MAP is about 30 kPa at idle and otherwise it shows the same values as an external pressure sensor that I use to inject water/alcohol. Baro is around 95 kPa and rises to 104 after going WOT under boost.
This weekend I checked the injectors tips and they are all nice and clean. I was able to see the intake valves of a couple of cylindes: all nice and clean too.
I checked the Oxygen sensors: no residuals, look almost new (they are 40'000 miles old).
I checked the catalysts and they look clean.
Other things I checked: compression, timing, fuel trims, spark pugs. And the car is still making 16 - 16.5 mi/ga
I remember I had the same situation once, in the same period of the year. We have now 37F in the morning and 60F during the day with a pressure of 950 hPa (= 950 mbar = 1984 psf = 13.78 psi) ...I don't know what unit you use over there.
Is it possible that certain wheater condition cause an eccessive fuel consumption? In winter or in summer I never noticed that, but in similar wheater conditions like now... honestly yes.
I know it doesen't make sense, I'm just looking for an explaination
