Topics3,715
Posts6,904
Page 3 of 3 1 2 3
#2395 - 02/16/08 01:32 PM Re: Engine noise [Re: teamzr1]
tici
Originally Posted by teamzr1
The lifters are spring loaded so with rockers off all pushrods should be equal in length at their tops.
If not then the lifter is collapsed and will not pump up
Collapsed means the spring is broken? What is the typical lifters failure?
With rockers on and with valve cover off and engine running you should see oil pumping out the tops of pushrods.
How can I do that with single coils?
#2401 - 02/19/08 03:26 PM Re: Engine noise [Re: ]
If the lifter is bad it does not pump up thus the pushrod could sit lower then normal.
If you take off valve cover and let engine idle and watch that each rocker is getting oil from the top of the pushrod that is getting oil from lifter.
You could just leave the coils hanging so sparkplugs are still getting spark.
I would do this when engine is not cold.
It might be a little messy as oil spraying but your only doing this for a couple of minutes.
Lifter could be just sticking and needing a oil based cleaner used
#2402 - 02/19/08 11:07 PM Re: Engine noise [Re: teamzr1]
tici
Some people use to replace 1 quart of engine oil with ATF a couple of days before the regular filter+oil change.
ATF can apparently "clean" the engine from the inside.
Is that a safe procedure? Would this be a solution for a gunked lifter?
Page 3 of 3 1 2 3
1 registered members (teamzr1), 14 guests, and 10 spiders.
