Engine Coolant Heater
40 N·m
30 lb ft
Engine Coolant Heater Cord Clip Bolt
32 N·m
24 lb ft
Fan Assembly Screw
10 N·m
89 lb in
Fan Motor Screw
6 N·m
53 lb in
Fan Nut
5.5 N·m
49 lb in
Front Stabilizer Shaft Insulator Clamp Bolt
58 N·m
43 lb ft
Negative Battery Cable Bolt
15 N·m
11 lb ft
Radiator Surge Tank Nut
10 N·m
89 lb in
Radiator Upper Support Bolt
8 N·m
71 lb in
Thermostat Housing Bolt
10 N·m
89 lb in
Transmission Oil Cooler Front Upper and Lower Pipe Fittings to Radiator, (Flared Fitting Design)
40 N·m
30 lb ft
Transmission Oil Cooler Front Upper and Lower Pipe Fittings to Radiator, (Sealed Washer Design)
16 N·m
12 lb ft
Transmission Oil Cooler Line Fittings to Junction at Engine Flywheel Housing (front lines to rear lines)
27 N·m
20 lb ft
Vapor Vent Pipe Screw
12 N·m
106 lb in
Water Pump Bolt (First Pass)
15 N·m
11 lb ft
Water Pump Bolt (Final Pass)
30 N·m
22 lb ft
Water Pump Pulley Bolt (First Pass)
10 N·m
89 lb in
Water Pump Pulley Bolt (Final Pass)
25 N·m
18 lb ft
