Make: CHEVROLET
Model: CORVETTE
Affected Year(s): 2005 2006
Units Affected: 6487
TC Recall #: 2005296
Manufacturer:
Campaign Code: 05086
Recall Details
Certain vehicles may have been built with a power steering hose that is not to specification.
Under extreme steering movements, such as turning the steering wheel fully to the left or right while braking, the hose may fracture and leak fluid.
If this were to occur, power steering assist would be lost and increased steering effort would be required. On vehicles equipped with hydro-boost power brakes, it could also result in loss of power brake assist and increase braking effort would be required.
If power steering fluid were to spray onto hot engine parts, an engine compartment fire could occur.
Correction: Dealers will inspect the power steering hose(s) for two suspect date codes and replace them if required.
Make: CHEVROLET
Model: CORVETTE
Units Affected: 693
TC Recall #: 2006123 Manufacturer:
Campaign Code: 06041
Recall Details
On certain vehicles with a painted roof, the adhesive between the roof panel and the frame may separate. As a result, the roof panel may detach from the vehicle and strike a road user, causing injury and property damage.
Correction: Dealers will inspect and, if required, replace the roof.
