Scan Tool Parameter
Data List*
Units
Typical Data Value
1-2 Shift Error
F2, F7
Seconds
Varies
1-2 Shift Time
F0, F2
Seconds
Varies
1-2 Sol.
F0, F2, F3, F4
On/Off
On
1-2 Sol. Open/Short to GND
F2
Yes/No
No
1-2 Sol. Short to Volts
F2
Yes/No
No
1-2 TAP Cell (4-16)
F7
kPa/Psi
Varies
2-3 Shift Error
F3, F8
Seconds
Varies
2-3 Shift Time
F0, F3
Seconds
Varies
2-3 Sol.
F0, F2, F3, F4
On/Off
On
2-3 Sol. Open/Short to GND
F3
Yes/No
No
2-3 Sol. Short to Volts
F3
Yes/No
No
2-3 TAP Cell (4-16)
F8
kPa/Psi
Varies
3-2 Downshift Sol.
F0, F5
On/Off
On
3-2 Sol. Open/Short to GND
F5
Yes/No
No
3-2 Sol. Short to Volts
F5
Yes/No
No
3-4 Shift Error
F4
Seconds
Varies
3-4 Shift Time
F0, F4
Seconds
Varies
A/C Clutch
F0
On/Off
Off
Adaptable Shift
F0, F7, F8
Yes/No
No
APP Average
F0, F1, F2, F3, F4, F5
Counts
Varies
APP Indicated Angle
Percent
0%
Cruise
F0
Enabled/Disabled
Disabled
Current Gear
F0, F1, F2, F3, F4, F5, F6
1,2,3,4
1
Current TAP Cell
F7, F8
4-16
Varies
Current TAP Memory
F7, F8
-16 to +16
Varies
ECT
F0, F1
°C (°F)
Varies
Engine Run Time
F0
Hr/Min/Sec
Varies
Engine Speed
RPM
Varies
Engine Torque
F0, F1
N·m (lb ft)
Varies
IAT
F0
°C (°F)
Varies
Ignition Voltage
F0
Volts
12-14 Volts
PC Sol. Actual Current
F0, F6
Amps
Varies (0.1-1.1 amps)
PC Solenoid Duty Cycle
F0, F6
Percent
Varies
PC Sol. Ref. Current
F0, F6
Amps
Speed Ratio
F0, F2, F3, F4, F5
Ratio
8.00:1
TCC Brake Switch
F0, F1
Open/Closed
Closed
TCC Duty Cycle
F0, F1
Percent
0%
TCC Duty Cycle Open/Short to GND
F0, F1
Yes/No
No
TCC Duty Cycle Short to Volts
F0, F1
Yes/No
No
TCC Enable
F0, F1
Yes/No
No
TCC Enable Open/Short to GND
F0, F1
Yes/No
No
TCC Enable Short to Volts
F0, F1
Yes/No
No
TCC Mode
F0, F1
0-5
0
TCC Slip Speed
F0, F1
RPM
+/-50 RPM from Engine Speed
TFP Switch A/B/C
F0
On/Off
Off/On/Off
TFT Sensor
F0, F1
Volts
Varies
TP Desired Angle
Percent
0-10%
TP Indicated Angle
Percent
0-10%
Trans. Fluid Temp.
F0, F1, F5, F6
°C (°F)
Varies
Transmission Hot Mode
F0, F1
On/Off
Off
Transmission OSS
RPM
0
Vehicle Speed
km/h (mph)
0
