#2709 - 07/19/0807:18 AMRe: Brake fluid cause of jammed clutch debunked
[Re: ]
Or when the hose was taken apart that seal/stop did not close all the way ? Or when taken off and all fluid was taken out it needs to be bleed again ? If you take the rod off the pedal with present master does it also have no pressure ?
