Topics3,664
Posts6,830
Most Online265 Jan 21st, 2023
#2324 - 01/28/08 08:40 PM
How much torque management and shift firmness is safe
mvvette97
This is on my 97 A4 corvette. I bought a PCM for my vette and the guy flashed my VIN and he said he would change things for my mods. He isn't a pro tuner but he seems like he know his stuff. Anyway I just now got to installing the pcm and i thought I would pull the file to just see what he had done. I use EFI Live. What is a safe amount to take away from torque management and to increase shift firmness? I don't know much about it but I was comparing it to a stock file and he did do some changes., thanks Marc
#2326 - 01/28/08 09:39 PM
Re: How much torque management and shift firmness is safe
[Re: teamzr1]
mvvette97
Thanks JR, I just want to make sure this guy has everything set decent so it doesn't tear something up or fry my engine. I just have boltons like headers and stuff. Like I said above the guy isn't a pro tuner but he thinks he know what he is doing, I hope he does. Oh the trans am seems to be running great that you tuned for me. Marc
#2327 - 01/29/08 08:43 AM
[Re: ]
mvvette97
I also was wondering why I don't have a VIN number when I pulled the file, it just says NA
#2329 - 01/29/08 10:30 AM
[Re: teamzr1]
mvvette97
I guess it must not need it, I changed some fan settings and flashed it back in and it ran. It must not need it or something. I had a guy tell me that if the guy that tuned it disabled VATS then I wouldn't need the VIN, you know anything about that? I would like to have ya tune this vette but I'm not sure if it's really worth it since all it has is headers.
#2334 - 02/01/08 09:25 AM
[Re: teamzr1]
Gordon
Pro
Pro
Plymouth, MI 48170
I believe EFILive does not store VIN's for 97 and 98 LS1 engines as they are not VIN specific for those model years. Hear is an EFILive scan file for transmissions setting.
PARAMETER SAE.TP SAE.MAF GM.DYNAIR GM.GEAR GM.TRQENG SAE.ECT SAE.RPM SAE.SPARKADV SAE.IAT SAE.MAP GM.SHIFTLAST GM.TFMPRS GM.KR GM.SHIFTDELAY GM.TCCMODE GM.TCCTIME GM.TCCDC SAE.VSS I hope this helps
2000 Nassua Blue FRC 08-468
28
guests, and
7
spiders. |
Admin,
Global Mod,
