by teamzr1. 07/09/25 04:07 PM
by teamzr1. 07/09/25 03:52 PM
by teamzr1. 07/08/25 10:07 AM
Topics3,618
Posts6,718
#1910 - 08/07/07 08:49 AM Testing web camera while using EASE ****
Brett Hunter
Just having a little fun testing out using a web camera while scanning.
#1912 - 08/07/07 09:24 PM Re: Testing web camera while using EASE [Re: ]
Brett some reading this might not know to click on your image would take them to your video and requires Flash version 8 to play it
That road looks like a good place to do BBG runs :-)
#1923 - 08/09/07 07:38 PM Re: Testing web camera while using EASE [Re: teamzr1]
Brett Hunter
Yep, just click on the picture and it will take you to the video.
I have another that I haven't edited for time that is taken from the driver's view showing the HUD. One thing that surprised me is that the HUD shows the tires breaking loose during the 3-4 shift but the EASE recording doesn't show an increase in speed when shifting. You can watch the HUD in the video and when I shift at roughly 108 mph the HUD goes up to around 118 and then once the tires stop spinning it goes back down to around 111 mph.
You're right about the BBG run. It's getting about that time again.
#1926 - 08/11/07 07:02 PM Re: Testing web camera while using EASE [Re: ]
Brett which Ease interface do you have ?
I assume a early GMLAN one that does not do Warp ?
#1930 - 08/11/07 09:01 PM Re: Testing web camera while using EASE [Re: teamzr1]
Brett Hunter
Correct, I have the BPC-INT from the beta version of 3.5 that we tested with and I use a USB to RS 232 adapter.
Is it still just the wireless version that will do bidirectional?
#1931 - 08/12/07 10:20 AM Re: Testing web camera while using EASE [Re: ]
The Wireless interface does the highest bandwidth since it does IEEE 802.11 LAN so it does full Warp and all bi-directional, its not cheap at around $500 but also does full GMLAN
The FVI-USB-CAN interface also does Warp but not all bi-directional but is half the cost at $270.
#2023 - 10/13/07 08:27 AM Re: Testing web camera while using EASE [Re: teamzr1]
Brett Hunter
Here is another from today. I didn't have the mic on so there is no sound. As you can see from watching the speedo traction is a major problem right now.
#2024 - 10/13/07 11:02 AM Re: Testing web camera while using EASE [Re: ]
I can tell you had Warp set at 20 mSec so collected 40 frame second. Also see the water/methanol was on but I would bring the Full setting on at a bit lower value to allow pump to go full flow sooner.
I can see lots of torque/wheel spin issues with the increased performance. At one point losr -100 ft/lbs due to wheel spin going from 2nd to 3rd gear as seen below
Also here is a compare of how your 2005 did when stock ( on left) and then as of today's run with our custom tune and w/meth on
1 registered members (teamzr1), 11 guests, and 11 spiders.
by teamzr1. 07/09/25 03:19 PM
