Sensor Calibration Procedure:
1.Mount all four wheels/tires on vehicle and torque to specifications. Place vehicle on the ground.
1.Turn ignition to ON position.
2.Press the DIC RESET button to clear any warning messages.
3.Press the DIC OPTIONS button until the display goes blank.
4.Press and hold the DIC RESET button for 3 seconds.
5.Press the DIC OPTIONS button again until the "TIRE TRAINING" message appears.
6.Press the DIC RESET button until the message, "LEARN L FRONT TIRE" appears.
7.Hold the magnet over the pressure sensor’s location on the LEFT FRONT wheel (this should be next to the valve stem if installed correctly).
8.When the horn beeps, programming is complete for that wheel.
9.Program the other 3 wheel sensors as directed by the message display. The sequence is as follows: Left Front, Right Front, Right Rear, Left Rear.
10.For more information, refer to the Corvette Service Manual, page 3-114: Low Tire Pressure Sensing—TPM Sensor Programming.
