OK, hopefully Hans will read this thread
I'm still testing stuff...
Here what I imagine could increase fuel consumption:
- MAP sensor racting too slow or wrong
- Oxygen sensors racting too slow or wrong
- injectors tips dirt because of sludge washed out
from the intake mainifold causing bad spray pattern
- Clogged catalysts
So far tested:
MAP = OK (I forced the PCM to run in SD and fuel trims are the same as when I did it last time, AFR remains constant even with sudden load changes)
What else could cause an higher than normal fuel consumption?
Stefano
