Document ID# 1877846
2008 Chevrolet Corvette
DTC P1630
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptor
DTC P1630: Theft Deterrent Learn Mode Active
Circuit/System Description
When replacing a remote control door lock receiver (RCDLR), the engine control module (ECM) must learn the new fuel enable password from the replacement RCDLR. If the ECM is replaced with a service replacement part, it is in a functional state to automatically learn the fuel enable password.
If the RCDLR is replaced, the ECM must be placed in learn mode so it can learn the new RCDLR password. This DTC indicates the ECM is in a functional state to learn the RCDLR fuel enable password.
The ECM is in learn mode.
DTC P1630 will set any time the ECM enters learn mode.
The security indicator will illuminate.
Conditions for Clearing the DTC
A current DTC will be cleared upon a successful engine start after exit of learn mode.
A history DTC will be cleared after 100 malfunction-free ignition cycles.
Reference Information
Schematic Reference
Immobilizer Schematics
Connector End View Reference
Component Connector End Views
Description and Operation
Immobilizer Description and Operation
Electrical Information Reference
Circuit Testing
Connector Repairs
Testing for Intermittent Conditions and Poor Connections
Wiring Repairs
Scan Tool Reference
Control Module References for Scan Tool Information
Circuit/System Verification
Perform the 10-Minute Immobilizer Relearn procedure. Refer to Programming Immobilizer System Components . The ECM should successfully complete the password learn and the vehicle should start.
⇒ If the ECM does not complete the learn or vehicle starting remains disabled, replace the ECM.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Control Module References for ECM replacement, setup, and programming
