FTC to Wack GM Over OnStar
by teamzr1. 01/15/26 03:51 PM
by teamzr1. 01/15/26 03:19 PM
Topics3,725
Posts6,922
#1954 - 08/26/07 12:07 PM Accel Super Ram for Trade or Sale
Pals92C4
I have a polished Accel Super Ram Intake Manifold, Plenum Runners and Gasket set I cannot use. I removed it from my '92 LT-1 and after installing new AFR 195 Comp Heads it won't fit as they heads are ported to the LT-4.
Parts I am searching for:
---'96 LT-4 Intake Manifold
--- 2 ea 5-spoke Silver Painted ZR-1 11" Rear Wheels.
Pictures available
smile
#1955 - 08/26/07 12:17 PM Re: Accel Super Ram for Trade or Sale [Re: ]
You can attach images directly when you compose or edit using the file manager function.
Just keep the images below 375K per image in size
#1959 - 08/28/07 06:10 PM Re: Accel Super Ram for Trade or Sale [Re: ]
Pals92C4
Let's see if this works. Here a picture.
#1977 - 09/07/07 12:33 PM Re: Accel Super Ram for Trade or Sale [Re: ]
dvdmrgn68
How much for the set up? You said this was on a LT1 engine. The intake is for a L98 engine. It has the hole for the distributor and thermostat. The Lt1 engine had niether of these on the intake. I have a 1991 corvette with the L98 engine. If this is the right intake base I need I would be interested in it. I need the base part number to verify. There are different intake bases out there. At least three I know of. Summit racing use to sell the gm lt4 intake. Edelbrock also makes an intake for the lt1 and lt4. Summit caries both of them as well. Thanks Dave.
#1992 - 09/12/07 05:03 PM Re: Accel Super Ram for Trade or Sale [Re: ]
Pals92C4
Thanks for the inquiry. I assume it would fit. The Lingenfelter folks would know for sure. The bad news is that I should have sold it on ebay, but instead traded it for that Edelbrock LT-4 Intake you mentioned. If I run accross one I'll shoot you a message.
Cheers.
1 registered members (teamzr1), 14 guests, and 7 spiders.
by teamzr1. 01/12/26 12:36 PM
