#2800 - 09/25/0807:37 PMRe: Part numbers for LS3, LS7, LS9 clutch, flywheel, master, slave
[Re: teamzr1]
LS9 has a stronger crank to handle the ZR1 HP/Tq so it's flyhweel has nine bolts to 6 bolts for other models.
LS9 also has a new designed slave that now allows just the bearing be replaced if need be where older design you had to replace the whole slave.
ZR1 also has a larger diameter driveshaft and drivetube. The end of driveshaft though going through clutch and pilot bearing is the same for all models.
