Adapter Plate Plug
27 N·m
20 lb ft
Adapter Plate to Transmission Case Bolts
48 N·m
36 lb ft
Backup Lamp Switch
27 N·m
20 lb ft
Computer Aided Gear Select Solenoid
40 N·m
30 lb ft
Cover Plate Bolts
20 N·m
15 lb ft
Extension Housing Plug
27 N·m
20 lb ft
Extension Housing to Transmission Case Bolts
48 N·m
36 lb ft
Neutral Return Cam Spring Retaining Bolt
25 N·m
18 lb ft
Reverse Idler Shaft Bracket Bolts
25 N·m
18 lb ft
Reverse Lockout Assembly Bolt
18 N·m
13 lb ft
Reverse Lockout Solenoid
40 N·m
30 lb ft
Shift Detent Assembly
40 N·m
30 lb ft
Shift Guide Plate Bolts
22 N·m
16 lb ft
Shift Lever Guide Bolts
27 N·m
20 lb ft
Transmission Case Drain Plug
18 N·m
13 lb ft
Transmission Case Fill Plug
18 N·m
13 lb ft
