Park Brake System Description and Operation
System Component Description
The park brake system consists of the following:
Park Brake Lever Assembly: Receives and transfers park brake system apply input force from driver to park brake cable system. Releases applied park brake system when the lever is returned to the at-rest rest position.
Park Brake Cables: Transfers input force received from park brake lever, through park brake cable equalizer, to park brake apply lever.
Park Brake Cable Equalizer: Evenly distributes input force to both the left and right park brake units. An auto adjust spring is used to remove the slack in the park brake cables.
Park Brake Actuator/Adjuster: Uses multiplied input force from apply lever via the cables to expand park brake shoe toward the friction surface of the drum-in-hat portion of the rear brake rotor.
Threaded park brake actuators/adjusters are also used to control clearance between the park brake shoe and the friction surface of the drum-in-hat portion of the rear brake rotor.
Park Brake Shoe (Rear Disc, Drum-In-Hat System): Applies mechanical output force from park brake actuator/adjuster to friction surface of the drum-in-hat portion of the rear brake rotor.
System Operation
Park brake apply input force is received by the park brake lever assembly being raised, transferred and evenly distributed, through the park brake cables and the park brake cable equalizer, to the left and right park brake apply levers.
The park brake apply levers multiply and transfer the apply input force to the park brake actuators/adjusters which expand the park brake shoe toward the friction surface of the drum-in-hat portion of the rear brake rotor in order to prevent the rotation of the rear tire and wheel assemblies.
The park brake lever assembly releases an applied park brake system when the lever is returned to the at-rest rest position.
