Topics3,713
Posts6,902
#2093 - 11/10/07 05:19 PM LG Motorsports
This 2007 with A6 trannie really must have come from hell
Rich from Kimble Motorsports out of Boise Id had a customer with a early 2007 with A6 that had already had headers and POS vararam installed come to him to install mods he already bought from that LG motorsports. They choose the makeup as to CAM, heads, LS7 injectors, L92 intake manifold and throttlebody.
Rich should have seen the writing on the way when he looked at the so called LG CAM where LGM had ground off the true vendor's part number off the CAM. Worse is LGM when Rich called him refused to say what the CAM specs are. puke
As we all know auto trannie and worse A6 is not going to allow radical CAM grinds and low vaccum at low engine loads.
Rich asked LGM if the existing CAM gear would be fine to use with the new CAM and was told YES.
Rich installs the parts, goes to fire up the engine and engine is puking so I asked for a Ease recording which when I replay see the CAM sensor is complaining like a bitch in heat.
Rich calls LGM and they say "Oh, that CAM requires a LS7 CAM gear, this means Rich has to take the front end off again to change gear. Rich asked since it was a LG screwup if they intended to pay his labor which is several hours and they tell him it is his problem and NO.
Now he goes to flash the tune I sent him, does that and pushes the button and engine will not turn over.
Assuming the PCM got wacked he buys another PCM which is blank so he has to go to a dealer and get it flashed for that car.
Then he flashes a new tune I had to do for that PCM. Again goes to start car and it is fucking DEAD !
Now he contacts carputing of LS2edit and then has to overnight both PCMs to them. They say both had the tunes in it.
Add more blood letting, ends up owner did not tell Rich then some buddy had a POS Prediator canned tuner and flashed that car that was for another 2007 and car had weird error codes and dealer told him something in dash was screwed up but owner did not get that fixed.
PCMs get back from carputing, I have Rich pull fuses for Onstar and XM radio. Flashing of tune works and car starts but takes several tried befor it will idle.
Also car when driving is not very good as something is going wrong so after fucking around for 2 weeks I tell Rich to bring the car here to Oregon from Boise Id.
He drives some hours to get here and this Sat AM he shows up and time for the show.
1. The CAM grind is NOT suited for a A6 trannie nor a stock torque converter.
Causing false misfires even when trying to start engine.
2. You know it is screwed when at idle the MAP is at 60-65 KPA.
3. Had to totally turn off misfire as even the highest delay count was not enough and that was even after a CKS relearn was done.
4. 2007 GM took out the VE tables so making this work is even tougher.
5. not even knowing what head work is done other then they were milled for higher engine compression I had no way of knowing if valves were larger.
Spent 7 hours today and did 8 tweaks of tune to fix the hard startup problem, a stumble at low speeds and how A6 acted so also had to tune the TCM for A6
End result is engine fires right up, engine is real strong and A6 even shifts good ( I held my nose and even test drove the car using that kiddle paddle shifter crap :-)
Not good is the torque converter is not the right one for this CAM grind.
For 3 plus years now we have seen many vettes with LG mods, either ill designed headers, telling customers to yank smog parts out and way overpriced costs along with lousy PCM tuning so they belong in this forum section.
Here is results after all the clean up :
#2095 - 11/11/07 09:49 AM Re: LG Motorsports [Re: teamzr1]
Here is scanner data of 3 pulls where I let A6 auto shift,
using the paddle shifter and holding RPMs per shift and fast shifts using paddle shifter.
Look at the torque values as when and when not torque was lost either due to shift times or wheel spin
#2096 - 11/11/07 10:06 AM Re: LG Motorsports [Re: teamzr1]
Here is scanner raw data for one of the pulls
Use the sliders to move through the data
[code]E-Time RPM KR TPS CELL Timing LTFTB1 IAT HO2B1S1 PWB1 LTFTB2 MAF MPH MAP PWB2 ECT HO2B2S1 DELTQ MISFIRE Load MAfreq MAFgrms Learn STFTB1 STFTB2 Vac Calcload INJDC grmcyc MapKpa HPFLYW Distance CFM Injflow VacKpa VE Kelvin
769 22 19 25 -8.6 59 0.700 3 -7 2 20 3.1 196 0.820 65 44 3631 14 1 -2 10 4 2.0 0.265 66 10 67.29 0.59 35 28 339
0.050 769 23 19 16 -8.6 59 0.700 3 -7 2 1 19 3.1 196 0.820 65 44 3631 14 1 -2 11 4 2.0 0.269 65 10 0 67.29 0.59 36 29 339
0.100 812 23 19 16 -8.6 59 0.700 3 -7 2 1 19 3.1 196 0.820 65 44 3631 14 1 -2 11 4 2.1 0.255 65 10 0 71.03 0.62 36 27 339
0.150 812 23 19 16 -8.6 59 0.380 3 -7 2 1 19 3.1 196 0.810 65 44 3631 14 1 -2 11 4 2.1 0.255 65 10 0 71.03 0.62 36 27 339
0.200 812 23 19 16 -8.6 59 0.380 3 -7 2 1 19 3.0 196 0.810 65 44 3664 14 1 -2 11 4 2.0 0.255 65 10 0 71.03 0.62 36 27 339
0.250 812 23 19 16 -8.6 59 0.380 3 -7 2 1 19 3.0 196 0.810 60 44 3664 14 1 -2 11 4 2.0 0.255 65 9 0 71.03 0.57 36 27 339
0.300 812 24 19 18 -8.6 59 0.380 3 -7 2 1 20 3.0 196 0.810 60 44 3664 15 1 -2 10 4 2.0 0.272 67 9 0 71.03 0.57 34 29 339
0.350 772 24 19 18 -8.6 59 0.380 3 -7 2 1 20 3.0 196 0.810 60 44 3664 15 1 -2 10 4 1.9 0.286 67 9 1 67.55 0.54 34 31 339
0.400 772 24 19 18 -8.6 59 0.710 3 -7 2 1 20 3.0 196 0.830 60 47 3664 15 1 -2 10 4 1.9 0.286 67 9 1 67.55 0.54 34 31 339
0.450 772 24 19 18 -8.6 59 0.710 3 -7 2 1 20 3.2 196 0.830 60 47 3733 15 1 -2 10 4 2.0 0.286 67 9 1 67.55 0.54 34 31 339
0.500 772 24 19 18 -8.6 59 0.710 3 -7 2 1 20 3.2 196 0.830 64 47 3733 15 1 -2 10 4 2.0 0.286 67 9 1 67.55 0.58 34 31 339
0.550 772 24 19 19 -8.6 59 0.710 3 -7 2 2 20 3.2 196 0.830 64 47 3733 16 1 -2 10 4 2.0 0.308 68 9 1 67.55 0.58 33 33 339
0.600 800 24 19 19 -8.6 59 0.710 3 -7 2 2 20 3.2 196 0.830 64 47 3733 16 1 3 -5 10 4 2.1 0.297 68 10 1 69.96 0.60 33 32 339
0.650 800 24 19 19 -8.6 59 0.350 3 -7 2 2 20 3.2 196 0.790 64 51 3733 16 1 3 -5 10 4 2.1 0.297 68 10 1 69.96 0.60 33 32 339
0.700 800 24 19 19 -8.6 59 0.350 4 -7 2 2 20 3.3 196 0.790 64 51 3842 16 1 3 -5 10 4 2.2 0.297 68 10 1 69.96 0.60 33 32 339
0.750 800 24 19 19 -8.6 59 0.350 4 -7 2 2 20 3.3 196 0.790 74 51 3842 16 1 3 -5 10 4 2.2 0.297 68 11 1 69.96 0.69 33 32 339
0.800 800 26 19 20 -8.6 59 0.350 4 -7 2 2 20 3.3 196 0.790 74 51 3842 17 1 3 -5 10 5 2.2 0.322 68 11 2 69.96 0.69 33 34 339
0.850 846 26 19 20 -8.6 59 0.350 4 -10.2 2 2 20 3.3 196 0.790 74 51 3842 17 1 3 1 10 5 2.3 0.304 68 12 2 74.05 0.73 33 33 339
0.900 846 26 20 -8.6 59 0.130 4 -10.2 2 2 20 3.3 196 0.270 74 53 3842 17 1 3 1 10 5 2.3 0.304 68 12 2 74.05 0.73 33 33 339
0.950 846 26 20 -8.6 59 0.130 4 -10.2 2 2 20 3.6 196 0.270 74 53 3968 17 1 3 1 10 5 2.5 0.304 68 12 2 74.05 0.73 33 33 339
1.000 846 26 20 -8.6 59 0.130 4 -10.2 2 2 20 3.6 196 0.270 87 53 3968 17 1 3 1 10 5 2.5 0.304 68 14 2 74.05 0.86 33 33 339
1.050 846 26 20 -8.6 59 0.130 4 -10.2 2 2 20 3.6 196 0.270 87 53 3968 17 1 3 1 10 5 2.5 0.304 68 14 2 74.05 0.86 33 33 339
1.100 846 27 22 -8.6 59 0.130 4 -10.2 3 2 20 3.6 196 0.270 87 53 3968 19 1 3 1 10 5 2.5 0.344 68 14 2 74.05 0.86 33 37 339
1.150 946 27 22 -8.6 59 0.130 4 -10.2 3 2 20 3.6 196 0.270 87 53 3968 19 1 4 1 10 5 2.8 0.308 68 16 3 82.73 0.96 33 33 339
1.200 946 27 22 -8.6 59 0.740 4 -10.2 3 2 20 3.6 196 0.100 87 53 3968 19 1 4 1 10 5 2.8 0.308 68 16 3 82.73 0.96 33 33 339
1.250 946 27 22 -8.6 59 0.740 4 -10.2 3 2 20 3.6 196 0.100 87 53 4142 19 1 4 1 10 5 2.8 0.308 68 16 3 82.73 0.96 33 33 339
1.300 946 27 22 -8.6 59 0.740 4 -10.2 3 2 20 3.6 196 0.100 96 53 4142 19 1 4 1 10 5 2.8 0.308 68 17 3 82.73 1.05 33 33 339
1.350 946 27 25 -8.6 59 0.740 4 -10.2 3 2 20 3.6 196 0.100 96 53 4142 20 1 4 1 10 6 2.8 0.320 67 17 3 82.73 1.05 34 34 339
1.400 1031 27 25 -8.6 59 0.740 4 -10.2 3 2 20 3.6 196 0.100 96 53 4142 20 1 -2 2 10 6 3.1 0.294 67 19 3 90.17 1.15 34 31 339
1.450 1031 27 25 -8.6 59 0.430 4 -10.2 3 2 20 3.6 196 0.050 96 49 4142 20 1 -2 2 10 6 3.1 0.294 67 19 4 90.17 1.15 34 31 339
1.500 1031 27 25 -8.6 59 0.430 4 -10.2 3 2 20 3.6 196 0.050 96 49 4186 20 1 -2 2 10 6 3.1 0.294 67 19 4 90.17 1.15 34 31 339
1.550 1031 27 25 -8.6 59 0.430 4 -10.2 3 2 20 3.6 196 0.050 104 49 4186 20 1 -2 2 10 6 3.1 0.294 67 20 4 90.17 1.25 34 31 339
1.600 1031 27 28 -8.6 59 0.430 4 -10.2 3 4 19 3.6 196 0.050 104 49 4186 21 1 -2 2 11 6 3.1 0.303 65 20 4 90.17 1.25 36 32 339
1.650 1091 27 28 -8.6 59 0.430 4 -10.2 3 4 19 3.6 196 0.050 104 49 4186 21 1 -2 6 11 6 3.3 0.286 65 22 4 95.46 1.33 36 31 339
1.700 1091 28 32 -8.6 59 0.430 4 -10.2 3 6 19 3.6 196 0.050 104 49 4186 22 1 -2 6 11 6 3.3 0.300 63 22 5 95.46 1.33 38 32 339
1.750 1106 28 32 -8.6 59 0.430 4 -10.2 3 6 19 3.6 196 0.050 104 49 4186 22 1 4 2 11 6 3.3 0.296 63 22 5 96.76 1.34 38 32 339
1.800 1106 28 32 -8.6 59 0.800 4 -10.2 3 6 19 3.6 196 0.690 104 49 4186 22 1 4 2 11 6 3.3 0.296 63 22 6 96.76 1.34 38 32 339
1.850 1106 28 32 -8.6 59 0.800 4 -10.2 3 6 19 3.6 196 0.690 104 49 4301 22 1 4 2 11 6 3.3 0.296 63 22 6 96.76 1.34 38 32 339
1.900 1106 28 32 -8.6 59 0.800 4 -10.2 3 6 19 3.6 196 0.690 108 49 4301 22 1 4 2 11 6 3.3 0.296 63 23 7 96.76 1.40 38 32 339
1.950 1106 28 32 -8.6 59 0.800 4 -10.2 3 6 19 3.6 196 0.690 108 49 4301 23 1 4 2 11 6 3.3 0.312 63 23 7 96.76 1.40 38 33 339
2.000 1148 28 32 -8.6 59 0.800 4 -10.2 3 6 19 3.6 196 0.690 108 49 4301 23 1 -2 2 11 6 3.4 0.301 63 24 7 100.45 1.45 38 32 339
2.050 1148 28 32 -8.6 59 0.870 4 -10.2 3 6 19 3.6 196 0.150 108 51 4301 23 1 -2 2 11 6 3.4 0.301 63 24 8 100.45 1.45 38 32 339
2.100 1148 28 32 -8.6 59 0.870 4 -10.2 3 6 19 3.7 196 0.150 108 51 4371 23 1 -2 2 11 6 3.5 0.301 63 24 8 100.45 1.45 38 32 339
2.150 1148 28 32 -8.6 59 0.870 4 -10.2 3 6 19 3.7 196 0.150 116 51 4371 23 1 -2 2 11 6 3.5 0.301 63 25 9 100.45 1.56 38 32 339
2.200 1148 28 33 -8.6 59 0.870 4 -10.2 3 7 19 3.7 196 0.150 116 51 4371 23 1 -2 2 11 6 3.5 0.298 63 25 9 100.45 1.56 38 32 339
2.250 1166 28 33 -8.6 59 0.870 4 -10.2 3 7 19 3.7 196 0.150 116 51 4371 23 1 -2 -2 11 6 3.5 0.294 63 26 10 102.05 1.58 38 31 339
2.300 1166 28 33 -8.6 59 0.830 4 -10.2 3 7 19 3.7 196 0.870 116 49 4371 23 1 -2 -2 11 6 3.5 0.294 63 26 10 102.05 1.58 38 31 339
2.350 1166 28 33 -8.6 59 0.830 3 -10.2 3 7 19 3.4 196 0.870 116 49 4366 23 1 -2 -2 11 6 3.3 0.294 63 26 11 102.05 1.58 38 31 339
2.400 1166 28 33 -8.6 59 0.830 3 -10.2 3 7 19 3.4 196 0.870 119 49 4366 23 1 -2 -2 11 6 3.3 0.294 63 26 11 102.05 1.62 38 31 339
2.450 1166 28 33 -8.6 59 0.830 3 -10.2 3 7 19 3.4 196 0.870 119 49 4366 23 1 -2 -2 11 6 3.3 0.296 63 26 12 102.05 1.62 38 32 339
2.500 1168 28 33 -8.6 59 0.830 3 -10.2 3 7 19 3.4 196 0.870 119 49 4366 23 1 -6 -2 11 6 3.3 0.296 63 26 12 102.18 1.62 38 32 339
2.550 1168 28 33 -8.6 59 0.780 3 -10.2 3 7 19 3.4 196 0.870 119 49 4366 23 1 -6 -2 11 6 3.3 0.296 63 26 13 102.18 1.62 38 32 339
2.600 1168 28 33 -8.6 59 0.780 3 -10.2 3 7 19 3.4 196 0.870 119 49 4385 23 1 -6 -2 11 6 3.3 0.296 63 26 13 102.18 1.62 38 32 339
2.650 1168 28 33 -8.6 59 0.780 3 -10.2 3 7 19 3.4 196 0.870 118 49 4385 23 1 -6 -2 11 6 3.3 0.296 63 26 14 102.18 1.60 38 32 339
2.700 1168 28 32 -8.6 59 0.780 3 -10.2 3 8 19 3.4 196 0.870 118 49 4385 23 1 -6 -2 11 6 3.3 0.296 63 26 15 102.18 1.60 38 32 339
2.750 1146 28 32 -8.6 59 0.780 3 -10.2 3 8 19 3.4 196 0.870 118 49 4385 23 1 2 2 11 6 3.2 0.302 63 26 15 100.23 1.57 38 32 339
2.800 1146 28 32 -8.6 59 0.090 3 -10.2 3 8 19 3.4 196 0.230 118 51 4385 23 1 2 2 11 6 3.2 0.302 63 26 16 100.23 1.57 38 32 339
2.850 1146 28 32 -8.6 59 0.090 4 -10.2 3 8 19 3.6 196 0.230 118 51 4405 23 1 2 2 11 6 3.5 0.302 63 26 16 100.23 1.57 38 32 339
2.900 1146 28 32 -8.6 59 0.090 4 -10.2 3 8 19 3.6 196 0.230 115 51 4405 23 1 2 2 11 6 3.5 0.302 63 25 17 100.23 1.54 38 32 339
2.950 1146 28 32 -8.6 59 0.090 4 -10.2 3 8 19 3.6 196 0.230 115 51 4405 23 1 2 2 11 6 3.5 0.302 63 25 17 100.23 1.54 38 32 339
3.000 1146 31 32 -8.6 59 0.090 4 -10.2 4 9 19 3.6 196 0.230 115 51 4405 27 1 2 2 11 8 3.5 0.357 65 25 18 100.23 1.54 36 38 339
3.050 1215 31 32 -8.6 59 0.090 4 -10.2 4 9 19 3.6 196 0.230 115 51 4405 27 1 2 2 11 8 3.7 0.337 65 27 19 106.31 1.64 36 36 339
3.100 1215 31 32 -8.6 59 0.050 4 -10.2 4 9 19 3.6 196 0.070 115 57 4405 27 1 2 2 11 8 3.7 0.337 65 27 19 106.31 1.64 36 36 339
3.150 1215 31 32 -8.6 59 0.050 4 -10.2 4 9 19 3.9 196 0.070 115 57 4648 27 1 2 2 11 8 3.9 0.337 65 27 20 106.31 1.64 36 36 339
3.200 1215 31 32 -8.6 59 0.050 4 -10.2 4 9 19 3.9 196 0.070 135 57 4648 27 1 2 2 11 8 3.9 0.337 65 31 21 106.31 1.92 36 36 339
3.250 1215 31 31 -8.6 59 0.050 4 -10.2 4 9 20 3.9 196 0.070 135 57 4648 28 1 2 2 10 8 3.9 0.351 67 31 21 106.31 1.92 34 38 339
3.300 1284 31 31 -8.6 59 0.050 4 -10.2 4 9 20 3.9 196 0.070 135 57 4648 28 1 -2 -2 10 8 4.2 0.332 67 33 22 112.38 2.03 34 36 339
3.350 1284 31 31 -8.6 59 0.860 4 -10.2 4 9 20 3.9 196 0.880 135 55 4648 28 1 -2 -2 10 8 4.2 0.332 67 33 23 112.38 2.03 34 36 339
3.400 1284 31 31 -8.6 59 0.860 4 -10.2 4 9 20 3.9 196 0.880 135 55 4716 28 1 -2 -2 10 8 4.1 0.332 67 33 23 112.38 2.03 34 36 339
3.450 1284 31 31 -8.6 59 0.860 4 -10.2 4 9 20 3.9 196 0.880 143 55 4716 28 1 -2 -2 10 8 4.1 0.332 67 35 24 112.38 2.14 34 36 339
3.500 1284 32 31 -8.6 59 0.860 4 -10.2 4 11 20 3.9 196 0.880 143 55 4716 30 1 -2 -2 10 8 4.1 0.351 66 35 25 112.38 2.14 35 37 339
3.550 1333 32 31 -8.6 59 0.860 4 -10.2 4 11 20 3.9 196 0.880 143 55 4716 30 1 -3 -3 10 8 4.3 0.338 66 36 26 116.64 2.22 35 36 339
3.600 1333 32 31 -8.6 59 0.890 4 -10.2 4 11 20 3.9 196 0.890 143 57 4716 30 1 -3 -3 10 8 4.3 0.338 66 36 26 116.64 2.22 35 36 339
3.650 1333 32 31 -8.6 59 0.890 4 -10.2 4 11 20 3.8 196 0.890 143 57 4878 30 1 -3 -3 10 8 4.3 0.338 66 36 27 116.64 2.22 35 36 339
3.700 1333 32 31 -8.6 59 0.890 4 -10.2 4 11 20 3.8 196 0.890 143 57 4878 30 1 -3 -3 10 8 4.3 0.338 66 36 28 116.64 2.23 35 36 339
3.750 1333 37 28 -8.6 59 0.890 4 -10.2 6 11 22 3.8 196 0.890 143 57 4878 45 1 -3 -3 8 12 4.3 0.508 73 36 29 116.64 2.23 28 54 339
3.800 1380 37 28 -5.5 59 0.890 4 -7 6 11 22 3.8 196 0.890 143 57 4878 45 1 -7 -8 8 12 4.4 0.491 73 38 30 120.71 2.31 28 52 339
3.850 1380 37 4 28 -5.5 59 0.860 4 -7 6 11 22 3.8 196 0.810 143 80 4878 45 1 -7 -8 8 12 4.4 0.491 73 38 31 120.71 2.31 28 52 339
3.900 1380 37 4 28 -5.5 59 0.860 5 -7 6 11 22 4.7 196 0.810 143 80 5544 45 1 -7 -8 8 12 5.4 0.491 73 38 31 120.71 2.31 28 52 339
3.950 1380 37 4 28 -5.5 59 0.860 5 -7 6 11 22 4.7 196 0.810 175 80 5544 45 1 -7 -8 8 12 5.4 0.491 73 46 32 120.71 2.82 28 52 339
4.000 1380 42 4 24 -5.5 59 0.860 5 -7 8 12 24 4.7 196 0.810 175 80 5544 57 1 -7 -8 6 16 5.4 0.617 81 46 33 120.71 2.82 20 66 339
4.050 1480 42 4 24 -3.1 59 0.860 5 -4.7 8 12 24 4.7 196 0.810 175 80 5544 57 1 1 6 16 5.8 0.575 81 49 34 129.53 3.02 20 61 339
4.100 1480 42 4 24 -3.1 59 0.030 5 -4.7 8 12 24 4.7 196 0.030 175 93 5544 57 1 1 6 16 5.8 0.575 81 49 35 129.53 3.02 20 61 339
4.150 1480 42 4 24 -3.1 59 0.030 6 -4.7 8 12 24 6.1 196 0.030 175 93 5997 57 1 1 6 16 7.6 0.575 81 49 36 129.53 3.02 20 61 339
4.200 1480 42 4 24 -3.1 59 0.030 6 -4.7 8 12 24 6.1 196 0.030 219 93 5997 57 1 1 6 16 7.6 0.575 81 62 37 129.53 3.78 20 61 339
4.250 1480 44 4 23 -3.1 59 0.030 6 -4.7 8 13 24 6.1 196 0.030 219 93 5997 62 1 1 6 17 7.6 0.630 82 62 37 129.53 3.78 19 67 339
4.300 1601 44 4 23 -3.1 59 0.030 6 -4.7 8 13 24 6.1 196 0.030 219 93 5997 62 1 4 3 6 17 8.2 0.582 82 67 38 140.04 4.08 19 62 339
4.350 1601 44 4 23 -3.1 59 0.020 6 -4.7 8 13 24 6.1 196 0.030 219 94 5997 62 1 4 3 6 17 8.2 0.582 82 67 39 140.04 4.08 19 62 339
4.400 1601 44 4 23 -3.1 59 0.020 7 -4.7 8 13 24 6.8 196 0.030 219 94 6163 62 1 4 3 6 17 9.0 0.582 82 67 40 140.04 4.08 19 62 339
4.450 1601 44 4 23 -3.1 59 0.020 7 -4.7 8 13 24 6.8 196 0.030 240 94 6163 62 1 4 3 6 17 9.0 0.582 82 73 41 140.04 4.47 19 62 339
4.500 1601 44 4 23 -3.1 59 0.020 7 -4.7 9 14 24 6.8 196 0.030 240 94 6163 65 1 4 3 6 18 9.0 0.611 81 73 42 140.04 4.47 20 65 339
4.550 1764 44 4 23 -3.1 59 0.020 7 -4.7 9 14 24 6.8 196 0.030 240 94 6163 65 1 8 8 6 18 9.9 0.554 81 80 43 154.31 4.93 20 59 339
4.600 1764 44 4 23 -3.1 59 0.040 7 -4.7 9 14 24 6.8 196 0.030 240 86 6163 65 1 8 8 6 18 9.9 0.554 81 80 44 154.31 4.93 20 59 339
4.650 1764 44 4 23 -3.1 59 0.040 8 -4.7 9 14 24 7.5 196 0.030 240 86 6259 65 1 8 8 6 18 11.0 0.554 81 80 45 154.31 4.93 20 59 339
4.700 1764 44 4 23 -3.1 59 0.040 8 -4.7 9 14 24 7.5 196 0.030 262 86 6259 65 1 8 8 6 18 11.0 0.554 81 88 46 154.31 5.39 20 59 339
4.750 1764 49 4 23 -3.1 59 0.040 8 -4.7 10 16 25 7.5 196 0.030 262 86 6259 77 1 8 8 5 21 11.0 0.654 84 88 48 154.31 5.39 17 70 339
4.800 1885 49 4 23 -3.1 59 0.040 8 -4.7 10 16 25 7.5 196 0.030 262 86 6259 77 1 -1 -1 5 21 11.8 0.612 84 94 49 164.94 5.77 17 65 339
4.850 1885 49 4 23 -3.1 59 0.900 8 -4.7 10 16 25 7.5 196 0.870 262 94 6259 77 1 -1 -1 5 21 11.8 0.612 84 94 50 164.94 5.77 17 65 339
4.900 1885 49 4 23 -3.1 59 0.900 7 -4.7 10 16 25 7.4 196 0.870 262 94 6628 77 1 -1 -1 5 21 11.7 0.612 84 94 51 164.94 5.77 17 65 339
4.950 1885 49 4 23 -3.1 59 0.900 7 -4.7 10 16 25 7.4 196 0.870 281 94 6628 77 1 -1 -1 5 21 11.7 0.612 84 101 52 164.94 6.18 17 65 339
5.000 1885 51 4 24 -3.1 59 0.900 7 -4.7 10 17 25 7.4 196 0.870 281 94 6628 78 1 -1 -1 5 22 11.7 0.623 86 101 54 164.94 6.18 15 67 339
5.050 1948 51 4 24 -3.1 59 0.900 7 -4.7 10 17 25 7.4 196 0.870 281 94 6628 78 1 -5 5 22 12.1 0.602 86 104 55 170.45 6.38 15 64 339
5.100 1948 51 4 24 -3.1 59 0.320 7 -4.7 10 17 25 7.4 196 0.800 281 97 6628 78 1 -5 5 22 12.1 0.602 86 104 56 170.45 6.38 15 64 339
5.150 1948 51 4 24 -3.1 59 0.320 8 -4.7 10 17 25 7.2 196 0.800 281 97 6611 78 1 -5 5 22 11.7 0.602 86 104 57 170.45 6.38 15 64 339
5.200 1948 51 4 24 -3.1 59 0.320 8 -4.7 10 17 25 7.2 196 0.800 294 97 6611 78 1 -5 5 22 11.7 0.602 86 109 59 170.45 6.68 15 64 339
5.250 1948 57 4 24 -3.1 59 0.320 8 -4.7 10 19 26 7.2 196 0.800 294 97 6611 78 1 -5 4 22 11.7 0.602 88 109 60 170.45 6.68 13 64 339
5.300 1996 57 4 24 -3.1 59 0.320 8 -4.7 10 19 26 7.2 196 0.800 294 97 6611 78 1 5 1 4 22 12.0 0.588 88 112 61 174.68 6.85 13 63 339
5.350 1996 57 4 24 -3.1 59 0.610 8 -4.7 10 19 26 7.2 196 0.330 294 86 6611 78 1 5 1 4 22 12.0 0.588 88 112 63 174.68 6.85 13 63 339
5.400 1996 57 4 24 -3.1 59 0.610 8 -4.7 10 19 26 8.0 196 0.330 294 86 6993 78 1 5 1 4 22 13.3 0.588 88 112 64 174.68 6.85 13 63 339
5.450 1996 57 4 24 -3.1 59 0.610 8 -4.7 10 19 26 8.0 196 0.330 300 86 6993 78 1 5 1 4 22 13.3 0.588 88 114 65 174.68 6.98 13 63 339
5.500 1996 57 4 24 -3.1 59 0.610 8 -4.7 10 19 26 8.0 196 0.330 300 86 6993 78 1 5 1 4 22 13.3 0.588 88 114 67 174.68 6.98 13 63 339
5.550 1996 64 4 24 -3.1 59 0.610 8 -4.7 13 21 26 8.0 196 0.330 300 86 6993 96 1 5 1 4 27 13.3 0.724 89 114 68 174.68 6.98 12 77 339
5.600 2072 64 4 24 -3.1 59 0.610 8 -4.7 13 21 26 8.0 196 0.330 300 86 6993 96 1 -3 4 27 13.8 0.698 89 118 70 181.33 7.24 12 75 339
5.650 2072 64 4 24 -3.1 59 0.900 8 -4.7 13 21 26 8.0 196 0.830 300 99 6993 96 1 -3 4 27 13.8 0.698 89 118 72 181.33 7.24 12 75 339
5.700 2072 64 4 24 -3.1 59 0.900 8 -4.7 13 21 26 7.5 196 0.830 300 99 6722 96 1 -3 4 27 12.9 0.698 89 118 73 181.33 7.24 12 75 339
5.750 2072 64 4 24 -3.1 59 0.900 8 -4.7 13 21 26 7.5 196 0.830 306 99 6722 96 1 -3 4 27 12.9 0.698 89 121 75 181.33 7.41 12 75 339
5.800 2072 67 4 27 -3.1 59 0.900 8 -4.7 13 22 26 7.5 196 0.830 306 99 6722 101 1 -3 4 28 12.9 0.732 89 121 76 181.33 7.41 12 78 339
5.850 2160 67 4 27 -3.1 59 0.900 8 -4.7 13 22 26 7.5 196 0.830 306 99 6722 101 1 4 28 13.4 0.702 89 126 78 189.03 7.72 12 75 339
5.900 2160 67 4 27 -3.1 59 0.910 8 -4.7 13 22 26 7.5 196 0.930 306 94 6722 101 4 28 13.4 0.702 89 126 79 189.03 7.72 12 75 339
5.950 2160 67 4 27 -3.1 59 0.910 9 -4.7 13 22 26 9.2 196 0.930 306 94 6644 101 4 28 16.5 0.702 89 126 81 189.03 7.72 12 75 339
6.000 2160 67 4 27 -3.1 59 0.910 9 -4.7 13 22 26 9.2 196 0.930 314 94 6644 101 4 28 16.5 0.702 89 129 83 189.03 7.92 12 75 339
6.050 2160 66 4 28 -3.1 59 0.910 9 -4.7 11 23 26 9.2 196 0.930 314 94 6644 80 4 22 16.5 0.556 89 129 84 189.03 7.92 12 59 339
6.100 2227 66 4 28 -3.1 59 0.910 9 -4.7 11 23 26 9.2 196 0.930 314 94 6644 80 4 22 17.1 0.539 89 133 86 194.86 8.16 12 58 339
6.150 2227 66 4 28 -3.1 59 0.940 9 -4.7 11 23 26 9.2 196 0.940 314 82 6644 80 4 22 17.1 0.539 89 133 88 194.86 8.16 12 58 339
6.200 2227 66 4 28 -3.1 59 0.940 10 -4.7 11 23 26 9.5 196 0.940 314 82 7117 80 4 22 17.6 0.539 89 133 89 194.86 8.16 12 58 339
6.250 2227 66 4 28 -3.1 59 0.940 10 -4.7 11 23 26 9.5 196 0.940 310 82 7117 80 4 22 17.6 0.539 89 132 91 194.86 8.06 12 58 339
6.300 2227 66 4 29 -3.1 59 0.940 10 -4.7 14 25 26 9.5 196 0.940 310 82 7117 102 4 28 17.6 0.689 88 132 93 194.86 8.06 13 74 339
6.350 2336 66 4 29 -3.1 59 0.940 10 -4.7 14 25 26 9.5 196 0.940 310 82 7117 102 4 28 18.4 0.657 88 138 95 204.36 8.46 13 70 339
6.400 2336 66 4 29 -3.1 59 0.920 10 -4.7 14 25 26 9.5 196 0.930 310 100 7117 102 4 28 18.4 0.657 88 138 97 204.36 8.46 13 70 339
6.450 2336 66 4 29 -3.1 59 0.920 9 -4.7 14 25 26 9.3 196 0.930 310 100 6855 102 4 28 18.2 0.657 88 138 98 204.36 8.46 13 70 339
6.500 2336 66 4 29 -3.1 59 0.920 9 -4.7 14 25 26 9.3 196 0.930 317 100 6855 102 4 28 18.2 0.657 88 141 100 204.36 8.64 13 70 339
6.550 2336 67 4 28 -3.1 59 0.920 9 -4.7 14 26 26 9.3 196 0.930 317 100 6855 103 4 28 18.2 0.663 89 141 102 204.36 8.64 12 71 339
6.600 2411 67 4 28 -3.1 59 0.920 9 -4.7 14 26 26 9.3 196 0.930 317 100 6855 103 4 28 18.8 0.642 89 146 104 210.95 8.92 12 69 339
6.650 2411 67 4 28 -3.1 59 0.910 9 -4.7 14 26 26 9.3 196 0.910 317 100 6855 103 4 28 18.8 0.642 89 146 106 210.95 8.92 12 69 339
6.700 2411 67 4 28 -3.1 59 0.910 9 -4.7 14 26 26 9.4 196 0.910 317 100 7048 103 4 28 19.0 0.642 89 146 108 210.95 8.92 12 69 339
6.750 2411 67 4 28 -3.1 59 0.910 9 -4.7 14 26 26 9.4 196 0.910 318 100 7048 103 4 28 19.0 0.642 89 146 110 210.95 8.93 12 69 339
6.800 2411 74 4 29 -3.1 59 0.910 9 -4.7 14 28 26 9.4 196 0.910 318 100 7048 103 4 28 19.0 0.642 88 146 112 210.95 8.93 13 69 339
6.850 2496 74 4 29 -3.1 59 0.910 9 -4.7 14 28 26 9.4 196 0.910 318 100 7048 103 4 28 19.6 0.620 88 151 114 218.40 9.25 13 66 339
6.900 2496 74 4 29 -3.1 59 0.910 9 -4.7 14 28 26 9.4 196 0.910 318 99 7048 103 4 28 19.6 0.620 88 151 116 218.40 9.25 13 66 339
6.950 2496 74 4 29 -3.1 59 0.910 10 -4.7 14 28 26 9.7 196 0.910 318 99 7393 103 4 28 20.1 0.620 88 151 118 218.40 9.25 13 66 339
7.000 2496 74 4 29 -3.1 59 0.910 10 -4.7 14 28 26 9.7 196 0.910 316 99 7393 103 4 28 20.1 0.620 88 150 120 218.40 9.19 13 66 339
7.050 2496 88 4 22 -3.1 59 0.910 10 -4.7 16 30 27 9.7 196 0.910 316 99 7393 118 3 33 20.1 0.708 90 150 122 218.40 9.19 11 76 339
7.100 2587 88 4 22 -3.1 59 0.910 10 -4.7 16 30 27 9.7 196 0.910 316 99 7393 118 3 33 20.9 0.683 90 156 124 226.39 9.53 11 73 339
7.150 2587 88 4 22 -3.1 59 0.900 10 -4.7 16 30 27 9.7 196 0.910 316 92 7393 118 3 33 20.9 0.683 90 156 127 226.39 9.53 11 73 339
7.200 2587 88 4 22 -3.1 59 0.900 10 -4.7 16 30 27 9.8 196 0.910 316 92 7729 118 3 33 21.1 0.683 90 156 129 226.39 9.53 11 73 339
7.250 2587 88 4 22 -3.1 59 0.900 10 -4.7 16 30 27 9.8 196 0.910 315 92 7729 118 3 33 21.1 0.683 90 155 131 226.39 9.50 11 73 339
7.300 2587 88 4 28 -3.1 59 0.900 10 -4.7 16 31 26 9.8 196 0.910 315 92 7729 123 4 34 21.1 0.711 89 155 133 226.39 9.50 12 76 339
7.350 2574 88 4 28 -3.1 59 0.900 10 -4.7 16 31 26 9.8 196 0.910 315 92 7729 123 4 34 21.0 0.715 89 154 136 225.21 9.45 12 76 339
7.400 2574 88 4 28 -3.1 59 0.910 10 -4.7 16 31 26 9.8 196 0.890 315 100 7729 123 4 34 21.0 0.715 89 154 138 225.21 9.45 12 76 339
7.450 2574 88 4 28 -3.1 59 0.910 10 -4.7 16 31 26 10.0 196 0.890 315 100 7233 123 4 34 21.5 0.715 89 154 140 225.21 9.45 12 76 339
7.500 2574 88 4 28 -3.1 59 0.910 10 -4.7 16 31 26 10.0 196 0.890 341 100 7233 123 4 34 21.5 0.715 89 167 142 225.21 10.24 12 76 339
7.550 2574 88 4 28 -3.1 59 0.910 10 -4.7 14 33 26 10.0 196 0.890 341 100 7233 105 4 29 21.5 0.610 89 167 145 225.21 10.24 12 65 339
7.600 2669 88 4 28 -3.1 59 0.910 10 -4.7 14 33 26 10.0 196 0.890 341 100 7233 105 4 29 22.3 0.588 89 173 147 233.49 10.61 12 63 339
7.650 2669 88 4 28 -3.1 59 0.900 10 -4.7 14 33 26 10.0 196 0.900 341 100 7233 105 4 29 22.3 0.588 89 173 150 233.49 10.61 12 63 339
7.700 2669 88 4 28 -3.1 59 0.900 10 -4.7 14 33 26 10.3 196 0.900 341 100 7547 105 4 29 22.9 0.588 89 173 152 233.49 10.61 12 63 339
7.750 2669 88 4 28 -3.1 59 0.900 10 -4.7 14 33 26 10.3 196 0.900 344 100 7547 105 4 29 22.9 0.588 89 175 155 233.49 10.69 12 63 339
7.800 2669 88 4 25 -3.1 59 0.900 10 -4.7 18 34 26 10.3 196 0.900 344 100 7547 136 4 38 22.9 0.765 89 175 157 233.49 10.69 12 82 339
7.850 2800 88 4 25 -3.1 59 0.900 10 -4.7 18 34 26 10.3 196 0.900 344 100 7547 136 4 38 24.1 0.729 89 183 159 244.98 11.22 12 78 339
7.900 2800 88 4 25 -3.1 59 0.900 10 -4.7 18 34 26 10.3 196 0.910 344 100 7547 136 4 38 24.1 0.729 89 183 162 244.98 11.22 12 78 339
7.950 2800 88 4 25 -3.1 59 0.900 11 -4.7 18 34 26 11.0 196 0.910 344 100 7597 136 4 38 25.7 0.729 89 183 164 244.98 11.22 12 78 339
8.000 2800 88 4 25 -3.1 59 0.900 11 -4.7 18 34 26 11.0 196 0.910 383 100 7597 136 4 38 25.7 0.729 89 204 167 244.98 12.50 12 78 339
8.050 2800 88 4 25 -3.1 59 0.900 11 -4.7 18 34 26 11.0 196 0.910 383 100 7597 136 4 38 25.7 0.729 89 204 169 244.98 12.50 12 78 339
8.100 2800 88 4 25 -3.1 59 0.900 11 -4.7 18 36 26 11.0 196 0.910 383 100 7597 133 4 37 25.7 0.714 89 204 172 244.98 12.50 12 76 339
8.150 2904 88 4 25 -3.1 59 0.900 11 -4.7 18 36 26 11.0 196 0.910 383 100 7597 133 4 37 26.6 0.688 89 212 175 254.08 12.96 12 74 339
8.200 2904 88 4 25 -3.1 59 0.900 11 -4.7 18 36 26 11.0 196 0.920 383 100 7597 133 4 37 26.6 0.688 89 212 177 254.08 12.96 12 74 339
8.250 2904 88 4 25 -3.1 59 0.900 11 -4.7 18 36 26 11.5 196 0.920 383 100 8130 133 4 37 27.7 0.688 89 212 180 254.08 12.96 12 74 339
8.300 2904 88 4 25 -3.1 59 0.900 11 -4.7 18 36 26 11.5 196 0.920 393 100 8130 133 4 37 27.7 0.688 89 217 183 254.08 13.31 12 74 339
8.350 2904 88 4 26 -3.1 59 0.900 11 -4.7 21 38 26 11.5 196 0.920 393 100 8130 157 4 43 27.7 0.812 89 217 185 254.08 13.31 12 87 339
8.400 3023 88 4 26 -3.1 59 0.900 11 -4.7 21 38 26 11.5 196 0.920 393 100 8130 157 4 43 28.9 0.780 89 226 188 264.54 13.86 12 83 339
8.450 3023 88 4 26 -3.1 59 0.920 11 -4.7 21 38 26 11.5 196 0.920 393 100 8130 157 4 43 28.9 0.780 89 226 191 264.54 13.86 12 83 339
8.500 3023 88 4 26 -3.1 59 0.920 11 -4.7 21 38 26 11.3 196 0.920 393 100 8230 157 4 43 28.5 0.780 89 226 194 264.54 13.86 12 83 339
8.550 3023 88 4 26 -3.1 59 0.920 11 -4.7 21 38 26 11.3 196 0.920 390 100 8230 157 4 43 28.5 0.780 89 224 197 264.54 13.75 12 83 339
8.600 3023 88 4 28 -3.1 59 0.920 11 -4.7 18 40 27 11.3 196 0.920 390 100 8230 139 3 38 28.5 0.692 90 224 200 264.54 13.75 11 74 339
8.650 3146 88 4 28 -3.1 59 0.920 11 -4.7 18 40 27 11.3 196 0.920 390 100 8230 139 3 38 29.7 0.665 90 234 202 275.30 14.31 11 71 339
8.700 3146 88 4 28 -3.1 59 0.910 11 -4.7 18 40 27 11.3 196 0.930 390 100 8230 139 3 38 29.7 0.665 90 234 205 275.30 14.31 11 71 339
8.750 3146 88 4 28 -3.1 59 0.910 11 -4.7 18 40 27 11.1 196 0.930 390 100 8196 139 3 38 29.1 0.665 90 234 208 275.30 14.31 11 71 339
8.800 3146 88 4 28 -3.1 59 0.910 11 -4.7 18 40 27 11.1 196 0.930 383 100 8196 139 3 38 29.1 0.665 90 230 211 275.30 14.07 11 71 339
8.850 3146 88 4 28 -3.1 57 0.910 11 -4.7 20 41 26 11.1 196 0.930 383 100 8196 152 4 42 29.1 0.726 89 230 214 275.30 14.07 12 77 337
8.900 3247 88 4 28 -3.1 57 0.910 11 -4.7 20 41 26 11.1 196 0.930 383 100 8196 152 4 42 30.0 0.704 89 237 217 284.14 14.53 12 75 337
8.950 3247 88 4 28 -3.1 57 0.920 11 -4.7 20 41 26 11.1 196 0.930 383 95 8196 152 4 42 30.0 0.704 89 237 220 284.14 14.53 12 75 337
9.000 3247 88 4 28 -3.1 57 0.920 11 -4.7 20 41 26 11.3 196 0.930 383 95 8537 152 4 42 30.5 0.704 89 237 223 284.14 14.53 12 75 337
9.050 3247 88 4 28 -3.1 57 0.920 11 -4.7 20 41 26 11.3 196 0.930 380 95 8537 152 4 42 30.5 0.704 89 235 226 284.14 14.39 12 75 337
9.100 3247 88 4 28 -3.1 57 0.920 11 -4.7 23 43 26 11.3 196 0.930 380 95 8537 175 4 48 30.5 0.809 89 235 229 284.14 14.39 12 86 337
9.150 3385 88 4 28 -3.1 57 0.920 11 -4.7 23 43 26 11.3 196 0.930 380 95 8537 175 4 48 31.8 0.777 89 245 233 296.17 15.00 12 83 337
9.200 3385 88 4 28 -3.1 57 0.920 11 -4.7 23 43 26 11.3 196 0.930 380 97 8537 175 4 48 31.8 0.777 89 245 236 296.17 15.00 12 83 337
9.250 3385 88 4 28 -3.1 57 0.920 11 -4.7 23 43 26 11.0 196 0.930 380 97 8359 175 4 48 31.0 0.777 89 245 239 296.17 15.00 12 83 337
9.300 3385 88 4 28 -3.1 57 0.920 11 -4.7 23 43 26 11.0 196 0.930 378 97 8359 175 4 48 31.0 0.777 89 243 242 296.17 14.91 12 83 337
9.350 3385 88 4 28 -3.1 57 0.920 11 -4.7 20 44 26 11.0 196 0.930 378 97 8359 152 4 42 31.0 0.673 89 243 245 296.17 14.91 12 72 337
9.400 3512 88 4 28 -3.1 57 0.920 11 -4.7 20 44 26 11.0 196 0.930 378 97 8359 152 4 42 32.1 0.649 89 252 249 307.26 15.47 12 69 337
9.450 3512 88 4 28 -3.1 57 0.920 11 -4.7 20 44 26 11.0 196 0.920 378 100 8359 152 4 42 32.1 0.649 89 252 252 307.26 15.47 12 69 337
9.500 3512 88 4 28 -3.1 57 0.920 11 -4.7 20 44 26 11.2 196 0.920 378 100 8556 152 4 42 32.7 0.649 89 252 255 307.26 15.47 12 69 337
9.550 3512 88 4 28 -3.1 57 0.920 11 -4.7 20 44 26 11.2 196 0.920 381 100 8556 152 4 42 32.7 0.649 89 255 258 307.26 15.61 12 69 337
9.600 3512 88 4 27 -3.1 57 0.920 11 -4.7 22 46 26 11.2 196 0.920 381 100 8556 164 4 45 32.7 0.700 89 255 262 307.26 15.61 12 75 337
9.650 3636 88 4 27 -3.1 57 0.920 11 -4.7 22 46 26 11.2 196 0.920 381 100 8556 164 4 45 33.8 0.676 89 264 265 318.13 16.17 12 72 337
9.700 3636 88 4 27 -3.1 57 0.920 11 -4.7 22 46 26 11.2 196 0.930 381 100 8556 164 4 45 33.8 0.676 89 264 268 318.13 16.17 12 72 337
9.750 3636 88 4 27 -3.1 57 0.920 11 -4.7 22 46 26 11.5 196 0.930 381 100 8629 164 4 45 34.7 0.676 89 264 272 318.13 16.17 12 72 337
9.800 3636 88 4 27 -3.1 57 0.920 11 -4.7 22 46 26 11.5 196 0.930 388 100 8629 164 4 45 34.7 0.676 89 269 275 318.13 16.46 12 72 337
9.850 3636 88 4 27 -3.1 57 0.920 11 -4.7 24 48 26 11.5 196 0.930 388 100 8629 180 4 50 34.7 0.742 89 269 279 318.13 16.46 12 79 337
9.900 3788 88 4 27 -3.1 57 0.920 11 -4.7 24 48 26 11.5 196 0.930 388 100 8629 180 4 50 36.1 0.712 89 280 282 331.43 17.15 12 76 337
9.950 3788 88 4 27 -3.1 57 0.930 11 -4.7 24 48 26 11.5 196 0.940 388 100 8629 180 4 50 36.1 0.712 89 280 286 331.43 17.15 12 76 337
10.000 3788 88 4 27 -3.1 57 0.930 12 -4.7 24 48 26 11.7 196 0.940 388 100 8771 180 4 50 36.8 0.712 89 280 289 331.43 17.15 12 76 337
10.050 3788 88 4 27 -3.1 57 0.930 12 -4.7 24 48 26 11.7 196 0.940 391 100 8771 180 4 50 36.8 0.712 89 282 293 331.43 17.29 12 76 337
10.100 3788 88 4 27 -3.1 57 0.930 12 -4.7 24 49 26 11.7 196 0.940 391 100 8771 182 4 50 36.8 0.719 89 282 296 331.43 17.29 12 77 337
10.150 3906 88 4 27 -3.1 57 0.930 12 -4.7 24 49 26 11.7 196 0.940 391 100 8771 182 4 50 38.0 0.698 89 291 300 341.76 17.83 12 74 337
10.200 3906 88 4 27 -3.1 57 0.930 12 -4.7 24 49 26 11.7 196 0.930 391 100 8771 182 4 50 38.0 0.698 89 291 303 341.76 17.83 12 74 337
10.250 3906 88 4 27 -3.1 57 0.930 12 -4.7 24 49 26 11.9 196 0.930 391 100 8800 182 4 50 38.6 0.698 89 291 307 341.76 17.83 12 74 337
10.300 3906 88 4 27 -3.1 57 0.930 12 -4.7 24 49 26 11.9 196 0.930 398 100 8800 182 4 50 38.6 0.698 89 296 311 341.76 18.12 12 74 337
10.350 3906 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 11.9 196 0.930 398 100 8800 187 4 52 38.6 0.719 89 296 314 341.76 18.12 12 77 337
10.400 4044 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 11.9 196 0.930 398 100 8800 187 4 52 39.9 0.694 89 306 318 353.85 18.76 12 74 337
10.450 4044 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 11.9 196 0.930 398 100 8800 187 4 52 39.9 0.694 89 306 322 353.85 18.76 12 74 337
10.500 4044 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 12.1 196 0.930 398 100 9163 187 4 52 40.8 0.694 89 306 326 353.85 18.76 12 74 337
10.550 4044 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 12.1 196 0.930 404 100 9163 187 4 52 40.8 0.694 89 311 329 353.85 19.04 12 74 337
10.600 4044 88 4 28 -3.1 57 0.930 12 -4.7 25 51 26 12.1 196 0.930 404 100 9163 187 4 52 40.8 0.694 89 311 333 353.85 19.04 12 74 337
10.650 4044 88 4 30 -3.1 57 0.930 12 -4.7 26 53 26 12.1 196 0.930 404 100 9163 200 4 55 40.8 0.743 88 311 337 353.85 19.04 13 79 337
10.700 4172 88 4 30 -3.1 57 0.930 12 -4.7 26 53 26 12.1 196 0.930 404 100 9163 200 4 55 42.1 0.720 88 321 341 365.01 19.64 13 77 337
10.750 4172 88 4 30 -3.1 57 0.930 12 -4.7 26 53 26 12.1 196 0.930 404 100 9163 200 4 55 42.1 0.720 88 321 345 365.01 19.64 13 77 337
10.800 4172 88 4 30 -3.1 57 0.930 12 -4.7 26 53 26 12.4 196 0.930 404 100 9378 200 4 55 43.0 0.720 88 321 349 365.01 19.64 13 77 337
10.850 4172 88 4 30 -3.1 57 0.930 12 -4.7 26 53 26 12.4 196 0.930 413 100 9378 200 4 55 43.0 0.720 88 328 353 365.01 20.12 13 77 337
10.900 4172 88 4 29 -3.1 57 0.930 12 -4.7 26 55 26 12.4 196 0.930 413 100 9378 198 4 55 43.0 0.713 88 328 357 365.01 20.12 13 76 337
10.950 4318 88 4 29 -3.1 57 0.930 12 -4.7 26 55 26 12.4 196 0.930 413 100 9378 198 4 55 44.5 0.689 88 340 361 377.78 20.82 13 73 337
11.000 4318 88 4 29 -3.1 57 0.920 12 -4.7 26 55 26 12.4 196 0.930 413 100 9378 198 4 55 44.5 0.689 88 340 365 377.78 20.82 13 73 337
11.050 4318 88 4 29 -3.1 57 0.920 13 -4.7 26 55 26 12.7 196 0.930 413 100 9661 198 4 55 45.8 0.689 88 340 369 377.78 20.82 13 73 337
11.100 4318 88 4 29 -3.1 57 0.920 13 -4.7 26 55 26 12.7 196 0.930 426 100 9661 198 4 55 45.8 0.689 88 350 373 377.78 21.47 13 73 337
11.150 4318 88 4 29 -3.1 57 0.920 13 -4.7 35 57 26 12.7 196 0.930 426 100 9661 261 4 72 45.8 0.908 88 350 377 377.78 21.47 13 97 337
11.200 4457 88 4 29 -3.1 57 0.920 13 -4.7 35 57 26 12.7 196 0.930 426 100 9661 261 4 72 47.3 0.880 88 362 381 389.94 22.16 13 94 337
11.250 4457 88 4 29 -3.1 57 0.910 13 -4.7 35 57 26 12.7 196 0.930 426 100 9661 261 4 72 47.3 0.880 88 362 385 389.94 22.16 13 94 337
11.300 4457 88 4 29 -3.1 57 0.910 13 -4.7 35 57 26 13.2 196 0.930 426 100 9163 261 4 72 48.8 0.880 88 362 389 389.94 22.16 13 94 337
11.350 4457 88 4 29 -3.1 57 0.910 13 -4.7 35 57 26 13.2 196 0.930 443 100 9163 261 4 72 48.8 0.880 88 376 394 389.94 23.04 13 94 337
11.400 4457 88 4 29 -3.1 57 0.910 13 -4.7 33 58 26 13.2 196 0.930 443 100 9163 252 4 70 48.8 0.848 88 376 398 389.94 23.04 13 90 337
11.450 4601 88 4 29 -3.1 57 0.910 13 -4.7 33 58 26 13.2 196 0.930 443 100 9163 252 4 70 50.4 0.821 88 388 402 402.57 23.78 13 88 337
11.500 4601 88 4 29 -3.1 57 0.920 13 -4.7 33 58 26 13.2 196 0.930 443 100 9163 252 4 70 50.4 0.821 88 388 406 402.57 23.78 13 88 337
11.550 4601 88 4 29 -3.1 57 0.920 13 -4.7 33 58 26 13.3 196 0.930 443 100 9852 252 4 70 51.0 0.821 88 388 411 402.57 23.78 13 88 337
11.600 4601 88 4 29 -3.1 57 0.920 13 -4.7 33 58 26 13.3 196 0.930 445 100 9852 252 4 70 51.0 0.821 88 390 415 402.57 23.89 13 88 337
11.650 4601 88 4 30 -3.1 57 0.920 13 -4.7 35 60 26 13.3 196 0.930 445 100 9852 261 4 72 51.0 0.852 88 390 419 402.57 23.89 13 91 337
11.700 4700 88 4 30 -3.1 57 0.920 13 -4.7 35 60 26 13.3 196 0.930 445 100 9852 261 4 72 52.1 0.834 88 398 424 411.25 24.41 13 89 337
11.750 4700 88 4 30 -3.1 57 0.910 13 -4.7 35 60 26 13.3 196 0.930 445 100 9852 261 4 72 52.1 0.834 88 398 428 411.25 24.41 13 89 337
11.800 4700 88 4 30 -3.1 57 0.910 13 -4.7 35 60 26 13.3 196 0.930 448 100 9852 261 4 72 52.1 0.834 88 401 432 411.25 24.59 13 89 337
11.850 4700 88 4 -3 -3.1 57 0.910 13 -4.7 31 62 26 13.3 196 0.930 448 100 9852 235 4 65 52.1 0.749 88 401 437 411.25 24.59 13 80 337
11.900 4473 88 4 -3 -3.1 57 0.910 13 -4.7 31 62 26 13.3 196 0.930 448 100 9852 235 4 65 49.6 0.788 88 382 442 391.37 23.40 13 84 337
11.950 4473 1 88 4 -3 -3.1 57 0.910 13 -4.7 31 62 26 13.3 196 0.930 448 100 9852 235 4 65 49.6 0.788 88 382 446 391.37 23.40 13 84 337
12.000 4473 1 88 4 -3 -3.1 57 0.910 13 -4.7 31 62 26 13.3 196 0.930 448 100 9615 235 4 65 49.7 0.788 88 382 451 391.37 23.40 13 84 337
12.050 4473 1 88 4 -3 -3.1 57 0.910 13 -4.7 31 62 26 13.3 196 0.930 256 100 9615 235 4 65 49.7 0.788 88 218 455 391.37 13.35 13 84 337
12.100 4473 1 88 4 28 -3.1 57 0.910 13 -4.7 20 63 26 13.3 196 0.930 256 100 9615 154 4 42 49.7 0.516 89 218 460 391.37 13.35 12 55 337
12.150 3087 1 88 4 28 -3.1 57 0.910 13 -4.7 20 63 26 13.3 196 0.930 256 100 9615 154 4 42 34.3 0.747 89 150 464 270.07 9.21 12 80 337
12.200 3087 1 88 4 28 -3.1 57 0.930 13 -4.7 20 63 26 13.3 196 0.930 256 100 9615 154 4 42 34.3 0.747 89 150 469 270.07 9.21 12 80 337
12.250 3087 1 88 4 28 -3.1 57 0.930 11 -4.7 20 63 26 10.8 196 0.930 256 100 8474 154 4 42 27.7 0.747 89 150 474 270.07 9.21 12 80 337
12.300 3087 1 88 4 28 -3.1 57 0.930 11 -4.7 20 63 26 10.8 196 0.930 380 100 8474 154 4 42 27.7 0.747 89 223 478 270.07 13.68 12 80 337
12.350 3087 1 88 4 29 -3.1 57 0.930 11 -4.7 20 63 27 10.8 196 0.930 380 100 8474 149 3 41 27.7 0.722 90 223 483 270.07 13.68 11 77 337
12.400 3265 1 88 4 29 -3.1 57 0.930 11 -4.7 20 63 27 10.8 196 0.930 380 100 8474 149 3 41 29.3 0.683 90 236 488 285.67 14.47 11 73 337
12.450 3265 88 4 29 -3.1 57 0.920 11 -4.7 20 63 27 10.8 196 0.920 380 100 8474 149 3 41 29.3 0.683 90 236 492 285.67 14.47 11 73 337
12.500 3265 88 4 29 -3.1 57 0.920 11 -4.7 20 63 27 11.0 196 0.920 380 100 8342 149 3 41 29.8 0.683 90 236 497 285.67 14.47 11 73 337
12.550 3265 88 4 29 -3.1 57 0.920 11 -4.7 20 63 27 11.0 196 0.920 379 100 8342 149 3 41 29.8 0.683 90 235 501 285.67 14.42 11 73 337
12.600 3265 88 4 29 -3.1 57 0.920 11 -4.7 19 65 27 11.0 196 0.920 379 100 8342 146 3 40 29.8 0.668 90 235 506 285.67 14.42 11 71 337
12.650 3321 88 4 29 -3.1 57 0.920 11 -4.7 19 65 27 11.0 196 0.920 379 100 8342 146 3 40 30.4 0.657 90 239 511 290.61 14.67 11 70 337
12.700 3321 88 4 29 -3.1 57 0.900 11 -4.7 19 65 27 11.0 196 0.920 379 100 8342 146 3 40 30.4 0.657 90 239 516 290.61 14.67 11 70 337
12.750 3321 88 4 29 -3.1 57 0.900 11 -4.7 19 65 27 11.0 196 0.920 379 100 8016 146 3 40 30.3 0.657 90 239 520 290.61 14.67 11 70 337
12.800 3321 88 4 29 -3.1 57 0.900 11 -4.7 19 65 27 11.0 196 0.920 377 100 8016 146 3 40 30.3 0.657 90 239 525 290.61 14.62 11 70 337
12.850 3321 88 4 29 -3.1 57 0.900 11 -4.7 20 66 27 11.0 196 0.920 377 100 8016 152 3 42 30.3 0.686 90 239 530 290.61 14.62 11 73 337
12.900 3361 88 4 29 -3.1 57 0.900 11 -4.7 20 66 27 11.0 196 0.920 377 100 8016 152 3 42 30.7 0.678 90 241 535 294.04 14.79 11 72 337
12.950 3361 88 4 29 -3.1 57 0.920 11 -4.7 20 66 27 11.0 196 0.920 377 100 8016 152 3 42 30.7 0.678 90 241 540 294.04 14.79 11 72 337
13.000 3361 88 4 29 -3.1 57 0.920 11 -4.7 20 66 27 11.0 196 0.920 377 100 8465 152 3 42 30.8 0.678 90 241 545 294.04 14.79 11 72 337
13.050 3361 88 4 29 -3.1 57 0.920 11 -4.7 20 66 27 11.0 196 0.920 377 100 8465 152 3 42 30.8 0.678 90 241 549 294.04 14.76 11 72 337
13.100 3361 88 4 29 -3.1 57 0.920 11 -4.7 20 66 27 11.0 196 0.920 377 100 8465 152 3 42 30.8 0.678 90 241 554 294.04 14.76 11 72 337
13.150 3361 88 4 28 -3.1 57 0.920 11 -4.7 21 67 26 11.0 196 0.920 377 100 8465 155 4 43 30.8 0.693 89 241 559 294.04 14.76 12 74 337
13.200 3397 88 4 28 -3.1 57 0.920 11 -4.7 21 67 26 11.0 196 0.920 377 100 8465 155 4 43 31.2 0.686 89 244 564 297.24 14.92 12 73 337
13.250 3397 88 4 28 -3.1 57 0.910 11 -4.7 21 67 26 11.0 196 0.920 377 100 8465 155 4 43 31.2 0.686 89 244 569 297.24 14.92 12 73 337
13.300 3397 88 4 28 -3.1 57 0.910 11 -4.7 21 67 26 11.0 196 0.920 377 100 8639 155 4 43 31.3 0.686 89 244 574 297.24 14.92 12 73 337
13.350 3397 88 4 28 -3.1 57 0.910 11 -4.7 21 67 26 11.0 196 0.920 377 100 8639 155 4 43 31.3 0.686 89 244 579 297.24 14.95 12 73 337
13.400 3397 88 4 28 -3.1 57 0.910 11 -4.7 20 68 27 11.0 196 0.920 377 100 8639 149 3 41 31.3 0.656 90 244 584 297.24 14.95 11 70 337
13.450 3467 88 4 28 -3.1 57 0.910 11 -4.7 20 68 27 11.0 196 0.920 377 100 8639 149 3 41 31.9 0.643 90 249 589 303.35 15.25 11 69 337
13.500 3467 88 4 28 -3.1 57 0.890 11 -4.7 20 68 27 11.0 196 0.920 377 100 8639 149 3 41 31.9 0.643 90 249 594 303.35 15.25 11 69 337
13.550 3467 88 4 28 -3.1 57 0.890 11 -4.7 20 68 27 11.0 196 0.920 377 100 8205 149 3 41 31.9 0.643 90 249 599 303.35 15.25 11 69 337
13.600 3467 88 4 28 -3.1 57 0.890 11 -4.7 20 68 27 11.0 196 0.920 378 100 8205 149 3 41 31.9 0.643 90 250 604 303.35 15.31 11 69 337
13.650 3467 88 4 28 -3.1 57 0.890 11 -4.7 24 69 26 11.0 196 0.920 378 100 8205 181 4 50 31.9 0.783 89 250 609 303.35 15.31 12 84 337
13.700 3516 88 4 28 -3.1 57 0.890 11 -4.7 24 69 26 11.0 196 0.920 378 100 8205 181 4 50 32.3 0.773 89 253 614 307.61 15.52 12 82 337
13.750 3516 88 4 28 -3.1 57 0.920 11 -4.7 24 69 26 11.0 196 0.920 378 92 8205 181 4 50 32.3 0.773 89 253 619 307.61 15.52 12 82 337
13.800 3516 88 4 28 -3.1 57 0.920 11 -4.7 24 69 26 11.1 196 0.920 378 92 8447 181 4 50 32.5 0.773 89 253 624 307.61 15.52 12 82 337
13.850 3516 88 4 28 -3.1 57 0.920 11 -4.7 24 69 26 11.1 196 0.920 379 92 8447 181 4 50 32.5 0.773 89 254 629 307.61 15.55 12 82 337
13.900 3516 88 4 27 -3.1 57 0.920 11 -4.7 22 70 27 11.1 196 0.920 379 92 8447 165 3 46 32.5 0.706 90 254 634 307.61 15.55 11 75 337
13.950 3569 88 4 27 -3.1 57 0.920 11 -4.7 22 70 27 11.1 196 0.920 379 92 8447 165 3 46 33.0 0.695 90 258 639 312.29 15.79 11 74 337
14.000 3569 88 4 27 -3.1 57 0.920 11 -4.7 22 70 27 11.1 196 0.930 379 92 8447 165 3 46 33.0 0.695 90 258 644 312.29 15.79 11 74 337
14.050 3569 88 4 27 -3.1 57 0.920 11 -4.7 22 70 27 11.2 196 0.930 379 92 8519 165 3 46 33.3 0.695 90 258 650 312.29 15.79 11 74 337
14.100 3569 88 4 27 -3.1 57 0.920 11 -4.7 22 70 27 11.2 196 0.930 382 92 8519 165 3 46 33.3 0.695 90 260 655 312.29 15.92 11 74 337
14.150 3569 88 4 27 -3.1 57 0.920 11 -4.7 22 71 27 11.2 196 0.930 382 92 8519 168 3 46 33.3 0.706 90 260 660 312.29 15.92 11 75 337
14.200 3624 88 4 27 -3.1 57 0.920 11 -4.7 22 71 27 11.2 196 0.930 382 92 8519 168 3 46 33.8 0.695 90 264 665 317.13 16.17 11 74 337
14.250 3624 88 4 27 -3.1 57 0.920 11 -4.7 22 71 27 11.2 196 0.930 382 93 8519 168 3 46 33.8 0.695 90 264 670 317.13 16.17 11 74 337
14.300 3624 88 4 27 -3.1 57 0.920 11 -4.7 22 71 27 11.3 196 0.930 382 93 8556 168 3 46 34.0 0.695 90 264 676 317.13 16.17 11 74 337
14.350 3624 88 4 27 -3.1 57 0.920 11 -4.7 22 71 27 11.3 196 0.930 384 93 8556 168 3 46 34.0 0.695 90 265 681 317.13 16.22 11 74 337
14.400 3624 88 4 27 -3.1 57 0.920 11 -4.7 25 72 26 11.3 196 0.930 384 93 8556 192 4 53 34.0 0.793 89 265 686 317.13 16.22 12 85 337
14.450 3678 88 4 27 -3.1 57 0.920 11 -4.7 25 72 26 11.3 196 0.930 384 93 8556 192 4 53 34.5 0.782 89 269 691 321.83 16.46 12 83 337
14.500 3678 88 4 27 -3.1 57 0.920 11 -4.7 25 72 26 11.3 196 0.920 384 97 8556 192 4 53 34.5 0.782 89 269 697 321.83 16.46 12 83 337
14.550 3678 88 4 27 -3.1 57 0.920 11 -4.7 25 72 26 11.4 196 0.920 384 97 8658 192 4 53 35.0 0.782 89 269 702 321.83 16.46 12 83 337
14.600 3678 88 4 27 -3.1 57 0.920 11 -4.7 25 72 26 11.4 196 0.920 389 97 8658 192 4 53 35.0 0.782 89 272 707 321.83 16.67 12 83 337
14.650 3678 88 4 27 -3.1 57 0.920 11 -4.7 24 73 26 11.4 196 0.920 389 97 8658 178 4 49 35.0 0.726 89 272 713 321.83 16.67 12 77 337
14.700 3732 88 4 27 -3.1 57 0.920 11 -4.7 24 73 26 11.4 196 0.920 389 97 8658 178 4 49 35.5 0.716 89 276 718 326.53 16.91 12 76 337
14.750 3732 88 4 27 -3.1 57 0.900 11 -4.7 24 73 26 11.4 196 0.930 389 100 8658 178 4 49 35.5 0.716 89 276 723 326.53 16.91 12 76 337
14.800 3732 88 4 27 -3.1 57 0.900 12 -4.7 24 73 26 11.5 196 0.930 389 100 8492 178 4 49 35.8 0.716 89 276 729 326.53 16.91 12 76 337
14.850 3732 88 4 27 -3.1 57 0.900 12 -4.7 24 73 26 11.5 196 0.930 392 100 8492 178 4 49 35.8 0.716 89 278 734 326.53 17.05 12 76 337
14.900 3732 88 4 27 -3.1 57 0.900 12 -4.7 24 75 26 11.5 196 0.930 392 100 8492 183 4 51 35.8 0.737 89 278 739 326.53 17.05 12 79 337
14.950 3780 88 4 27 -3.1 57 0.900 12 -4.7 24 75 26 11.5 196 0.930 392 100 8492 183 4 51 36.3 0.728 89 282 745 330.73 17.26 12 78 337
15.000 3780 88 4 27 -3.1 57 0.920 12 -4.7 24 75 26 11.5 196 0.920 392 100 8492 183 4 51 36.3 0.728 89 282 750 330.73 17.26 12 78 337
15.050 3780 88 4 27 -3.1 57 0.920 12 -4.7 24 75 26 11.8 196 0.920 392 100 9049 183 4 51 37.2 0.728 89 282 756 330.73 17.26 12 78 337
15.100 3780 88 4 27 -3.1 57 0.920 12 -4.7 24 75 26 11.8 196 0.920 394 100 9049 183 4 51 37.2 0.728 89 284 761 330.73 17.39 12 78 337
15.150 3780 88 4 27 -3.1 57 0.920 12 -4.7 23 76 26 11.8 196 0.920 394 100 9049 171 4 47 37.2 0.680 89 284 767 330.73 17.39 12 72 337
15.200 3831 88 4 27 -3.1 57 0.920 12 -4.7 23 76 26 11.8 196 0.920 394 100 9049 171 4 47 37.7 0.671 89 288 773 335.20 17.63 12 71 337
15.250 3831 88 4 27 -3.1 57 0.920 12 -4.7 23 76 26 11.8 196 0.930 394 100 9049 171 4 47 37.7 0.671 89 288 778 335.20 17.63 12 71 337
15.300 3831 88 4 27 -3.1 57 0.920 12 -4.7 23 76 26 11.8 196 0.930 394 100 8849 171 4 47 37.7 0.671 89 288 784 335.20 17.63 12 71 337
15.350 3831 88 4 27 -3.1 57 0.920 12 -4.7 23 76 26 11.8 196 0.930 399 100 8849 171 4 47 37.7 0.671 89 291 789 335.20 17.82 12 71 337
15.400 3831 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.8 196 0.930 399 100 8849 182 4 50 37.7 0.711 89 291 795 335.20 17.82 12 76 337
15.450 3904 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.8 196 0.930 399 100 8849 182 4 50 38.4 0.698 89 296 801 341.58 18.16 12 74 337
15.500 3904 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.8 196 0.920 399 100 8849 182 4 50 38.4 0.698 89 296 806 341.58 18.16 12 74 337
15.550 3904 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.9 196 0.920 399 100 8629 182 4 50 38.6 0.698 89 296 812 341.58 18.16 12 74 337
15.600 3904 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.9 196 0.920 400 100 8629 182 4 50 38.6 0.698 89 297 818 341.58 18.22 12 74 337
15.650 3904 88 4 28 -3.1 57 0.920 12 -4.7 24 77 26 11.9 196 0.920 400 100 8629 182 4 50 38.6 0.698 89 297 823 341.58 18.22 12 74 337
15.700 3904 88 4 28 -3.1 57 0.920 12 -4.7 23 78 26 11.9 196 0.920 400 100 8629 176 4 49 38.6 0.678 89 297 829 341.58 18.22 12 72 337
15.750 3940 88 4 28 -3.1 57 0.920 12 -4.7 23 78 26 11.9 196 0.920 400 100 8629 176 4 49 39.0 0.672 89 300 835 344.73 18.39 12 72 337
15.800 3940 88 4 28 -3.1 57 0.920 12 -4.7 23 78 26 11.9 196 0.930 400 100 8629 176 4 49 39.0 0.672 89 300 840 344.73 18.39 12 72 337
15.850 3940 88 4 28 -3.1 57 0.920 12 -4.7 23 78 26 12.1 196 0.930 400 100 8978 176 4 49 39.7 0.672 89 300 846 344.73 18.39 12 72 337
15.900 3940 88 4 28 -3.1 57 0.920 12 -4.7 23 78 26 12.1 196 0.930 403 100 8978 176 4 49 39.7 0.672 89 302 852 344.73 18.50 12 72 337
15.950 3940 88 4 29 -3.1 57 0.920 12 -4.7 27 79 27 12.1 196 0.930 403 100 8978 205 3 57 39.7 0.781 90 302 858 344.73 18.50 11 83 337
16.000 4015 88 4 29 -3.1 57 0.920 12 -4.7 27 79 27 12.1 196 0.930 403 100 8978 205 3 57 40.4 0.767 90 308 863 351.27 18.85 11 82 337
16.050 4015 88 4 29 -3.1 57 0.920 12 -4.7 27 79 27 12.1 196 0.920 403 100 8978 205 3 57 40.4 0.767 90 308 869 351.27 18.85 11 82 337
16.100 4015 88 4 29 -3.1 57 0.920 12 -4.7 27 79 27 12.1 196 0.920 403 100 9324 205 3 57 40.3 0.767 90 308 875 351.27 18.85 11 82 337
16.150 4015 88 4 29 -3.1 57 0.920 12 -4.7 27 79 27 12.1 196 0.920 403 100 9324 205 3 57 40.3 0.767 90 308 881 351.27 18.85 11 82 337
16.200 4015 88 4 29 -3.1 57 0.920 12 -4.7 29 80 26 12.1 196 0.920 403 100 9324 219 4 60 40.3 0.817 88 308 887 351.27 18.85 13 87 337
16.250 4061 88 4 29 -3.1 57 0.920 12 -4.7 29 80 26 12.1 196 0.920 403 100 9324 219 4 60 40.8 0.807 88 311 892 355.32 19.07 13 86 337
16.300 4061 88 4 29 -3.1 57 0.920 12 -4.7 29 80 26 12.1 196 0.920 403 100 9324 219 4 60 40.8 0.807 88 311 898 355.32 19.07 13 86 337
16.350 4061 88 4 29 -3.1 57 0.920 12 -4.7 29 80 26 12.2 196 0.920 403 100 8771 219 4 60 41.1 0.807 88 311 904 355.32 19.07 13 86 337
16.400 4061 88 4 29 -3.1 57 0.920 12 -4.7 29 80 26 12.2 196 0.920 409 100 8771 219 4 60 41.1 0.807 88 317 910 355.32 19.40 13 86 337
16.450 4061 88 4 30 -3.1 57 0.920 12 -4.7 26 81 27 12.2 196 0.920 409 100 8771 194 3 53 41.1 0.715 90 317 916 355.32 19.40 11 76 337
16.500 4132 88 4 30 -3.1 57 0.920 12 -4.7 26 81 27 12.2 196 0.920 409 100 8771 194 3 53 41.8 0.703 90 322 922 361.53 19.74 11 75 337
16.550 4132 88 4 30 -3.1 57 0.910 12 -4.7 26 81 27 12.2 196 0.920 409 100 8771 194 3 53 41.8 0.703 90 322 928 361.53 19.74 11 75 337
16.600 4132 88 4 30 -3.1 57 0.910 12 -4.7 26 81 27 12.4 196 0.920 409 100 9324 194 3 53 42.7 0.703 90 322 934 361.53 19.74 11 75 337
16.650 4132 88 4 30 -3.1 57 0.910 12 -4.7 26 81 27 12.4 196 0.920 413 100 9324 194 3 53 42.7 0.703 90 325 940 361.53 19.92 11 75 337
16.700 4132 88 4 30 -3.1 57 0.910 12 -4.7 25 83 26 12.4 196 0.920 413 100 9324 192 4 53 42.7 0.696 89 325 946 361.53 19.92 12 74 337
16.750 4178 88 4 30 -3.1 57 0.910 12 -4.7 25 83 26 12.4 196 0.920 413 100 9324 192 4 53 43.2 0.688 89 329 952 365.60 20.14 12 73 337
16.800 4178 88 4 30 -3.1 57 0.910 12 -4.7 25 83 26 12.4 196 0.930 413 100 9324 192 4 53 43.2 0.688 89 329 958 365.60 20.14 12 73 337
16.850 4178 88 4 30 -3.1 57 0.910 13 -4.7 25 83 26 12.6 196 0.930 413 100 9422 192 4 53 43.7 0.688 89 329 964 365.60 20.14 12 73 337
16.900 4178 88 4 30 -3.1 57 0.910 13 -4.7 25 83 26 12.6 196 0.930 418 100 9422 192 4 53 43.7 0.688 89 333 970 365.60 20.40 12 73 337
16.950 4178 88 4 29 -3.1 57 0.910 13 -4.7 26 83 26 12.6 196 0.930 418 100 9422 194 4 53 43.7 0.695 89 333 976 365.60 20.40 12 74 337
17.000 4234 88 4 29 -3.1 57 0.910 13 -4.7 26 83 26 12.6 196 0.930 418 100 9422 194 4 53 44.3 0.686 89 337 982 370.50 20.67 12 73 337
17.050 4234 88 4 29 -3.1 57 0.910 13 -4.7 26 83 26 12.6 196 0.920 418 100 9422 194 4 53 44.3 0.686 89 337 988 370.50 20.67 12 73 337
17.100 4234 88 4 29 -3.1 57 0.910 13 -4.7 26 83 26 12.6 196 0.920 418 100 9557 194 4 53 44.5 0.686 89 337 995 370.50 20.67 12 73 337
17.150 4234 88 4 29 -3.1 57 0.910 13 -4.7 26 83 26 12.6 196 0.920 423 100 9557 194 4 53 44.5 0.686 89 341 1001 370.50 20.90 12 73 337
17.200 4234 88 4 29 -3.1 57 0.910 13 -4.7 26 85 27 12.6 196 0.920 423 100 9557 197 3 54 44.5 0.697 90 341 1007 370.50 20.90 11 74 337
17.250 4306 88 4 29 -3.1 57 0.910 13 -4.7 26 85 27 12.6 196 0.920 423 100 9557 197 3 54 45.2 0.686 90 347 1013 376.73 21.25 11 73 337
17.300 4306 88 4 29 -3.1 57 0.910 13 -4.7 26 85 27 12.6 196 0.920 423 100 9557 197 3 54 45.2 0.686 90 347 1019 376.73 21.25 11 73 337
17.350 4306 88 4 29 -3.1 57 0.910 13 -4.7 26 85 27 12.8 196 0.920 423 100 9334 197 3 54 45.9 0.686 90 347 1026 376.73 21.25 11 73 337
17.400 4306 88 4 29 -3.1 57 0.910 13 -4.7 26 85 27 12.8 196 0.920 431 100 9334 197 3 54 45.9 0.686 90 354 1032 376.73 21.66 11 73 337
17.450 4306 88 4 29 -3.1 57 0.910 13 -4.7 33 86 26 12.8 196 0.920 431 100 9334 252 4 70 45.9 0.877 88 354 1038 376.73 21.66 13 94 337
17.500 4344 88 4 29 -3.1 57 0.910 13 -4.7 33 86 26 12.8 196 0.920 431 100 9334 252 4 70 46.3 0.870 88 357 1044 380.08 21.86 13 93 337
17.550 4344 88 4 29 -3.1 57 0.900 13 -4.7 33 86 26 12.8 196 0.920 431 100 9334 252 4 70 46.3 0.870 88 357 1051 380.08 21.86 13 93 337
17.600 4344 88 4 29 -3.1 57 0.900 13 -4.7 33 86 26 13.0 196 0.920 431 100 9039 252 4 70 46.9 0.870 88 357 1057 380.08 21.86 13 93 337
17.650 4344 88 4 29 -3.1 57 0.900 13 -4.7 33 86 26 13.0 196 0.920 436 100 9039 252 4 70 46.9 0.870 88 361 1063 380.08 22.10 13 93 337
17.700 4344 88 4 29 -3.1 57 0.900 13 -4.7 34 87 26 13.0 196 0.920 436 100 9039 255 4 70 46.9 0.879 88 361 1070 380.08 22.10 13 94 337
17.750 4398 88 4 29 -3.1 57 0.900 13 -4.7 34 87 26 13.0 196 0.920 436 100 9039 255 4 70 47.5 0.869 88 365 1076 384.81 22.38 13 93 337
17.800 4398 88 4 29 -3.1 57 0.890 13 -4.7 34 87 26 13.0 196 0.920 436 100 9039 255 4 70 47.5 0.869 88 365 1082 384.81 22.38 13 93 337
17.850 4398 88 4 29 -3.1 57 0.890 13 -4.7 34 87 26 13.1 196 0.920 436 100 9768 255 4 70 47.9 0.869 88 365 1089 384.81 22.38 13 93 337
17.900 4398 88 4 29 -3.1 57 0.890 13 -4.7 34 87 26 13.1 196 0.920 435 100 9768 255 4 70 47.9 0.869 88 364 1095 384.81 22.31 13 93 337
17.950 4398 88 4 -3.1 57 0.890 13 -4.7 31 88 26 13.1 196 0.920 435 100 9768 237 4 66 47.9 0.810 88 364 1102 384.81 22.31 13 86 337
18.000 4363 88 4 -3.1 57 0.890 13 -4.7 31 88 26 13.1 196 0.920 435 100 9768 237 4 66 47.5 0.816 88 361 1108 381.76 22.13 13 87 337
18.050 4363 88 4 -3.1 57 0.910 13 -4.7 31 88 26 13.1 196 0.920 435 100 9768 237 4 66 47.5 0.816 88 361 1115 381.76 22.13 13 87 337
18.100 4363 88 4 -3.1 57 0.910 13 -4.7 31 88 26 13.1 196 0.920 435 100 9696 237 4 66 47.7 0.816 88 361 1121 381.76 22.13 13 87 337
18.150 4363 88 4 -3.1 57 0.910 13 -4.7 31 88 26 13.1 196 0.920 281 100 9696 237 4 66 47.7 0.816 88 234 1128 381.76 14.32 13 87 337
18.200 4363 88 4 -3.1 57 0.910 13 -4.7 31 88 26 13.1 196 0.920 281 100 9696 237 4 66 47.7 0.816 88 234 1134 381.76 14.32 13 87 337
18.250 4363 88 4 6 -3.1 57 0.910 13 -4.7 23 88 26 13.1 196 0.920 281 100 9696 171 4 47 47.7 0.589 89 234 1140 381.76 14.32 12 63 337
18.300 3601 88 4 6 -3.1 57 0.910 13 -4.7 23 88 26 13.1 196 0.920 281 100 9696 171 4 47 39.4 0.714 89 193 1147 315.07 11.82 12 76 337
18.350 3601 88 4 6 -3.1 57 0.920 13 -4.7 23 88 26 13.1 196 0.930 281 90 9696 171 4 47 39.4 0.714 89 193 1153 315.07 11.82 12 76 337
18.400 3601 88 4 6 -3.1 57 0.920 11 -4.7 23 88 26 10.9 196 0.930 281 90 8316 171 4 47 32.6 0.714 89 193 1160 315.07 11.82 12 76 337
18.450 3601 88 4 6 -3.1 57 0.920 11 -4.7 23 88 26 10.9 196 0.930 281 90 8316 171 4 47 32.6 0.714 89 193 1166 315.07 11.82 12 76 337
18.500 3601 88 4 28 -3.1 57 0.920 11 -4.7 20 89 27 10.9 196 0.930 281 90 8316 150 3 41 32.6 0.625 91 193 1173 315.07 11.82 10 67 337
18.550 3415 88 4 28 -3.1 57 0.920 11 -4.7 20 89 27 10.9 196 0.930 281 90 8316 150 3 41 30.9 0.659 91 183 1179 298.80 11.21 10 70 337
18.600 3415 88 4 28 -3.1 57 0.890 11 -4.7 20 89 27 10.9 196 0.910 281 100 8316 150 3 41 30.9 0.659 91 183 1186 298.80 11.21 10 70 337
18.650 3415 88 4 28 -3.1 57 0.890 11 -4.7 20 89 27 11.0 196 0.910 281 100 8105 150 3 41 31.2 0.659 91 183 1192 298.80 11.21 10 70 337
18.700 3415 88 4 28 -3.1 57 0.890 11 -4.7 20 89 27 11.0 196 0.910 378 100 8105 150 3 41 31.2 0.659 91 245 1199 298.80 15.04 10 70 337
18.750 3415 88 4 28 -3.1 57 0.890 11 -4.7 21 89 27 11.0 196 0.910 378 100 8105 157 3 43 31.2 0.691 90 245 1205 298.80 15.04 11 74 337
18.800 3416 88 4 28 -3.1 57 0.890 11 -4.7 21 89 27 11.0 196 0.910 378 100 8105 157 3 43 31.3 0.690 90 246 1212 298.88 15.04 11 74 337
18.850 3416 88 4 28 -3.1 57 0.910 11 -4.7 21 89 27 11.0 196 0.910 378 91 8105 157 3 43 31.3 0.690 90 246 1218 298.88 15.04 11 74 337
18.900 3416 88 4 28 -3.1 57 0.910 11 -4.7 21 89 27 11.0 196 0.910 378 91 8456 157 3 43 31.3 0.690 90 246 1225 298.88 15.04 11 74 337
18.950 3416 88 4 28 -3.1 57 0.910 11 -4.7 21 89 27 11.0 196 0.910 377 91 8456 157 3 43 31.3 0.690 90 245 1231 298.88 15.01 11 74 337
19.000 3416 88 4 28 -3.1 57 0.910 11 -4.7 21 90 27 11.0 196 0.910 377 91 8456 161 3 44 31.3 0.708 90 245 1238 298.88 15.01 11 75 337
19.050 3440 88 4 28 -3.1 57 0.910 11 -4.7 21 90 27 11.0 196 0.910 377 91 8456 161 3 44 31.5 0.703 90 247 1245 301.03 15.12 11 75 337
19.100 3440 88 4 28 -3.1 57 0.900 11 -4.7 21 90 27 11.0 196 0.900 377 98 8456 161 3 44 31.5 0.703 90 247 1251 301.03 15.12 11 75 337
19.150 3440 88 4 28 -3.1 57 0.900 11 -4.7 21 90 27 11.0 196 0.900 377 98 8154 161 3 44 31.5 0.703 90 247 1258 301.03 15.12 11 75 337
19.200 3440 88 4 28 -3.1 57 0.900 11 -4.7 21 90 27 11.0 196 0.900 377 98 8154 161 3 44 31.5 0.703 90 247 1264 301.03 15.14 11 75 337
19.250 3440 88 4 28 -3.1 57 0.900 11 -4.7 23 91 27 11.0 196 0.900 377 98 8154 170 3 47 31.5 0.742 90 247 1271 301.03 15.14 11 79 337
19.300 3477 88 4 28 -3.1 57 0.900 11 -4.7 23 91 27 11.0 196 0.900 377 98 8154 170 3 47 31.9 0.734 90 250 1278 304.19 15.30 11 78 337
19.350 3477 88 4 28 -3.1 57 0.890 11 -4.7 23 91 27 11.0 196 0.920 377 99 8154 170 3 47 31.9 0.734 90 250 1285 304.19 15.30 11 78 337
19.400 3477 88 4 28 -3.1 57 0.890 11 -4.7 23 91 27 11.0 196 0.920 377 99 8376 170 3 47 32.0 0.734 90 250 1291 304.19 15.30 11 78 337
19.450 3477 88 4 28 -3.1 57 0.890 11 -4.7 23 91 27 11.0 196 0.920 378 99 8376 170 3 47 32.0 0.734 90 250 1298 304.19 15.33 11 78 337
19.500 3477 88 4 28 -3.1 57 0.890 11 -4.7 20 92 27 11.0 196 0.920 378 99 8376 149 3 41 32.0 0.643 90 250 1305 304.19 15.33 11 69 337
19.550 3497 88 4 28 -3.1 57 0.890 11 -4.7 20 92 27 11.0 196 0.920 378 99 8376 149 3 41 32.1 0.639 90 252 1311 305.97 15.42 11 68 337
19.600 3497 88 4 28 -3.1 57 0.880 11 -4.7 20 92 27 11.0 196 0.910 378 100 8376 149 3 41 32.1 0.639 90 252 1318 305.97 15.42 11 68 337
19.650 3497 88 4 28 -3.1 57 0.880 11 -4.7 20 92 27 11.1 196 0.910 378 100 8255 149 3 41 32.2 0.639 90 252 1325 305.97 15.42 11 68 337
19.700 3497 88 4 28 -3.1 57 0.880 11 -4.7 20 92 27 11.1 196 0.910 379 100 8255 149 3 41 32.2 0.639 90 252 1332 305.97 15.47 11 68 337
19.750 3497 88 4 28 -3.1 57 0.880 11 -4.7 24 93 26 11.1 196 0.910 379 100 8255 181 4 50 32.2 0.777 89 252 1338 305.97 15.47 12 83 337
19.800 3524 88 4 28 -3.1 57 0.880 11 -4.7 24 93 26 11.1 196 0.910 379 100 8255 181 4 50 32.5 0.771 89 254 1345 308.31 15.58 12 82 337
19.850 3524 88 4 28 -3.1 57 0.900 11 -4.7 24 93 26 11.1 196 0.910 379 92 8255 181 4 50 32.5 0.771 89 254 1352 308.31 15.58 12 82 337
19.900 3524 88 4 28 -3.1 57 0.900 11 -4.7 24 93 26 11.1 196 0.910 379 92 8528 181 4 50 32.6 0.771 89 254 1359 308.31 15.58 12 82 337
19.950 3524 88 4 28 -3.1 57 0.900 11 -4.7 24 93 26 11.1 196 0.910 380 92 8528 181 4 50 32.6 0.771 89 255 1366 308.31 15.60 12 82 337
20.000 3524 88 4 28 -3.1 57 0.900 11 -4.7 22 93 27 11.1 196 0.910 380 92 8528 165 3 46 32.6 0.704 90 255 1373 308.31 15.60 11 75 337
20.050 3550 88 4 28 -3.1 57 0.900 11 -4.7 22 93 27 11.1 196 0.910 380 92 8528 165 3 46 32.8 0.699 90 257 1379 310.61 15.72 11 74 337
20.100 3550 88 4 28 -3.1 57 0.910 11 -4.7 22 93 27 11.1 196 0.920 380 91 8528 165 3 46 32.8 0.699 90 257 1386 310.61 15.72 11 74 337
20.150 3550 88 4 28 -3.1 57 0.910 11 -4.7 22 93 27 11.2 196 0.920 380 91 8492 165 3 46 33.1 0.699 90 257 1393 310.61 15.72 11 74 337
20.200 3550 88 4 28 -3.1 57 0.910 11 -4.7 22 93 27 11.2 196 0.920 382 91 8492 165 3 46 33.1 0.699 90 258 1400 310.61 15.81 11 74 337
20.250 3550 88 4 27 -3.1 57 0.910 11 -4.7 22 94 27 11.2 196 0.920 382 91 8492 169 3 47 33.1 0.712 90 258 1407 310.61 15.81 11 76 337
20.300 3579 88 4 27 -3.1 57 0.910 11 -4.7 22 94 27 11.2 196 0.920 382 91 8492 169 3 47 33.3 0.707 90 260 1414 313.16 15.94 11 75 337
20.350 3579 88 4 27 -3.1 57 0.910 11 -4.7 22 94 27 11.2 196 0.910 382 91 8492 169 3 47 33.3 0.707 90 260 1420 313.16 15.94 11 75 337
20.400 3579 88 4 27 -3.1 57 0.910 11 -4.7 22 94 27 11.2 196 0.910 382 91 8629 169 3 47 33.4 0.707 90 260 1427 313.16 15.94 11 75 337
20.450 3579 88 4 27 -3.1 57 0.910 11 -4.7 22 94 27 11.2 196 0.910 382 91 8629 169 3 47 33.4 0.707 90 260 1434 313.16 15.96 11 75 337
20.500 3579 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.910 382 91 8629 170 3 47 33.4 0.713 90 260 1441 313.16 15.96 11 76 337
20.550 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.910 382 91 8629 170 3 47 33.6 0.708 90 262 1448 315.38 16.07 11 75 337
20.600 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.920 382 100 8629 170 3 47 33.6 0.708 90 262 1455 315.38 16.07 11 75 337
20.650 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.920 382 100 8658 170 3 47 33.7 0.708 90 262 1462 315.38 16.07 11 75 337
20.700 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.920 383 100 8658 170 3 47 33.7 0.708 90 263 1469 315.38 16.09 11 75 337
20.750 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 94 27 11.2 196 0.920 383 100 8658 170 3 47 33.7 0.708 90 263 1476 315.38 16.09 11 75 337
20.800 3604 88 4 27 -3.1 57 0.910 11 -4.7 23 95 27 11.2 196 0.920 383 100 8658 173 3 48 33.7 0.720 90 263 1483 315.38 16.09 11 77 337
20.850 3634 88 4 27 -3.1 57 0.910 11 -4.7 23 95 27 11.2 196 0.920 383 100 8658 173 3 48 33.9 0.714 90 265 1490 317.98 16.22 11 76 337
20.900 3634 88 4 27 -3.1 57 0.910 11 -4.7 23 95 27 11.2 196 0.910 383 93 8658 173 3 48 33.9 0.714 90 265 1497 317.98 16.22 11 76 337
20.950 3634 88 4 27 -3.1 57 0.910 11 -4.7 23 95 27 11.3 196 0.910 383 93 8629 173 3 48 34.3 0.714 90 265 1503 317.98 16.22 11 76 337
21.000 3634 88 4 27 -3.1 57 0.910 11 -4.7 23 95 27 11.3 196 0.910 386 93 8629 173 3 48 34.3 0.714 90 267 1510 317.98 16.35 11 76 337
21.050 3634 88 4 27 -3.1 57 0.910 11 -4.7 23 96 27 11.3 196 0.910 386 93 8629 175 3 48 34.3 0.721 90 267 1517 317.98 16.35 11 77 337
21.100 3665 88 4 27 -3.1 57 0.910 11 -4.7 23 96 27 11.3 198 0.910 386 93 8629 175 3 48 34.6 0.715 90 269 1525 320.64 16.49 11 76 337
21.150 3665 88 4 27 -3.1 57 0.910 11 -4.7 23 96 27 11.3 198 0.910 386 94 8629 175 3 48 34.6 0.715 90 269 1532 320.64 16.49 11 76 337
21.200 3665 88 4 27 -3.1 57 0.910 11 -4.7 23 96 27 11.3 198 0.910 386 94 8658 175 3 48 34.6 0.715 90 269 1539 320.64 16.49 11 76 337
21.250 3665 88 4 27 -3.1 57 0.910 11 -4.7 23 96 27 11.3 198 0.910 386 94 8658 175 3 48 34.6 0.715 90 269 1546 320.64 16.49 11 76 337
21.300 3665 88 4 27 -3.1 57 0.910 11 -4.7 26 97 26 11.3 198 0.910 386 94 8658 196 4 54 34.6 0.800 89 269 1553 320.64 16.49 12 85 337
21.350 3681 88 4 27 -3.1 57 0.910 11 -4.7 26 97 26 11.3 198 0.910 386 94 8658 196 4 54 34.8 0.797 89 270 1560 322.09 16.56 12 85 337
21.400 3681 88 4 27 -3.1 57 0.900 11 -4.7 26 97 26 11.3 198 0.910 386 88 8658 196 4 54 34.8 0.797 89 270 1567 322.09 16.56 12 85 337
21.450 3681 88 4 27 -3.1 57 0.900 11 -4.7 26 97 26 11.4 198 0.910 386 88 8658 196 4 54 34.9 0.797 89 270 1574 322.09 16.56 12 85 337
21.500 3681 88 4 27 -3.1 57 0.900 11 -4.7 26 97 26 11.4 198 0.910 386 88 8658 196 4 54 34.9 0.797 89 270 1581 322.09 16.56 12 85 337
21.550 3681 88 4 27 -3.1 57 0.900 11 -4.7 21 98 27 11.4 198 0.910 386 88 8658 157 3 43 34.9 0.641 90 270 1588 322.09 16.56 11 68 337
21.600 3712 88 4 27 -3.1 57 0.900 11 -4.7 21 98 27 11.4 198 0.910 386 88 8658 157 3 43 35.2 0.635 90 273 1596 324.83 16.71 11 68 337
21.650 3712 88 4 27 -3.1 57 0.890 11 -4.7 21 98 27 11.4 198 0.910 386 98 8658 157 3 43 35.2 0.635 90 273 1603 324.83 16.71 11 68 337
21.700 3712 88 4 27 -3.1 57 0.890 11 -4.7 21 98 27 11.4 198 0.910 386 98 8412 157 3 43 35.4 0.635 90 273 1610 324.83 16.71 11 68 337
21.750 3712 88 4 27 -3.1 57 0.890 11 -4.7 21 98 27 11.4 198 0.910 389 98 8412 157 3 43 35.4 0.635 90 275 1617 324.83 16.83 11 68 337
21.800 3712 88 4 27 -3.1 57 0.890 11 -4.7 24 98 27 11.4 198 0.910 389 98 8412 178 3 49 35.4 0.720 90 275 1624 324.83 16.83 11 77 337
21.850 3731 88 4 27 -3.1 57 0.890 11 -4.7 24 98 27 11.4 198 0.910 389 98 8412 178 3 49 35.5 0.716 90 276 1632 326.49 16.92 11 76 337
21.900 3731 88 4 27 -3.1 57 0.900 11 -4.7 24 98 27 11.4 198 0.910 389 100 8412 178 3 49 35.5 0.716 90 276 1639 326.49 16.92 11 76 337
21.950 3731 88 4 27 -3.1 57 0.900 12 -4.7 24 98 27 11.5 198 0.910 389 100 9049 178 3 49 35.8 0.716 90 276 1646 326.49 16.92 11 76 337
22.000 3731 88 4 27 -3.1 57 0.900 12 -4.7 24 98 27 11.5 198 0.910 390 100 9049 178 3 49 35.8 0.716 90 277 1653 326.49 16.97 11 76 337
22.050 3731 88 4 27 -3.1 57 0.900 12 -4.7 24 99 27 11.5 198 0.910 390 100 9049 180 3 50 35.8 0.723 90 277 1660 326.49 16.97 11 77 337
22.100 3758 88 4 27 -3.1 57 0.900 12 -4.7 24 99 27 11.5 198 0.910 390 100 9049 180 3 50 36.0 0.718 90 279 1668 328.85 17.09 11 77 337
22.150 3758 88 4 27 -3.1 57 0.910 12 -4.7 24 99 27 11.5 198 0.910 390 99 9049 180 3 50 36.0 0.718 90 279 1675 328.85 17.09 11 77 337
22.200 3758 88 4 27 -3.1 57 0.910 12 -4.7 24 99 27 11.6 198 0.910 390 99 8403 180 3 50 36.2 0.718 90 279 1682 328.85 17.09 11 77 337
22.250 3758 88 4 27 -3.1 57 0.910 12 -4.7 24 99 27 11.6 198 0.910 393 99 8403 180 3 50 36.2 0.718 90 281 1689 328.85 17.23 11 77 337
22.300 3758 88 4 27 -3.1 57 0.910 12 -4.7 27 99 27 11.6 198 0.910 393 99 8403 206 3 57 36.2 0.822 90 281 1697 328.85 17.23 11 88 337
22.350 3794 88 4 27 -3.1 57 0.910 12 -4.7 27 99 27 11.6 198 0.910 393 99 8403 206 3 57 36.6 0.814 90 284 1704 332.00 17.39 11 87 337
22.400 3794 88 4 27 -3.1 57 0.910 12 -4.7 27 99 27 11.6 198 0.910 393 100 8403 206 3 57 36.6 0.814 90 284 1711 332.00 17.39 11 87 337
22.450 3794 88 4 27 -3.1 57 0.910 12 -4.7 27 99 27 11.7 198 0.910 393 100 8849 206 3 57 36.9 0.814 90 284 1718 332.00 17.39 11 87 337
22.500 3794 88 4 27 -3.1 57 0.910 12 -4.7 27 99 27 11.7 198 0.910 395 100 8849 206 3 57 36.9 0.814 90 285 1726 332.00 17.47 11 87 337
22.550 3794 88 4 27 -3.1 57 0.910 12 -4.7 22 100 27 11.7 198 0.910 395 100 8849 168 3 46 36.9 0.662 90 285 1733 332.00 17.47 11 71 337
22.600 3823 88 4 27 -3.1 57 0.910 12 -4.7 22 100 27 11.7 198 0.910 395 100 8849 168 3 46 37.2 0.657 90 287 1740 334.54 17.60 11 70 337
22.650 3823 88 4 27 -3.1 57 0.900 12 -4.7 22 100 27 11.7 198 0.920 395 100 8849 168 3 46 37.2 0.657 90 287 1748 334.54 17.60 11 70 337
22.700 3823 88 4 27 -3.1 57 0.900 12 -4.7 22 100 27 11.6 198 0.920 395 100 8743 168 3 46 37.1 0.657 90 287 1755 334.54 17.60 11 70 337
22.750 3823 88 4 27 -3.1 57 0.900 12 -4.7 22 100 27 11.6 198 0.920 394 100 8743 168 3 46 37.1 0.657 90 287 1762 334.54 17.58 11 70 337
22.800 3823 88 4 27 -3.1 57 0.900 12 -4.7 25 101 27 11.6 198 0.920 394 100 8743 188 3 52 37.1 0.739 90 287 1770 334.54 17.58 11 79 337
22.850 3834 88 4 27 -3.1 57 0.900 12 -4.7 25 101 27 11.6 198 0.920 394 100 8743 188 3 52 37.2 0.737 90 288 1777 335.46 17.63 11 79 337
22.900 3834 88 4 27 -3.1 57 0.910 12 -4.7 25 101 27 11.6 198 0.920 394 97 8743 188 3 52 37.2 0.737 90 288 1785 335.46 17.63 11 79 337
22.950 3834 88 4 27 -3.1 57 0.910 12 -4.7 25 101 27 11.8 198 0.920 394 97 8565 188 3 52 37.6 0.737 90 288 1792 335.46 17.63 11 79 337
23.000 3834 88 4 27 -3.1 57 0.910 12 -4.7 25 101 27 11.8 198 0.920 397 97 8565 188 3 52 37.6 0.737 90 290 1799 335.46 17.76 11 79 337
23.050 3834 88 4 27 -3.1 57 0.910 12 -4.7 26 102 27 11.8 198 0.920 397 97 8565 200 3 55 37.6 0.784 90 290 1807 335.46 17.76 11 84 337
23.100 3871 88 4 27 -3.1 57 0.910 12 -4.7 26 102 27 11.8 198 0.920 397 97 8565 200 3 55 37.9 0.776 90 293 1814 338.70 17.93 11 83 337
23.150 3871 88 4 27 -3.1 57 0.900 12 -4.7 26 102 27 11.8 198 0.920 397 100 8565 200 3 55 37.9 0.776 90 293 1822 338.70 17.93 11 83 337
23.200 3871 88 4 27 -3.1 57 0.900 12 -4.7 26 102 27 11.8 198 0.920 397 100 8537 200 3 55 37.9 0.776 90 293 1829 338.70 17.93 11 83 337
23.250 3871 88 4 27 -3.1 57 0.900 12 -4.7 26 102 27 11.8 198 0.920 396 100 8537 200 3 55 37.9 0.776 90 292 1837 338.70 17.90 11 83 337
23.300 3871 88 4 27 -3.1 57 0.900 12 -4.7 26 102 27 11.8 198 0.920 396 100 8537 200 3 55 37.9 0.776 90 292 1844 338.70 17.90 11 83 337
23.350 3871 88 4 28 -3.1 57 0.900 12 -4.7 26 103 27 11.8 198 0.920 396 100 8537 195 3 54 37.9 0.755 90 292 1852 338.70 17.90 11 81 337
23.400 3896 88 4 28 -3.1 57 0.900 12 -4.7 26 103 27 11.8 198 0.920 396 100 8537 195 3 54 38.2 0.750 90 294 1859 340.86 18.02 11 80 337
23.450 3896 88 4 28 -3.1 57 0.900 12 -4.7 26 103 27 11.8 198 0.920 396 89 8537 195 3 54 38.2 0.750 90 294 1867 340.86 18.02 11 80 337
23.500 3896 88 4 28 -3.1 57 0.900
#2098 - 11/11/07 08:03 PM Re: LG Motorsports [Re: teamzr1]
barkingowl
JR what is the point of LG not being helpful after they f'k up someone's car? I'd be thinking that they'd be losing customers right & left.
#2102 - 11/11/07 08:53 PM Re: LG Motorsports [Re: ]
They can care less since they hype themselves on many forums so due to volume of people they get off the forums and the forums preventing negative content of those who paid those monthly supportng vendor fees and got screwed over by those vendors they have a long list of new customers.
The fact they grind off the vendor and model on CAM shows they did not make the CAM and think somehow they are holding some secret power grind when someone smart would have the CAM measured and find what the grind values are.
In the long run sooner or later the value springs need to be changed as to use and age and car owner is fucked since he has no idea what CAM grind is or if he wanted to try another CAM he has no idea what is now in car so how does he know what different grind to use.
In any case this 2007 A6 C6 the shop owner drove the car 350 miles to get home and says after the PCM and TCM relearned the tunes of ours for both are now correct and car drives well.
#2106 - 11/12/07 03:32 PM Re: LG Motorsports [Re: teamzr1]
Here is a good example when the wrong selection of CAM grind
Stock 2007 C6 on the bottom of these collected scanner data traps.
Notice this modified 2007 ( top data stream) mentioned in this thread how much vaccum is lost at idle and thus a domino effect to all other engine functions.
Compare the functions and their values.
#2107 - 11/12/07 04:16 PM Re: LG Motorsports [Re: teamzr1]
Here is where mods make an effect and that is at upper engine loads.
The mods itself would be useless without a good custom tuning as you notice the modified 2007 C6 has higher timing due to the tune.
Notice the torque and horsepower flywheel levels
#2108 - 11/12/07 04:46 PM Re: LG Motorsports [Re: teamzr1]
Gregory T. Lloyd, DVM
great demonstration! Way too cool!
#2934 - 12/18/08 02:46 PM Re: LG Motorsports [Re: ]
Here is what the $2,000 LG headers look like over time
Also the bung for the O2 sensor weld is junk and leaking
Great high quality metal used puke
1 registered members (teamzr1), 103 guests, and 7 spiders.
