Air Conditioning Compressor Bracket Bolts
50 N·m
37 lb ft
Air Conditioning Idler Pulley Bolt
50 N·m
37 lb ft
Air Conditioning Tensioner Bolt
25 N·m
18 lb ft
Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts
20 N·m
15 lb ft
AIR Right Side Pipe Bracket-to-Cylinder Head Bolt
50 N·m
37 lb ft
Camshaft Retainer Bolts
25 N·m
18 lb ft
Camshaft Sensor Bolt
25 N·m
18 lb ft
Camshaft Sprocket Bolts
35 N·m
26 lb ft
Connecting Rod Bolts (First Pass)
20 N·m
15 lb ft
Connecting Rod Bolts (Final Pass)
60 degrees
Coolant Temperature Gauge Sensor
20 N·m
15 lb ft
Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed)
330 N·m
240 lb ft
Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes)
50 N·m
37 lb ft
Crankshaft Balancer Bolt (Final Pass)
140 degrees
Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence)
20 N·m
15 lb ft
Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence)
80 degrees
Crankshaft Bearing Cap Side Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence)
20 N·m
15 lb ft
Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence)
53 degrees
Crankshaft Oil Deflector Nuts
25 N·m
18 lb ft
Crankshaft Position Sensor Bolt
25 N·m
18 lb ft
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
30 N·m
22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
30 N·m
22 lb ft
Cylinder Head Coolant Plug
20 N·m
15 lb ft
Cylinder Head Core Hole Plug
20 N·m
15 lb ft
Drive Belt Idler Pulley Bolt
50 N·m
37 lb ft
Drive Belt Tensioner Bolts
50 N·m
37 lb ft
Engine Block Coolant Drain Plugs
60 N·m
44 lb ft
Engine Block Heater
40 N·m
30 lb ft
Engine Block Oil Gallery Plugs
60 N·m
44 lb ft
Engine Flywheel Bolts (First Pass)
20 N·m
15 lb ft
Engine Flywheel Bolts (Second Pass)
50 N·m
37 lb ft
Engine Flywheel Bolts (Final Pass)
100 N·m
74 lb ft
Engine Flywheel Hub Collar Bolt (Automatic Transmission)
130 N·m
96 lb ft
Engine Front Cover Bolts
25 N·m
18 lb ft
Engine Mount Bracket-to-Engine Block Bolts
50 N·m
37 lb ft
Engine Mount Lower Stud-to-Crossmember Nut
65 N·m
48 lb ft
Engine Mount Upper Nut
65 N·m
48 lb ft
Engine Rear Cover Bolts
25 N·m
18 lb ft
Engine Service Lift Bracket M10 Bolts
50 N·m
37 lb ft
Engine Service Lift Bracket M8 Bolt
25 N·m
18 lb ft
Engine Valley Cover Bolts
25 N·m
18 lb ft
Exhaust Manifold Bolts (First Pass)
15 N·m
11 lb ft
Exhaust Manifold Bolts (Final Pass)
25 N·m
18 lb ft
Exhaust Manifold Pipe Nuts
35 N·m
26 lb ft
Fuel Injection Fuel Rail Bolts
10 N·m
89 lb in
Generator and Power Steering Pump Bracket Bolts
50 N·m
37 lb ft
Generator Rear Bracket Bolt
50 N·m
37 lb ft
Ground Strap-to-LH Cylinder Head Bolt
32 N·m
23 lb ft
Ground Strap-to-LH Frame Rail Bolt
12 N·m
106 lb in
Ignition Coil-to-Bracket Bolts
12 N·m
106 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts
12 N·m
106 lb in
Intake Manifold Bolts (First Pass in Sequence)
5 N·m
44 lb in
Intake Manifold Bolts (Final Pass in Sequence)
10 N·m
89 lb in
Knock Sensors
20 N·m
15 lb ft
Oil Filter
30 N·m
22 lb ft
Oil Filter Fitting
55 N·m
40 lb ft
Oil Level Indicator Tube Bolt
16 N·m
12 lb ft
Oil Level Sensor
13 N·m
115 lb in
Oil Pan Baffle Bolts
12 N·m
106 lb in
Oil Pan Closeout Cover Bolt (Left Side)
12 N·m
106 lb in
Oil Pan Closeout Cover Bolt (Right Side)
12 N·m
106 lb in
Oil Pan Drain Plug
25 N·m
18 lb ft
Oil Pan M8 Bolts (Oil Pan to Engine Block and Oil Pan-to-Front Cover)
25 N·m
18 lb ft
Oil Pan M6 Bolts (Oil Pan to Rear Cover)
12 N·m
106 lb in
Oil Pressure Sensor
20 N·m
15 lb ft
Oil Pump-to-Engine Block Bolts
25 N·m
18 lb ft
Oil Pump Cover Bolts
12 N·m
106 lb in
Oil Pump Relief Valve Plug
12 N·m
106 lb in
Oil Pump Screen Nuts
25 N·m
18 lb ft
Oil Pump Screen-to-Oil Pump Bolt
12 N·m
106 lb in
Oil Temperature Sensor
20 N·m
15 lb ft
Oil Transfer Cover Bolts
12 N·m
106 lb in
Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud)
12 N·m
106 lb in
Power Steering Pump Bolts
25 N·m
18 lb ft
Power Steering Reservoir Bolts
50 N·m
37 lb ft
Spark Plugs (Cylinder Heads-New)
20 N·m
15 lb ft
Spark Plugs (all Subsequent Installations)
15 N·m
11 lb ft
Starter Motor Bolts
50 N·m
37 lb ft
Throttle Body Bolts
12 N·m
106 lb in
Valve Lifter Guide Bolts
12 N·m
106 lb in
Valve Rocker Arm Bolts
30 N·m
22 lb ft
12 N·m
106 lb in
Vapor Vent Pipe Bolts and Studs
12 N·m
106 lb in
Water Inlet Housing Bolts
15 N·m
11 lb ft
Water Pump Bolts (First Pass)
15 N·m
11 lb ft
Water Pump Bolts (Final Pass)
30 N·m
22 lb ft
Water Pump Cover Bolts
15 N·m
11 lb ft
