Document ID# 2045696
Condition
Some customers may comment on the airbag light being illuminated. Upon investigation, the technician may find DTC 023 set in the Passenger Presence System (PPS).
Correction
Do This
| Don't Do This
Diagnose and replace right front seatbelt retractor assembly, if necessary.
| Do not replace the passenger presence system.
Verify proper system electrical connections. Inspect the passenger seat belt tension sensor signal, voltage reference, and low reference circuits carefully for cutting and/or chaffing per SI instructions for DTC 023. If all checks have been made and no fault has been found, replace the belt tension sensor.
Important: The seat belt tension sensor is not serviced separately. The seat belt retractor assembly with the tension sensor must be serviced as a complete unit.
Parts Information (excluding Saab U.S. Models)
For part number and usage of seatbelt retractors, see Group 14.875 (cars) or Group 16.714 (trucks) of the appropriate parts catalog.
Parts Information (Saab U.S. Models)
For part number, see Group 16 of the electronic parts catalog (EPC).
Warranty Information (excluding Saab U.S. Models)
For vehicles repaired under warranty, use:
Labor Operation
| Description
| Labor Time
C9040
| Belt, Seatbelt Retractor (Front) (Right) - Replace
| Use Published Labor Operation Time
Add
| Diagnosis Time
| 0.0-0.3 hr
Warranty Information (Saab U.S. Models)
Labor Operation
| Description
| Failed Object
| Fault/Reason Code
| Location Code
| Warranty Type
| Repair/Action Code
| Labor Time
8533103
| 85331
| 67
| 4
| 01
| 01
Add
| Diagnosis Time
| 0.0-0.3 hr in 99 time
