Bulletin ACC08-013 - Introduction of GM Performance Parts LS376/480 Crate Engine and Engine Controller
DESCRIPTION:
GM Performance Parts is pleased to announce the availability of both the LS376/480 crate engine and also the non-programmable engine controller kit for the LS376/480 engine.
This new complete performance engine is rated at 480 horsepower and 475 lb/ft of torque. This engine is based on the new 2008 Corvette 6.2L LS3 V-8 production engine, but it's been upgraded with the GMPP LS Hot Cam to increase performance by 50 horsepower. This engine is fuel injected and requires a controller system.
The LS376/480 controller kit is calibrated specifically for the LS376/480 engine. This controller kit is virtually plug-and-play, and comes with everything (except for a MAF inlet tube) you'll need for use in nearly any vehicle.
EFFECTIVE DATE: Immediately
ORDER INPUT: Available to all GM dealers
GENERAL INFORMATION:
Crate engine P/N 19171224
Dealer Price - $6,250.00
Supported by GM Performance Parts standard limited crate engine warranty of 24 months/50,000 miles (see warranty card, item number PT-WA-0036-08)
Refer to page 114 of the 2008 GM Performance Parts catalog for more details
ECM and wiring harness sold separate
Controller P/N 19201327
Dealer Price - $805.00
Supported by GM Performance Parts standard limited warranty of 12 months/12,000 miles (see warranty card, item number PT-WA-0036-08)
Kit includes the following:
Controller
Engine Harness
Mass Air Flow Meter
Mass Air Flow Meter Mounting Boss
Accelerator Pedal Assembly
Oxygen Sensor (Qty 2 Per Kit)
Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
Instruction Kit
Additional information can be found in the 2008 GM Performance Parts Catalog page 357 or on the gmperformanceparts.com website
* Note - This controller will not function in a production vehicle unless all kit components are used and will not operate production gauges
