Review numbers in image on common install of water/meth injection
- 1. Nozzle
2. 1 way check valve shuts down fluid flow path when w/meth not on.
3. Hose Tee to allow pump pressure gauge be used when needed
4. Wired to ground wire of fuel injector to monitor pusle width, duty cycle, RPMs and engine load
5. Vaccum obtained with Tee hose fitting in vaccum hose for brakes.
6. Water/Meth Controller mounted with velcro
7. Failsafe monitors fluid volume flow and trips safety functions mounted via velcro
8. Co share windshield washer tank to also use for w/meth fluid
