by teamzr1. 10/29/25 04:34 PM
by teamzr1. 10/27/25 01:57 PM
by teamzr1. 10/18/25 06:42 PM
by teamzr1. 10/18/25 06:37 PM
by teamzr1. 10/15/25 04:09 PM
by teamzr1. 10/12/25 11:15 AM
by teamzr1. 10/07/25 02:11 PM
by teamzr1. 09/30/25 04:36 PM
WEC Six Hours of Fuji
by teamzr1. 09/29/25 06:24 PM
by teamzr1. 10/27/25 06:32 PM
2025 C8 Production Stats
by teamzr1. 10/22/25 06:29 PM
by teamzr1. 10/21/25 03:12 PM
by teamzr1. 10/09/25 04:29 PM
Test Crashing 2024 & 25 C8s
by teamzr1. 10/08/25 10:55 AM
by teamzr1. 10/27/25 02:47 PM
Topics3,678
Posts6,859
#1871 - 07/27/07 05:49 PM 2008 RPO
AAB Memory - Driver Convenience Package
AG2 Adjuster Pass ST - Power, Multi-Directional
AJ7 Restraint System - Seat, Inflatable, Driver & Pass, FRT & Side
AK5 Restraint System - Seat, Inflatable, Driver & Pass
AL0 Sensor Indicator - Inflatable Restraint, FRT Pass/Child Presence Detector
AQ9 Seat - FRT BKT, Luxury
AR9 Seat - FRT BKT, Deluxe
AU5 Lock Control, Entry - Remote Entry, Low Power
AU8 Lock Control, Entry - Remote Entry, Specific Frequency
AX4 Restraint Conversion - Seat, Man, European
BAG Parts Pkg - Export
BGR Plant Code - Bowling Green, KY, USA
BS1 Insulation - Acoustical Pkg
BV7 Bumper Provisions - FRT & RR, Canadian Requirements
B4H Modification - Noise Control, Export
B4P Modification - Noise Control, Transmission Control Module
CC3 Roof - Hatch, Removable Panels, Plastic
CE4 Washer - Headlamp, High Pressure
CF7 Roof - Sun, Removable, Non-Transparent
CJ2 HVAC System - Air Conditioner FRT, Auto Temp Cont, AUX Temp Cont
CM7 Roof - Convertible, Folding, Power
C2L Roof - Package, Dual Removable
DD0 Mirror O/S - LH & RH, Remote Control, Electric, Heated, LT Sensitive
DD8 Mirror I/S R/V - LT Sensitive
DL8 Mirror O/S - LH & RH, Remote Control, Electric, Heated
D42 Shade - RR Compt
EXP Export
FE1 Suspension System - Soft Ride
FE2 Suspension System - Ride, Handling
FE3 Suspension System - Sport
FE4 Suspension System - Special Ride & Handling
FE9 Certification - Emission, Federal
F55 Chassis - Continuously Variable Real Time Damping Magnetorheological
GB9 Label, Limited - Consignment - Delete
GM8 Axle Rear - 2.56 Ratio
GU2 Axle Rear - 2.73 Ratio
GU6 Axle Rear - 3.42 Ratio
IL3 Trim - Interior Design (L3)
IL5 Trim - Interior Design (L5)
IL6 Trim - Interior Design (L6)
IP3 Trim - Interior Design (P3)
JAF Brake Provisions - Europe
JJA PT Dress Subassembly - Installed (Modular Optimization Method Only)
JJB PT Dress Subassembly - Not Installed (Modular Optimization Method Only)
JL5 Control - Manual Trans, First To Fourth Gear Skip Shift
JL9 Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL
J55 Brake System - Heavy Duty
J56 Brake System - PWR, FRT & RR Disc, Antilock, FRT & RR WHL, Heavy Duty
KNR Cooling System - Axle
KNP Cooling System - Trans, HD
KPS Cooler - Oil, Engine
KA1 Heater - Seat, FRT
KJ5 Protector - Shipping, Shock Absorber
K05 Heater Eng - Block
K63 Generator - 110 AMP
LS3 Engine - Gas, 8 Cyl, 6.2L, SFI, Alum, HO, GM
LS7 Engine - Gas, 8 Cyl, 7.0L, SFI, Alum, GM
MAE Marketing Area - Europe
MYC Transmission - Auto 6 Spd, HMD, 6L80
MM6 Transmission - Man 6 Spd, Tremec, 85mm, 2.66 1st, 0.50 6th, O/D
MN6 Merchandised Trans - Man 6 Spd Provisions
MX0 Merchandised Trans - Auto Provisions, O/D
MZ6 Transmission - Man 6 Spd, Tremec, 85mm, 2.97 1st, 0.57 6th, O/D
NA3 Emission System - Japan
NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs GVW (use 2003 mdl yr)
NF9 Emission System - General, OBD MIL Suppression
NK4 Steering Wheel - Sport Leather
NPP Exhaust System - Performance
NP7 Steering Column - EEC Approved
NT4 Emission System - EEC 05
NT7 Emission System - Federal, Tier 2
NU1 Emission System - California, LEV2
NU5 Emission System - California, Lev 2
N33 Steering Column - Tilt Type
N37 Steering Column - Tilt, Telescoping
QL9 Wheel - 18 X 9.5 FRT & 19 X 12 RR, Polished
QG6 Wheel - 18 X 8.5 FRT & 19 X 10 RR, Aluminum, Styled
QG7 Wheel - 18 X 8.5 FRT & 19 X 10 RR, Polished
QX1 Wheel - 18 X 18.5 FRT & 19 X 10 RR, Aluminum, Painted, Flangless
Q10 Wheel - 18 X 9.5 FRT & 19 X 12 RR
Q44 Wheel - 18 X 9.5 FRT & 19 X 12 RR, Aluminum, Painted
Q76 Wheel - 18 X 9.5 FRT & 19 X 12 RR, Chrome
R8C Control - Sales Item No. 53
SSG Graphic - Switch Function Symbol
T62 Lamp System - Daytime Running - Delete
T79 Lamp - Fog, RR
T84 Headlamps - RH Rule of The Road, E Mark
T85 Headlamps - LH Rule of The Road, E Mark
T90 Lamp - Signaling & Marker, Export
T93 Lamp - Tail & Stop, Special
UA2 Theft Deterrent Sys - Export Specific
UD4 Alarm - Vehicle Speed, 120 k/h
UE1 Communication System - Vehicle, G.P.S. 1
UH3 Indicator - Low Tire Press, VAR 2
UG1 Opener - Garage Door, Universal
UJ6 Indicator - Low Tire Press
UJ9 Indicator - Low Tire Press, VAR 2
UK1 Frequencies - Japanese
UK3 Control - Steering Wheel, Accessory
ULS Lock Control - Steering Column
UL2 Frequencies - European
UPF Wireless Interface - Short Range, Voice Rec
US3 Antenna - Diversity
US8 Radio - AM/FM Stereo, SEEK/SCAN, CD, Auto Tone, Clock, ETR, MP3, RDS
US9 Radio - AM/FM Stereo, SEEK/SCAN, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UV6 Display - Head Up
U2K Digital Audio System - S - Band
U3U Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3
U3Z Radio - AM/FM Stereo, SEEK/SCAN, DVD, CD, Clock, ETR, Navigation, Voice Rec, MP3, VICS
U19 Speedometer - Inst, Kilo & Miles, Kilo Odometer
U52 Cluster - Inst, Electronic
U65 Speaker System - 7, Custom
U66 Speaker System - 7, Custom
VBX Language Label - Arabic
VDD Vehicle Information - DVD, Customer Orientation
VA5 Language Label - English
VB1 Label - Shipping, Japan
VC4 Label - Price/Fuel Econ, Puerto Rico & Virgin Islands
VC5 Label - Shipping, Except US, US Possessions, or Japan
VH5 Plate - Vehicle Identification
VH9 Envelope - Owner Info Man
VK3 License Plate Front - FRT Mounting PKG
VL4 License Plate Front - FRT Mounting PKG, EEC
VL6 License Plate Front - FRT Mounting PKG, Japanese
VT7 Owners Manual - English Language
VZ3 Label - Mercury Disposal Notification
V73 Vehicle Statement - USA/Canada
V76 Hook - Tow
V78 Vehicle Statement - Delete
V87 Vehicle Statement - Gulf States Organization
W11 Navigation Disc Data - Nav Data 1
W12 Navigation Disc Data - Nav Data 2
XBH Tire Front - P245/40ZR18 BW HW4 (EMT)
XFA Tire Front - P275/35ZR1 8 BW TL HW4 EMT
XND Tire Front - P245/40ZR18 BW HW4 (EMT) High-Performance
YFJ Tire Rear - P325/30ZR19 BW TL HW4 EMT
YF5 Certification - Emission, California
YPI Tire Rear - P285/35ZR19 BW HW4 (EMT)
YTK Tire Rear - P285/35ZR19 BW HW4 (EMT) High-Performance
ZV6 Modification - RR Shock Damping, European Requirement
Z5X Mirror Provision - Arabic Language
Z49 Export - Canadian Modify Mandator Y base Equip
Z51 Performance Package - Handling
1SA Package - Option 01
1SB Package - Option 02
1SE Package - LZ Option 05
1LT Package - LT Option 1
1LZ Package - LZ Option 1
2LT Package - LT Option 2
2LZ Package - LZ Option 2
3LT Package - LT Option 3
3LZ Package - LZ Option 3
4LT Package - LT Option 4
#2034 - 10/20/07 05:44 AM Re: 2008 RPO [Re: teamzr1]
mj2010 Offline
Wazer
mj2010  Offline
Wazer
Rednitzhembach, Germany
Two questions:
1) Is there a totally different navigation system for export models or is it simply a change of DVDs?
2) Is the stereo frequency step adjustable or is there a different model for export Corvettes destined for Europe?
TIA.
s/mj
1 registered members (teamzr1), 13 guests, and 10 spiders.
C4 Production Numbers & RPOs
by teamzr1. 10/27/25 03:00 PM
C3 Production Numbers & RPOs
by teamzr1. 10/27/25 02:53 PM
