Document ID# 2038016
Subject: Center High Mount Stop Lamp Illuminates Dim All The Time - keywords apply battery CHMSL connector corrosion light mount rear stop terminal water #PIC4426A - (11/13/2007)
Models: 2005-2008 Chevrolet Corvette
Condition/Concern:
Some customers may comment that the Center High Mount Stop Lamp (CHMSL) may illuminate DIM with out brake application. With the CHMSL illuminated all the time, this could lead to a battery drain concern. This may be the result of water intrusion to the C455 connector.
Recommendation/Instructions:
Inspect for water intrusion at the C455 connector behind the right rear tail lamp. Dry out the connector, repair any damaged terminals, reroute the connector to avoid water intrusion and coat terminals with dielectric grease to prevent corrosion.
