Topics3,715
Posts6,904
Most Online425 Oct 19th, 2025
#2360 - 02/05/08 09:16 AM
Re: Engine noise
[Re: teamzr1]
tici
What else should I consider while replacing the springs?
I can imagine: new rods new valve seals new valvecovers seals new spark plugs new (lighter) valve retainers new (lighter) valve caps
Should I try rockers with a bigger ratio? (1.8) Or is that a lost of time/money? The engine is supercharged and is 100% internally stock.
#2367 - 02/05/08 11:01 PM
Re: Engine noise
[Re: teamzr1]
tici
Are the L92 spring dual? Is it OK to install single springs? I was thinking this was for safety in case that one spring brakes the other one would avoid the valve to stay low and hit the piston.
#2375 - 02/10/08 07:00 AM
Re: Engine noise
[Re: teamzr1]
tici
Fine, thank you. Let me take a look at the engine...
Roght now I'm not in the mood to remove the engine and take it apart nor remove the heads with the engine still in the car. Is there a way to understand if the lifters are damaged without removing the heads? Same for cam, rods and crank bearings.
So far I checked everywhere with a sthetoscope at idle and revving the engine. But the noise appears only with a little load and while driving. As long the car dosn't move I can't recreate the noise. The noise appears after about 2000 rpm.
I also remove the injectors plugs one by one to see if the noise changes depending on which cylinder isn't firing, but nothing changes.
#2389 - 02/13/08 10:46 PM
Re: Engine noise
[Re: teamzr1]
tici
rushrod... you mean pushrod? (sorry, my engine slang is pretty poor)
#2392 - 02/16/08 06:35 AM
Re: Engine noise
[Re: teamzr1]
tici
Is there a way to check the lifters without removing the heads?
0 registered members (),
4
guests, and
10
spiders. |
Admin,
Global Mod,
