2001 Corvette Specifications
Major Changes for 2001
Two new exterior colors:
Quicksilver and Speedway White
INCREASED Horsepower- 350HP
JL4 Active Handling Generation II-
Standard Safety Feature. All models- Chrome Exhaust
Tips Stainless Steel and Aluminum Exhaust.
RPO - ZO6 Option
Model AvailabilityStandard Safety Features
Coupe 1YY07JL4 Active Handling Generation II
* Convertible 1YY67Air Bags - Driver and Passenger
Hardtop 1YY37Brakes - Power Disk, 4 Wheel
Anti-Lock
Assembly PlantDaytime Running Lamps
Bowling Green, KYRemote Keyless Entry - with Active Halo
Lighting
Side Guard Door Beams
Select Standard FeaturesStarter Saver and Battery Saver
MechanicalTheft Deterrent System - PASS-Key
Engine - 5.7L V8 LS1Select Optional Features
Transmission - 4 Speed Automatic w/overdrive (Coupe &
Convertible) Six Speed manual (Hardtop)Electrochromic
Mirrors*
Traction ControlAxle Ratio - Performance
Steering - Speed sensitive, power rack and pinionCompact
Disc Changer - Remote, 12 Disk
Suspension - Z51 Sport suspension (Std. On
Hardtop)Electronic Dual Zone Climate Control
InteriorFloor Mats
Air ConditioningFog Lamps
Defogger - Rear WindowHead-Up Display
Gauges - Analog, Ultraviolet FloodlitLuggage Shade &
Parcel Net (Coupe)
Grab Handle - Passenger's sideMemory Package - Exterior
mirrors, radio, driver's seat, climate
Ignition - Dash Mountedcontrol & Power Telescoping
steering column (if so equipped)
Locks - PowerMoldings - Body Side
Radios - Delco cassette w/Bose speakers (coupe &Power
Telescoping/Manual Tilt Steering Wheel
convertible)Radio - Delco CD w/Bose Speakers
Radios - Delco cassette (hardtop)Roof Panel - Removable,
Blue Tint (coupe)
Seats - Leather TrimmedRoof Panels - Dual Removable
(coupe)
Seats - Power drivers side (coupe and convertible)Seats
- Power Passenger - Sport
ExteriorSelective Real Time Damping (adjustable shocks)
Removable Top - Body Color (coupe)Transmission - 6 Speed
manual transmission
Tires - Extended mobility w/tire pressure sensorTwilight
Sentinel w/Automatic Headlamps
Wheels - Forged Aluminum five spokeWheels-High Polish or
Magnesium
Windows - Power, driver and passenger express downZ51
Performance Handling Package (Standard on hardtop)
2001 Technical Specifications -
Dimension (In.)
Exterior Coupe-ConvertibleEngine
Wheel Base - 104.5Engine Code LSI
Length - 179.7Description 5.7L (346 CID) V8
Width - 73.6Compression Ratio 10.1:1
Height - 47.7Horsepower @ RPM - 350 @ 5600*
Track, Front - 62.0Torque (lbs. ft.) 350 @4400
Track, Rear - 62.1Exhaust System - Full Dual, Aluminum
Stainless Steel
InteriorTires / Wheels
Passenger Volume (cu. ft.) - 51.4Tires Std. (Front) -
P245/45ZR17 Extended Mobility
Passenger Capacity - 2Tires Std. (Rear) - P275/40ZR18
Extended Mobility
Head Room, Front (in.) - 37.9 / 37.6Wheels Std (Front)
17" x 8.5" Forged Aluminum
Leg Room, Front (in.) - 42.7Wheels Std (Rear) 18" x 9.5"
Shoulder Room, Front (in.) 55.3
Luggage CompartmentTrailer Towing
Trunk Volume (cu. ft.) - 24.9 / 13.9 (top up)Towing
Class - Not Recommended
Liftover Height (in.) - 36.7
2001 Corvette Colors
With Suggested Interior Combinations
ExteriorInterior (Leather Trimmed)
BlackLight
GrayTorch
RedLight
Oak
11 - Lt. Pewter MT...
12 - Quicksilver MT*...
28 - Navy Blue MT..
40 Speedway White *....
41 - Black....
70 - Torch Red....
79 - Millennium Yellow.
86 - Magnetic Red II.. .
91 - Dark Bowling Green MT.. .
Brakes
Type, Front - Hydraulic Power Disc (dual Piston)
Type, Rear - Hydraulic Power Disc
ABS - 4 Wheel
Lining Material, Front - Semi-Metallic
Lining Material, Rear - Semi- Metallic
Swept Area, Front / Rear (sq. in.) - 263.0 / 158.8
Capacities
Cooling System (qts.) - 11.4
Fuel Tank (gals.) - 19.1
Base Curb Wt. (lbs.) - 3,221
Restraint Systems
Air Bag - Left Standard Right Standard
Front Belts - Left 3pt Lap/Shoulder Right 3pt
Lap/Shoulder
Steering and Suspension
Steering Type / Ratio Magnasteer II speed sensitive,
Power-Assisted, Magnetic Variable Effort / 16.1:1
Front Suspension - Short/Long Arm Double Wishbone
Rear Suspension - Short/Long Arm Double Wishbone
Front Stabilizer Bar (mm) - B/F45 23x3.8 Z51 25.4x4
Rear Stabilizer Bar (mm) - B/F45 19.1x2 Z51
21.7x3MT - Indicates Metallic Paint
Convertible Tops are Available in White,
Black and Light Oak
.Hardtop Available with Black Interior Only, Not
Available with Quicksilver, Navy Blue, Magnetic Red,
Millennium Yellow, or Dark Bowling Green Exterior.
.Magnetic Red and Millennium Yellow are extra cost
premium colors
.All paints use Base Coat / Clear Coat System which is
formulated to minimize the effects of acid rain, water
spotting, and other environmental damage.
.Some Color/Trim/Model restrictions apply; Contact your
local Chevrolet Dealer for Details.
* New or Changes for 2001
**Information from the 2001 GM Product Preview Fleet and Commercial
Vehicle Guide
*** 2001 availability will be two basic packages above the already
standard 1SA package. The 1SB option package which is the standard
equipment package and adds to it, the memory system (power seats,
sports bucket seats, dual zone air), fog lamps and the rear luggage
shade. The 1SC package includes all the above plus electrochromic
mirrors (new for 01), HUD, twilight sentinel and power telescoping
steering column. The Convertible packaging is slightly different in
that the 1SB package includes the electrochromic mirrors
John Rovner
