OIL PANS & ACCESSORIES
12561828
Corvette Oil Pan (2002-04 LS6)
Used on 2002-2004 Corvettes with LS6 V-8.
12558762
F-Car Oil Pan
Used on 1998-2003 Camaro and Firebird LS1 V-8.
23011420
Magnetic Drain Plug
Catches and holds small pieces of metal before they can
cause damage.
17801830 NEW
High Volume LS Oil Pump Kit (not shown)
High Volume pump assembly for your LS Series engine
(except LS7 applications). Pump pick up seal included.
OIL FILTERS AND ADAPTERS
25534412
LS7 Oil Hose Adapters (not shown)
This kit is to adapt the production LS7 Oil Pan to aftermarket
AN style hoses for aftermarket dry sump oil tanks. Bolts
directly to LS7 Oil Pan and has AN male outlet for -12 AN
fittings. Kit includes (2) fitttings, (2) bolts, and
(2) sealing gaskets.
EXHAUST MANIFOLD/HEADER
12480130
Header Flange
These 3/8" thick steel header flanges are a great way to start
a fabricated set of LS series Headers for a racecar or street
rod. These are for stock LS1, LS2 and LS6 exhaust ports.
BOOKS & MANUALS
88959384
LS1 Engine Kit Installation Guide
Installing an LS1 engine in your older vehicle? You need this
guide before turning the first wrench. It includes notes and
technical explanations for necessary parts, along with part
numbers you can order from your GM dealer to get the job
done easily.
88958786 NEW
High Performance Chevy LS1/LS6 V-8’s
Discusses the LS Series engine architecture and design,
parts interchangeability along with step-by-step engine
removal sequences for many GM vehicles with LS Series
engines. Shows how to build, modify and tune high-performance
LS engines. 160 pages.
