Fastener Tightening Specifications (6.2L LS9)
Application
Specification
Metric
English
Camshaft Position (CMP) Sensor Bolt
12 N·m
106 lb in
Camshaft Retainer Bolts - TORX® Head Bolts
15 N·m
11 lb ft
Camshaft Sprocket Bolts
30 N·m
22 lb ft
Clutch Pressure Plate Bolts
70 N·m
52 lb ft
Connecting Rod Bolts - First Pass
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
110 degrees
Coolant Air Bleed Pipe Bolt
12 N·m
106 lb in
Coolant Temperature Sensor
20 N·m
15 lb ft
Crankshaft Balancer Bolt - First Pass
150 N·m
111 lb ft
Crankshaft Balancer Bolt - Second Pass - Loosen Bolt
360 degrees
Crankshaft Balancer Bolt - Third Pass
50 N·m
37 lb ft
Crankshaft Balancer Bolt - Final Pass
230 degrees
Crankshaft Bearing Cap M8 Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Crankshaft Oil Deflector Nuts
25 N·m
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 N·m
18 lb ft
Crankshaft Rear Oil Seal Housing Bolts
30 N·m
22 lb ft
Cylinder Head Coolant Plug
20 N·m
15 lb ft
Cylinder Head M12 Bolts - First Pass in Sequence
20 N·m
15 lb ft
Cylinder Head M12 Bolts - Second Pass in Sequence
80 N·m
60 lb ft
Cylinder Head M12 Bolts - Third Pass in Sequence
90 degrees
Cylinder Head M12 Bolts - Final Pass in Sequence
45 degrees
Cylinder Head M8 Bolts - in Sequence
30 N·m
22 lb ft
Engine Block Coolant Drain Hole Plug
60 N·m
44 lb ft
Engine Block Coolant Heater
50 N·m
37 lb ft
Engine Block Oil Gallery Plug
60 N·m
44 lb ft
Engine Oil Cooler Coolant Hose Connector
35 N·m
26 lb ft
Engine Oil Cooler Core-to-Housing Bolts
25 N·m
18 lb ft
Engine Oil Cooler-to-Oil Pan M6 Bolts
10 N·m
89 lb in
Engine Oil Cooler-to-Oil Pan M8 Bolts
25 N·m
18 lb ft
Engine Oil Tank Bolts
25 N·m
18 lb ft
Engine Oil Tank Bracket Bolts
25 N·m
18 lb ft
Engine Oil Tank Clamp Nut
21 turns
Engine Oil Tank Transfer Tube Fittings
35 N·m
26 lb ft
Engine Oil Temperature Sensor
20 N·m
15 lb ft
Evaporative Emission (EVAP) Canister Purge Solenoid Valve Bolt
10 N·m
89 lb in
Exhaust Manifold Bolts - First Pass
15 N·m
11 lb ft
Exhaust Manifold Bolts - Final Pass
20 N·m
15 lb ft
Exhaust Manifold Stud
20 N·m
15 lb ft
Flywheel Bolts - First Pass
20 N·m
15 lb ft
Flywheel Bolts - Second Pass
30 N·m
20 lb ft
Flywheel Bolts - Final Pass
40 degrees
Front Cover Bolts
30 N·m
22 lb ft
Fuel Injection Fuel Rail Bolt
10 N·m
89 lb in
Fuel Injection Fuel Rail Studs
10 N·m
89 lb in
Fuel Injector Wire Harness Bracket Bolt
Generator Bracket Bolt
50 N·m
37 lb ft
Ignition Coil -to-Valve Rocker Arm Cover Bolts
12 N·m
106 lb in
Inlet Air Temperature Sensor
20 N·m
15 lb ft
J 41798 M8 Bolt
25 N·m
18 lb ft
J 41798 M10 Bolts
50 N·m
37 lb ft
Knock Sensor Bolts
25 N·m
18 lb ft
Motor Mount Bracket Bolts
50 N·m
37 lb ft
Oil Filter
30 N·m
22 lb ft
Oil Filter Fitting
55 N·m
40 lb ft
Oil Pan Closeout Cover Bolt - Left Side
9 N·m
80 lb in
Oil Pan Closeout Cover Bolt - Right Side
9 N·m
80 lb in
Oil Pan Drain Plugs
25 N·m
18 lb ft
Oil Pan M6 Bolts - Oil Pan-to-Rear Oil Seal Housing
12 N·m
106 lb in
Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 N·m
18 lb ft
Oil Pressure Sensor
35 N·m
26 lb ft
Oil Pump Cover Bolts
10 N·m
89 lb in
Oil Pump Relief Valve Plug
14 N·m
10 lb ft
Oil Pump Suction Pipe-to-Oil Pan Bolts
10 N·m
89 lb in
Oil Pump-to-Engine Block Bolts
25 N·m
18 lb ft
Piston Oil Nozzle Bolt
20 N·m
15 lb ft
Spark Plugs
20 N·m
15 lb ft
Supercharger Air Outlet Pressure Sensor Bolt
10 N·m
89 lb in
Supercharger Barometric Pressure Sensor Bolt
10 N·m
89 lb in
Supercharger Bypass Valve Actuator Bolts
25 N·m
18 lb ft
Supercharger Charge Air Bypass Regulator Solenoid Bolt
10 N·m
89 lb in
Supercharger Inlet Air Pressure Sensor Bolt
10 N·m
89 lb in
Supercharger - Lower - Manifold-to-Cylinder Head Bolts - First Pass in Sequence
5 N·m
44 lb in
Supercharger - Lower - Manifold-to-Cylinder Head Bolts - Final Pass in Sequence
10 N·m
89 lb in
Supercharger - Upper - Charge Air Cooler Cover Bolts - First Pass in Sequence
5 N·m
44 lb in
Supercharger - Upper - Charge Air Cooler Cover Bolts - Final Pass in Sequence
10 N·m
89 lb in
Supercharger - Upper - Water Manifold-to-Cover Bolts
10 N·m
89 lb in
Throttle Body Bolts
10 N·m
89 lb in
Timing Chain Tensioner Bolts
25 N·m
18 lb ft
Valley Cover Bolts
25 N·m
18 lb ft
Valve Lifter Guide Bolts
12 N·m
106 lb in
Valve Rocker Arm Bolts
30 N·m
22 lb ft
12 N·m
106 lb in
Water Inlet Housing Bolts
15 N·m
11 lb ft
Water Pump Bolts - First Pass
15 N·m
11 lb ft
Water Pump Bolts - Final Pass
30 N·m
22 lb ft
