 N·m
| 22 lb in
