Topics3,621
Posts6,726
Most Online265 Jan 21st, 2023
#250 - 03/16/02 07:08 PM
AFR Ratio's/ Vortex/LTFT's/STFT's
John, I had my Zo6 re-dyno'd after the EASE scan Wes did for me, and you interpreted...... The new #'s were 348rwhp, & 347rwtq. These #'s were taken on the same dyno as my first runs. And were within 1-3 HP & RWTQ of each other..... This is a stock motor, I am running near perfect AFR.......in the 12.3-6 ranges or better throughout..... Question, what should I expect if I have a Vortex put on, in both HP gains(if any), and also, changes in the AFR's, and LTFT's.....which were also very good..........
#252 - 03/21/02 06:25 PM
Re: AFR Ratio's/ Vortex/LTFT's/STFT's
Team, the 02 sensor was indeed in the exhaust....... And as far as the LTFT's, if adding an airbox is going to lean them out further, it seems like a lose, lose situation...... As, the car is making as much or more rwhp, as any '01 stock i have seen. What would be the advantage of installing the box, and then having to add a MAFT, and 30# injectors??. They stock injectors are running right at 17Ms @ WOT.....over 90% duty cycle. Can you see an appreciable power gain for the $$$$ to gain I would pick up??. Thanks
#254 - 03/22/02 06:52 PM
Team, I am going in circles here..........( what else is new??)...... Let me make sure I comprehend what exactly you are saying.... IF, I install a Vortex(in a box), my AFR's will richen......right so far?, then, I would need a MAFT & 30# SVO injectors, to re adjust the AFR's.......and would pick up a substantial gain from doing these 3 things ALL TOGETHER?. Or, will just adding a Air Box (as above) give me SOME more HP, but not AS much, as if I replaced the 28# stock injectors that are running at 90% @WOT?........with the 30's??. In effect, lessening PCM reading of duty cycles, and allowing my engine to get more advance timing??. Does this make sense, or am I confused?/. :rolleyes:
#256 - 03/31/02 07:09 PM
Hi guys. What all do I need to scan on the ease. Which categories do I need to test the low end? What other things do I have to do to get WOT dialed in? I have the haltech tric only, and the maft translator. Ill probably buy svo's if I need them.
#257 - 03/31/02 08:38 PM
For part throttle, important to scan/record is both heads (B1 and B2) LTFT, O2s (S1s), injector pulse width, trim cells, MAF in ft/lbs, RPMs, delivered torque, knock, total misfires, timing, IAT and MPH. You export recordings into Excel and average out each functions when fuel trim cells 0-19 were used. For WOT, change the math conditions to only when trim cell 22 was used to see what the values are for WOT condition. Your goal would be that both LTFT's are reporting close to zero during part throttle, and for WOT, MAF is reporting about 27 lbs/min, with WOT timing about 28 degrees ( about 25 for a '02), O2s reporting about 900 mVolts and injector pulse width with averages less then 18 mSecs. Delivered torque should be what the claims are for that M.Y or higher is the mods gave a performance increase. I find in most cases the halltech is junk, so be sure your IAT equals outside weather temperature and is supplying the amount of airflow I stated above. In almost everycase I have found the injectors do have to be increased, do not pay that halltech $700 for a set when they cost about $229. Originally posted by KilrZ06: Hi guys.
0 registered members (),
19
guests, and
14
spiders. |
Admin,
Global Mod,
