#236 - 05/12/02 06:41 AM LS1 Parts List
GM Part numbers for LS1/6 cars
12160244 IAT Sensor
24504388 IAT Sensor Grommet
12480033 Hot Cam Kit
10238852 LS1 Pushrod
12552954 LS1 Timing Chain
12559271 Water Pump Gasket (need 2)
12561244 Front Crank Seal
12557840 Crank Pulley Bolt
12558013 Timing Cover Gasket
12558573 Exhaust manifold gasket
12559188 98-99 AIR tube (one side)
12559189 98-99 AIR tube (other side)
12556643 98-99 EGR tube
12553047 EGR gasket
12553617 AIR tube gasket
12557932 EGR O-ring seal
12560696 Valve Cover Gasket
12565117 LS6 valve springs
12560950 LS6 Camshaft
12568002 LS6 Valley cover
12658010 LS6 PCV kit
88890523 LS6 Intake
12568478 2001 Coolant pipe
12562788 2001 Coolant plug
12560744 "M-11" Headbolts (need 8/side)
12560745 "M-11" short headbolt (need 2/side)
12558840 OR 12558845 "M-8" Headbolts (need 5/side) *Not sure on which is correct*.
12558809 Head gasket (drivers side)
12558810 Head gasket (pass side)
12556643 98-99 EGR Tube Assembly
12556436 2001 Oil Pump
16238212 Computer (PCM) 1998
12177561 Engine harness 1998 (manual)
25312196 RH O2 sensor
25312197 LH O2 Sensor
12558948 Coil
12560228 Crank Sensor
12560229 Cam sensor
12555424 Belt tensioner
10456603 Knock sensor
9353691 Body Control Mod. (BCM)
15301401 Coil harness
25179711 LS1 MAF
12160244 IAT sensor
12552059 Water pump pulley
25170361 Camaro lower airbox
25179711 00' Mass Air Sensor (whole assembly)
12561269 Intake manifold for 98-00 F-body
88890523 Intake manifold for 01 F-body
12557846 Intake manifold for 98-00 Y-body
88890524 Intake manifold for 01 Y-body(LS1 & LS6)
12560965 Camshaft for 98-00 F-body
12560964 Camshaft for 98-99 Y-body
12560968 Camshaft for 00 Y-body
12561721 Camshaft for 01 F-body & LS1 Y-body
12560950 Camshaft for 01 Y-body LS6
12560194 Left exhaust manifold for 98-99 F-body
12561308 Left exhaust manifold for 98-99 Y-body
12559507 Left exhaust manifold for 00-01 F-body
12562638 Left exhaust manifold for 00 Y-body
12561255 Left exhaust manifold for 01 Y-body LS1
12561256 Left exhaust manifold for 01 Y-body LS6
12560193 Right exhaust manifold for 98-99 F-body
12561309 Right exhaust manifold for 98-99 Y-body
12559506 Right exhaust manifold for 00 F-body
12562639 Right exhaust manifold for 00 Y-body
12567706 Right exhaust manifold for 01 F-body
12561256 Right exhaust manifold for 01 Y-body (LS1 & LS6)
17113390 Throttle body for 98-99 F-body
17113564 Throttle body for 98-99 Y-body
17113647 Throttle body for 00-01 F-body
17113669 Throttle body for 00-01 Y-body (LS1 & LS6)
12533952 Injector for 98 F-body & Y-body
12456154 Injector for 99-00 F-body & Y-body
12482704 Injector for 01 F-body & Y-body (LS1 & LS6)
12558807 Heads for 98 F-body & Y-body
12559855 Heads for 99-01 F-body & Y-body (LS1)
12560801 Heads for 01 Y-body (LS6)
12480033 Hotcam for LS1
Clutch/Transmission/Driveline
12562765 LS1 Flywheel
12560725 Aluminum drive shaft
10085375 1LE Aluminium Driveshaft
12570277 Clutch Master Cyl
12570281 Z06 clutch, pplate, flywheel
12562765 2001 Fbody clutch,pplate,fwheel
12565145 2001 Slave Cyl
15046288 2000 Slave Cyl
22146231 1LE Transmission Mount
12570281 Z06 clutch
Suspension
26032907 1LE front swaybar (32mm)
10221779 1LE endlinks
10021221 1LE rear swaybar (21mm)
10262147 1LE Panhard bar
22132887 1LE front springs
22132889 1LE rear springs
52367658 1LE Front Left Lower Control Arm
22156461 1LE Front left upper Control Arm
52367659 1LE Front Right Lower Control arm
22156462 1LE Front Right upper Control arm
10288551 1LE front swaybar insulator (32mm)
10164151 1LE Lower Control Arms
22166910 1LE Rear shock insulator retainer
10009135 1LE Rear shock lower insulator
22166909 1LE Rear shock upper insulator
10235886 1LE Rear swaybar insulator (21mm)
10413903 Torque Arm Bushing
22174970 Transmission Mount
18026165 Front brake pads
12454972 Rear brake pads
18038574 Durastop Disc Brake Pads
18039370 Durastop Performance Disc Brake Pads
18060230 Front Brake Rotor
18060239 Rear Brake Rotor
10434796 & 10434797 Brake backing plates (whole assembly w/ ebrake)
Misc.
12369966 SS logo (Silver)
12369965 SS logo (Red)
25121942 Fuel filter
12378261 Diff oil for auburn
12555685 Mobil 1 oil cap
10236268 Mobil 1 sticker
12556455 + 12559261 Fuel rail covers
12564257 + 12564258 Z06 Fuel rail covers
12457574 Ram Air Hood Stickers (White Metalic)
12455211 WS6 Air lid "Ram-Air" Sticker
12455209 WS6 Lower Air Box
12455212 WS6 Lower Air box/radiator support
12455213 WS6 Nostril Screen (1)
12455214 WS6 Nostril Screen (2)
12369963 SS Hood
12369964 SS Hood grill screen
12335525 Camaro Front Fascia
10280356 Camaro Front Grille
10193494 Camaro Front Fascia Emblem
12369966 SS Side Emblems (Silver)
9593624 WS6 Wheel
9593305 WS6 Wheel
10402860 Black Electric Antenna
GMP00F Helms manual
12369969 SS Spoiler Brake Light
#237 - 12/09/04 11:59 PM Re: LS1 Parts List
dmurf Offline
Pro
dmurf  Offline
Pro
Ashburn, Va
Got any part numbers for a EVAP sensor for a 98 and 01. The new 01 PCM doesn't like my 98 EVAP Sensor.
DMurf
White Fang IV
Save the Wave!
