Topics3,686
Posts6,867
 Most Online425 Oct 19th, 2025
#2708 - 07/19/08 06:14 AM
Re: Brake fluid cause of jammed clutch debunked
[Re: teamzr1]
Brett Hunter
I looked at the original one taken out in 2006 and it is bad. You can move the clutch pedal rod in and out without opening the spring loaded fitting, the new one will not budge. This means it is not building any pressure.
#2710 - 07/19/08 07:52 AM
[Re: teamzr1]
Brett Hunter
The one that is in it now also has no pressure with the pedal removed. I can easily press it in with my hands.
  The original still has fluid in it, since it is a closed system I never removed the fluid.
  Once I remove the quick connect I will be able to remove the one in it. I just had to come in from the heat for a break.
  I wonder if forcing the pedal up when the slave is stuck would cause the cylinder to fail?
#2712 - 07/19/08 09:02 AM
[Re: teamzr1]
Brett Hunter
Will do. I just finished replacing it and the new one operates fine.
#2713 - 07/19/08 10:37 AM
[Re: ]
Brett Hunter
I first tried to bleed the old one with no luck. I then took all of the hoses apart and the plunger appeared to be cocked sideways. After fixing that and bleeding, it seems to be working. I'll box up the untouched replacement and send it. The one I tore apart had the fluid changed within a few days of failing. So I completely agree that changing the fluid is definitely not the cure. BTW be careful when removing the spring loaded quick connect fitting. I was lucky to find all of the pieces when it went flying across the garage.
#2715 - 07/20/08 12:47 AM
[Re: teamzr1]
tici
Is it possible that the self adjusting mechanism of the clutch causes problems that people assume are due to damaged hydraulics or old fluid?
  From time to time my clutch pedal felt really strange: while pushing and also releasing it. The clutch was releasing fine, just the pedal movement was slowed down by something.
  I pressure bleeded the system several times without results, replaced the master and the slave but the problem was still there.
  All of a sudden, after a spirited trip on our mountais the problem desappeared. The only thing I know that changes automatically is the position of the ring inside of the pressure plate that adjusts the clutch for wear.
  I can imagine that if the spring fingers arent in the correct position the whole system isn't working properly.
9
guests, and
10
spiders. |
	Admin,
	Global Mod,
