Team, I am going in circles here..........( what else is new??)......
Let me make sure I comprehend what exactly you are saying....
IF, I install a Vortex(in a box), my AFR's will richen......right so far?, then, I would need a MAFT & 30# SVO injectors, to re adjust the AFR's.......and would pick up a substantial gain from doing these 3 things ALL TOGETHER?.
Or, will just adding a Air Box (as above) give me SOME more HP, but not AS much, as if I replaced the 28# stock injectors that are running at 90% @WOT?........with the 30's??.
In effect, lessening PCM reading of duty cycles, and allowing my engine to get more advance timing??.
Does this make sense, or am I confused?/. :rolleyes:
