Diagnostic Trouble Code Identification
Diagnostic Trouble Code IdentificationF-car 4L60-E 5.7L, VIN G)
Code
DTC
 Description
 DTC Type*
 Default Action
P0218
 Transmission Fluid Overtemperature
 D
 The PCM freezes shift adapts from being updated
P0502
 Vehicle Speed Sensor Circuit Low
 B
 The PCM commands first gear only
The PCM commands maximum line pressure
The PCM inhibits TCC engagement
P0503
 Vehicle Speed Sensor Circuit Intermittent
 B
 The PCM commands second gear only
The PCM inhibits 4th gear if the transmission is in hot mode
P0711
 TFT Sensor Circuit Range/Performance
 D
 The PCM uses a transmission fluid temperature default value based on engine coolant, engine run time and IAT at startup
P0712
 TFT Sensor Circuit Low
 D
P0713
 TFT Sensor Circuit High
 D
P0719
 Brake Switch Circuit Low
 D
 The PCM disregards the brake switch input for TCC scheduling
P0724
 Brake Switch Circuit High
 D
P0740
 TCC Enable Solenoid Circuit Electrical
 B
P0742
 TCC System Stuck On
 B
P0748
 PC Solenoid Circuit Electrical
 D
 The PC solenoid valve is OFF
P0751
 1-2 SS Valve Performance
 A
 The PCM commands D2 line pressure
The PCM inhibits 3-2 downshifts if the vehicle speed is greater than 48 km/h (30 mph)
P0753
 1-2 SS Circuit Electrical
 B
P0756
 2-3 SS Valve Performance
 A
 The PCM commands third gear only
P0758
 2-3 SS Circuit Electrical
 A
 The PCM commands 3rd gear only
P0785
 3-2 SS Circuit Electrical
 A
 The PCM commands a soft landing to 3rd gear
P1810
 TFP Switch Circuit Fault
 B
The PCM commands a D4 shift pattern
P1860
 TCC PWM Solenoid Circuit Electrical
 B
P1870
 Transmission Component Slipping
 B
*DTC Types:
A-Emission-related, turns the MIL ON after the first failure.
B-Emission-related, turns the MIL ON after two consecutive trips with failure.
C-Non-emission-related, turns the service lamp ON after the first failure.
D-Non-emission-related, no lamps.
