Document ID# 2006867
Subject: Clunk Noise When Shifting More Noticeable At Low Speeds - keywords clutch manual throttle transmission #PIP3896 - (08/28/2007)
Models: 2004-2007 Cadillac CTS-V
1997-2007 Chevrolet Corvette Equipped with a Tremec 6-speed Manual Transmission
Condition/Concern:
While driving in a steady slow speed parade type situation a clunk-clunk noise from the driveline may be heard when depressing and releasing the clutch pedal, between shifts or quickly depressing and releasing the throttle.
Recommendation/Instructions:
The noise is a normal torque reversal in the driveline and a combination of axle backlash, front and rear drive shaft rubber isolation flanges, drive shaft center support, and a dual mass flywheel all working together. This is a normal characteristic and not a condition of operation concern. No repairs should be attempted.
Also reference the latest version of TSB 03-07-29-004 for further manual transmission operating characteristics.
