Engine Mechanical Specifications (6.2L LS9)
Application
Specification
Metric
English
General
  • Engine Type
V8
  • Displacement
6.2L
376 CID
  • RPO
LS9
  • VIN
R
  • Bore
103.241-103.259 mm
4.0065-4.0065 in
  • Stroke
92.0 mm
3.622 in
  • Compression Ratio
9.1:1
  • Firing Order
1-8-7-2-6-5-4-3
  • Spark Plug Gap
1.02 mm
0.04 in
Block
  • Camshaft Bearing Bore 1 and 5 Diameter
59.58-59.63 mm
2.345-2.347 in
  • Camshaft Bearing Bore 2 and 4 Diameter
59.08-59.13 mm
2.325-2.327 in
  • Camshaft Bearing Bore 3 Diameter
58.58-58.63 mm
2.306-2.308 in
  • Crankshaft Main Bearing Bore Diameter
69.871-69.889 mm
2.75-2.751 in
  • Crankshaft Main Bearing Bore Out-of-Round
0.006 mm
0.0002 in
  • Cylinder Bore Diameter
103.241-103.259 mm
4.0065-4.0065 in
  • Cylinder Head Deck Height - Measuring from the Centerline of Crankshaft to the Deck Face
234.57-234.82 mm
9.235-9.245 in
  • Cylinder Head Deck Surface Flatness - Measured within a 152.4 mm (6.0 in) Area
0.11 mm
0.004 in
  • Cylinder Head Deck Surface Flatness - Measuring the Overall Length of the Block Deck
0.22 mm
0.008 in
  • Valve Lifter Bore Diameter
21.417-21.443 mm
0.843-0.844 in
Camshaft
  • Camshaft End Play
0.025-0.305 mm
0.001-0.012 in
  • Camshaft Journal Diameter
54.99-55.04 mm
2.164-2.166 in
  • Camshaft Bearing Diameter
55.063-55.088 mm
2.1678-2.1688 in
  • Camshaft Journal-to-Bearing Clearance
0.023-0.098 mm
0.0009-0.0038 in
  • Camshaft Journal Out-of-Round
0.025 mm
0.001 in
  • Camshaft Lobe Lift - Intake
8.4 mm
0.331 in
  • Camshaft Lobe Lift - Exhaust
8.34 mm
0.328 in
  • Camshaft Runout - Measured at the Intermediate Journals
0.05 mm
0.002 in
Connecting Rod
  • Connecting Rod Bearing Clearance - Production
0.023-0.065 mm
0.0009-0.0025 in
  • Connecting Rod Bearing Clearance - Service
0.023-0.076 mm
0.0009-0.003 in
  • Connecting Rod Bore Diameter - Bearing End
56.505-56.525 mm
2.224-2.225 in
  • Connecting Rod Bore Out-of-Round - Bearing End - Production
0.004-0.008 mm
0.00015-0.0003 in
  • Connecting Rod Bore Out-of-Round - Bearing End - Service
0.004-0.008 mm
0.00015-0.0003 in
  • Connecting Rod Side Clearance
0.11-0.51 mm
0.00433-0.02 in
Crankshaft
  • Connecting Rod Journal Diameter - Production
53.318-53.338 mm
2.0991-2.0999 in
  • Connecting Rod Journal Diameter - Service
53.308 mm
2.0987 in
  • Connecting Rod Journal Out-of-Round - Production
0.005 mm
0.0002 in
  • Connecting Rod Journal Out-of-Round - Service
0.01 mm
0.0004 in
  • Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Production
0.005 mm
0.0002 in
  • Connecting Rod Journal Taper - Maximum for 1/2 of Journal Length - Service
0.02 mm
0.00078 in
  • Crankshaft End Play
0.04-0.2 mm
0.0015-0.0078 in
  • Crankshaft Main Bearing Clearance - Production
0.02-0.052 mm
0.0008-0.0021 in
  • Crankshaft Main Bearing Clearance - Service
0.02-0.065 mm
0.0008-0.0025 in
  • Crankshaft Main Journal Diameter - Production
64.992-65.008 mm
2.558-2.559 in
  • Crankshaft Main Journal Diameter - Service
64.992 mm
2.558 in
  • Crankshaft Main Journal Out-of-Round - Production
0.003 mm
0.000118 in
  • Crankshaft Main Journal Out-of-Round - Service
0.008 mm
0.0003 in
  • Crankshaft Main Journal Taper - Production
0.01 mm
0.0004 in
  • Crankshaft Main Journal Taper - Service
0.02 mm
0.00078 in
  • Crankshaft Rear Flange Runout
0.05 mm
0.002 in
  • Crankshaft Reluctor Ring Runout - Measured 1.0 mm (0.04 in) Below Tooth Diameter
0.7 mm
0.028 in
  • Crankshaft Thrust Surface - Production
26.14-26.22 mm
1.029-1.0315 in
  • Crankshaft Thrust Surface - Service
26.22 mm
1.0315 in
  • Crankshaft Thrust Surface Runout
0.025 mm
0.001 in
Cylinder Head
  • Cylinder Head Height/Thickness - Measured from the Cylinder Head Deck to Machining Pad Locations
6.88-7.12 mm
0.271-0.283 in
  • Surface Flatness - Block Deck - Measured within a 152.4 mm (6.0 in) Area
0.08 mm
0.003 in
  • Surface Flatness - Block Deck - Measuring the Overall Length of the Cylinder Head
0.1 mm
0.004 in
  • Surface Flatness - Exhaust Manifold Deck
0.1 mm
0.004 in
  • Surface Flatness - Intake Manifold Deck
0.08 mm
0.0031 in
  • Valve Guide Installed Height - Measured from the Spring Seat Surface to the Top of the Guide
17.08-17.57 mm
0.672-0.692
Intake Manifold
  • Surface Flatness - Measured at Gasket Sealing Surfaces and Measured Within a 200 mm (7.87 in) Area that Includes 2 Runner Port Openings
0.3 mm
0.118 in
Lubrication System
  • Oil Capacity - with Filter
9.93 liters
10.5 quarts
  • Oil Capacity - without Filter
9.7 liters
10.25 quarts
  • Oil Pressure - Minimum - Hot
41 kPa at 1,000 engine RPM
124 kPa at 2,000 engine RPM
165 kPa at 4,000 engine RPM
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
Oil Pan
  • Front Cover Alignment - at Oil Pan Surface
+0.0 to-0.5 mm
+0.0 to -0.2 in
  • Crankshaft Rear Oil Seal Housing Alignment - at Oil Pan Surface
+0.0 to-0.5 mm
+0.0 to -0.2 in
  • Oil Pan Alignment - to Rear of Engine Block at Transmission Housing Mounting Surface
+0.0 to-0.5 mm
+0.0 to -0.2 in
Piston Rings
  • Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Production
0.23-0.44 mm
0.009-0.017 in
  • Piston Ring End Gap - First Compression Ring - Measured in Cylinder Bore - Service
0.23-0.5 mm
0.009-0.0196 in
  • Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Production
0.44-0.7 mm
0.017-0.027 in
  • Piston Ring End Gap - Second Compression Ring - Measured in Cylinder Bore - Service
0.44-0.76 mm
0.0173-0.03 in
  • Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Production
0.18-0.75 mm
0.007-0.029 in
  • Piston Ring End Gap - Oil Control Ring - Measured in Cylinder Bore - Service
0.18-0.81 mm
0.007-0.032 in
  • Piston Ring to Groove Clearance - First Compression Ring - Production
0.04-0.085 mm
0.00157-0.00335 in
  • Piston Ring to Groove Clearance - First Compression Ring - Service
0.04-0.085 mm
0.00157-0.00335 in
  • Piston Ring to Groove Clearance - Second Compression Ring - Production
0.04-0.078 mm
0.00157-0.0031 in
  • Piston Ring to Groove Clearance - Second Compression Ring - Service
0.04-0.078 mm
0.00157-0.0031 in
  • Piston Ring to Groove Clearance - Oil Control Ring - Production
0.012-0.2 mm
0.0005-0.0078 in
  • Piston Ring to Groove Clearance - Oil Control Ring - Service
0.012-0.2 mm
0.0005-0.0078 in
Pistons and Pins
  • Pin - Piston Pin Clearance to Piston Pin Bore - Production
0.003-0.011 mm
0.0001-0.0004 in
  • Pin - Piston Pin Clearance to Piston Pin Bore - Service
0.002-0.015 mm
0.0008-0.0006 in
  • Pin - Piston Pin Diameter
24.997-25.0 mm
0.984-0.0984 in
  • Pin - Piston Pin Fit in Connecting Rod Bore - Production
0.007-0.02 mm
0.00027-0.00078 in
  • Pin - Piston Pin Fit in Connecting Rod Bore - Service
0.007-0.0022 mm
0.00027-0.00086 in
  • Piston - Piston Diameter - Measured Over Skirt Coating
103.235-103.258 mm
4.064-4.065 in
  • Piston - Piston to Bore Clearance - Production
-0.036 to +0.016 mm
-0.0014 to +0.0006 in
  • Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off
0.71 mm
0.0028 in
Valve System
  • Valves - Valve Face Angle
45 degrees
  • Valves - Valve Face Width
1.25 mm
0.05 in
  • Valves - Valve Lash
Net Lash - No Adjustment
  • Valves -Valve Lift - Intake
13.97 mm
0.55 in
  • Valves - Valve Lift - Exhaust
13.22 mm
0.52 in
  • Valves - Valve Seat Angle
45 degrees
  • Valves - Valve Seat Runout
0.05 mm
0.002 in
  • Valves - Valve Seat Width - Exhaust
1.78 mm
0.07 in
  • Valves - Valve Seat Width - Intake
1.02 mm
0.04 in
  • Valves - Valve Stem Diameter - Production
7.955-7.976 mm
0.313-0.314 in
  • Valves - Valve Stem Diameter - Service
7.95 mm
0.313 in
  • Valves - Stem-to-Guide Clearance - Production - Intake
0.025-0.066 mm
0.001-0.0026 in
  • Valves - Valve Stem-to-Guide Clearance - Service - Intake
0.093 mm
0.0037 in
  • Valves - Valve Stem-to-Guide Clearance - Production - Exhaust
0.025-0.066 mm
0.001-0.0026 in
  • Valves - Stem-to-Guide Clearance - Service - Exhaust
0.093 mm
0.0037 in
  • Rocker Arms - Rocker Arm Ratio
1.70:1
  • Valve Springs - Valve Spring Free Length
53.1-53.7 mm
2.09-2.11 in
  • Valve Springs - Valve Spring Installed Height
45.75 mm
1.8 in
  • Valve Springs - Valve Spring Load - Closed
400 N at 45.75 mm
90 lb at 1.8 in
  • Valve Springs - Valve Spring Load - Open
1326 N at 31.5 mm
298 lb at 1.24 in
