Document ID# 1911787
2008 Chevrolet Corvette
Immobilizer Operation
This vehicle has a passive theft-deterrent system.
The system is automatically armed when the ignition mode transitions to off.
The immobilization system is disarmed when the ignition mode transitions to OFF/ACCESSORY or START and a valid transmitter is found in the vehicle.
You do not have to manually arm or disarm the system.
The security light comes on if there is a problem with arming or disarming the theft-deterrent system.
The system has one or more keyless access transmitters that are matched to an immobilizer control unit in the vehicle. Only a correctly matched keyless access transmitter starts the vehicle. The vehicle may not start if the keyless access transmitter is damaged.
If the engine does not start and the security light comes on, there may be a problem with the immobilizer system. Press the START button again.
If the vehicle does not start and the keyless access transmitter appears to be undamaged, try another keyless access transmitter. Or, place the transmitter in the transmitter pocket. See "NO FOBS DETECTED" under DIC Warnings and Messages for additional information. Check the fuse. See Fuses and Circuit Breakers .
If the engine still does not start with the other transmitter, the vehicle needs service.
If the engine does start, the first transmitter may be faulty. See your dealer/retailer who can service the theft-deterrent system and have a new keyless access transmitter programmed to the vehicle.
It is possible for the immobilizer system to learn new or replacement keyless access transmitters. Up to four keyless access transmitters can be programmed for the vehicle. To program additional transmitters, see "Matching transmitter(s) to Your Vehicle" under Keyless Access System Operation .
Do not leave the key or device that disarms or deactivates the theft deterrent system in the vehicle.
This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
This device may not cause interference.
This device must accept any interference received, including interference that may cause undesired operation.
This device complies with RSS-210 of Industry Canada. Operation is subject to the following two conditions:
Changes or modifications to this system by other than an authorized service facility could void authorization to use this equipment.
