PIC3520A: Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode - keywords 06516 abs bcm ebcm ecm engine ignition ipm key lh2 ls2 ly7 mode on program rim sdm sir sps switch - (Jan 25, 2008)
Subject: Difficulty Programming Modules, Cannot Achieve Ignition On, Engine Off Mode
Models: 2005-2008 Chevrolet Corvette
Condition/Concern:
Some Technicians may experience failed module programming or difficulty performing certain diagnostic procedures due to the ignition not being in the "Ignition On, Engine Off" mode. The above listed vehicles use a keyless access system with push button start.
Recommendation/Instructions:
To reach the "Ignition On, Engine Off" mode, press and hold the ACC/OFF portion of the Start/ACC/OFF mode button for 5 seconds with a valid keyless entry transmitter inside the vehicle and the transmission in park. Refer to eSI Document ID # 1430062 for STS, Document ID # 1460260 for XLR and Document ID # 1456344 for Corvette.
