Document ID# 2008455
Subject: Air Bag Indicator On - keywords B0033 B0040 B0023 B0016 B0022 B0042 B0012 B0013 B0019 B0020 connector driver lamp light passenger restraints roof side sir sdm wire #PIT4011F - (08/30/2007)
Models: 2006-2008 Chevrolet Corvette
Condition/Concern:
You may experience an intermittent or current SIR indicator on the Instrument Panel Cluster (IPC) with DTC B0012 0E, b0013 0E, b0016 0E, b0019 0E, b0020 0E, b0022, b0023 0E, B0033 0E, B0040 0E, or B0042 set in the sensing and diagnostic module (SDM).
Note: This PI only applies to the DTCs as listed above. Example, if you have a dtc B0022 symptom 0D, this pi DOES NOT apply because it is only for a B0022. DTCs B0022 and B0042 will not have symptom codes because they are for older models like the Trailblazer, Envoy, etc, and did not use symptom codes.
Recommendation/Instructions:
Inspect for a loose, missing, or broken Connector Position Assurance (CPA) retainer at the air bag for the set dtc. If loose, remove the connector and reinstall correctly by first pushing the connector body in completely and then pushing in the CPA completely.
If the CPA is broken, missing, or will not seat in connector correctly, replace the CPA retainer with part number: 54590003 (Orange CPA) that is located in the connector tray of the terminal repair kit.
Note: If the CPA retainer part number: 54590003 (Orange CPA) can't be located in terminal repair kit, contact Kent Moore Tools @ 1-800-GM-Tools to obtain a new package of 5.
