Adhesives, Fluids, Lubricants, and Sealers (6.2L LS9)
Application
| Type of Material
| GM Part Number
United States
| Canada
All Purpose Parts Cleaner
| Cleaner
| 12378553
| 88900920
Coolant Temperature Sensor Threads
| Sealant
| 12346004
| 10953480
Crankshaft Key
| Sealant
| 9985969
Crankshaft Rear Cup Plug
| Sealant
| 89021297
| 10953488
Engine Block Coolant Drain Hole Plug
| Sealant
| 12346004
| 10953480
Engine Block Oil Gallery Plug - Front
| Threadlock
| 12345382
| 10953489
Engine Block Oil Gallery Plug - Side
| Sealant
| 12346004
| 10953480
Engine Degreaser
| Cleaner
| 12378482
| 992878
Engine Oil
| 5W-30 Oil - Synthetic
| 12345610
| 993193
Engine Oil Pressure Sensor Threads
| Sealant
| 12346004
| 10953480
Engine Oil Supplement
| Fluorescent Dye
| 12345795
| 10953470
Exhaust Manifold Bolts
| Threadlock
| 12345493
| 10953488
Flywheel Bolts
| Threadlock
| 12345382
| 10953489
Fuel Injection Fuel Rail Bolts
| Threadlock
| 12345382
| 10953489
Ignition Coil-to-Rocker Arm Cover Bolts
| Threadlock
| 12345382
| 10953489
Intake Manifold Bolts
| Threadlock
| 12345382
| 10953489
Oil Pan Surface at Front Cover and Rear Housing
| Sealant
| 12378521
| 88901148
Thread Repair Component Cleaner
| Cleaner
| 12346139
| 10953463
| Cleaner
| 12377981
| 10953463
Thread Repair Cutting Oil
| Lubricant
| 1052864
| 992881
