Document ID# 2042208
Subject: Unwanted OnStar Turn By Turn Operation At Startup - keywords message navigation onstar OPC TBT turn unwanted #PIC4701 - (12/04/2007)
Models: All 2006 -2008 OnStar® GEN 7 equipped vehicles with Turn by Turn navigation
Condition/Concern:
Some customers may report hearing a message "Navigation Active" upon starting the vehicle following a previous run cycle where OnStar® Turn By Turn Navigation was in use.
Recommendation/Instructions:
If the customer has reached their intended destination using the OnStar® TBT Navigation but did not reach the precise point at that location as recognized by the TBT system, the system will continue to attempt to direct them to that point upon the next key cycle. This typically will occur at locations with large parking lots (Hospitals, malls, etc.).
The customer should hear "You have reached your destination" or similar message when they reach the intended destination. If this is not heard when reaching the end of the route or if the "Navigation Active" message is heard on start up, the customer simply need to press the handfree calling button and after the "OnStar® Ready!" prompt, say "Cancel route!"
For further information on OnStar® Turn By Turn operation the customer should be referred to the OnStar® Gen 7 owners guide (this specific information is found on page 14) in the vehicle or
www.OnStar.com.
